Snobrdrkid's WJ Build Thread - Page 292 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Cure for your Tie Rod Roll!Steering and more from Ruffstuff!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 06-17-2012, 10:02 PM   #4366
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by Larryftmfw View Post
4 1/2 months
Ohhhhh okay. Did you start a build thread?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 10:04 PM   #4367
Larryftmfw
I did, haven't been on it in a while tho lol
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 10:16 PM   #4368
snobrdrkid07
Mine is pretty awesome, a lot of people flock here to chat and stuff
-Michael-
Unread 06-17-2012, 10:27 PM   #4369
Larryftmfw
I do like yours, lots of good info
Unread 06-17-2012, 10:28 PM   #4370
PhantomWJ
2003 WJ
Awesome.....no way....ha ha ha
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 10:36 PM   #4371
snobrdrkid07
Haha thanks, that is what it is here for.
Get out :P
-Michael-
Unread 06-18-2012, 12:07 AM   #4372
PhantomWJ
2003 WJ
Get out :P
No.
Unread 06-18-2012, 04:35 AM   #4373
Larryftmfw
No.
Lol
Unread 06-18-2012, 09:25 AM   #4374
snobrdrkid07
No.
Okay then.
-Michael-
Unread 06-18-2012, 09:39 AM   #4375
snobrdrkid07
So more or less back on topic here.
The second set of 3/4 inch spacers will be here today. I may go rent those spring compressors from Auto whatever. Take it and just put it on, then jack the jeep up so the coil will hopefully just fall out and make it easier.
Also getting the rear IRO sway links today. Will do both at the same time, makes the most sense. Since I am only sitting at about 1.5 inches of lift in the rear, the additional 3/4 spacer should give me around 2.25 inches of lift in the rear. Around 21.25 hub to fender.
-Michael-
Unread 06-18-2012, 10:50 AM   #4376
PhantomWJ
2003 WJ
at that height you probably wont need the coil spring compressor, but it will most certainly help....just jack up the body as high as you can and drop one side at a time...
Unread 06-18-2012, 11:00 AM   #4377
snobrdrkid07
You are correct that i dont need them. BUT even at full droop (with shocks and sway disco'd) it is still a bit** because I still have to use force to compress the spring to get it in there. So the compressors will just make it overall easier. This will be the 4th time doing this. Lol.
-Michael-
Unread 06-18-2012, 11:19 AM   #4378
ChrisHager
ChrisHager's Avatar
You could do like I did and just squeeze the spring with your hands. If you're like me, you should be able to mash them down to about 4" tall.
HA! Really though, I just let the axle droop and jacked up the opposite side from where I was working. That gave me tons of room.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 11:36 AM   #4379
PhantomWJ
2003 WJ
I know wath you mean...it isn't my first rodeo, or 4th...at any rate, to each their own....
Or, like mentioned above....use the hands to compress them
Unread 06-18-2012, 11:49 AM   #4380
snobrdrkid07
When i put the jeep on jack stands and drop the axle, one side lower at a time. It pops out the breather hose and blah blah blah. I just figured itd be easier to keep them at compressed length, and then drop the axle etc.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
