Snobrdrkid's WJ Build Thread - Page 290 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 06-17-2012, 03:51 PM   #4336
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by Larryftmfw View Post
My jeep does the same thing, kind of feels like the front end goes light? Could be the tre's
It just seems like I am having to correct it more then I did previously. I do seem to get the same feeling too.
MAYBE it is because my steering wheel is off center and its throwing ME off thinking to go straight to hold the wheel straight but I can currently do that. But that doesn't really explain the 'lighter' feeling in the front.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 04:04 PM   #4337
Larryftmfw
Mine is off too lol I'm going to do the tre's and If that doesn't fix it I'll be upgrading to a Durango steering box
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 04:57 PM   #4338
99WJdan
Mine does it too. I think is has something to do with the track bar not being completely parallel to the drag link? Something with the geometry of the steering components.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 05:05 PM   #4339
PhantomWJ
2003 WJ
All Moog TRE's and adjusting sleeves.
Well thank you too. The first package to come to me from Hawaii ever!
How in the world did it get bent??
Mall crawling....web wheeling...ha ha ha...sarcasm
I don't remember, either Ocatillo wells or Calico....probably a big rock....fortunately I have a stock tie rod to replace it with....its cheaper to replace it with stock parts, at least this part is....
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 05:49 PM   #4340
snobrdrkid07
That a direct swap?
Hmmm you did the moog upgrade already right? Those two not being parallel does apparently cause bump steer from what I've heard
-Michael-
Unread 06-17-2012, 05:52 PM   #4341
snobrdrkid07
The Moog sleeve was only like 25 bucks man.
-Michael-
Unread 06-17-2012, 05:54 PM   #4342
snobrdrkid07
All cleaned up!
-Michael-
Unread 06-17-2012, 06:06 PM   #4343
PhantomWJ
2003 WJ
Really, as In the whole bar? Good to know.
Unread 06-17-2012, 06:09 PM   #4344
snobrdrkid07
Heck yeah man. The really long tie rod sleeve was like 25 and the the drag link was like 23. Check out rockauto.com. that is where i got my stuff at.
-Michael-
Unread 06-17-2012, 06:26 PM   #4345
PhantomWJ
2003 WJ
Cool. I didn't know they were that cheap. I bought a used spare tie rod for $40 with good TREs....
Unread 06-17-2012, 06:32 PM   #4346
snobrdrkid07
Thats not bad. What type of tie rods?
-Michael-
Unread 06-17-2012, 06:39 PM   #4347
PhantomWJ
2003 WJ
I dunno...stock....whatevrr was equipped with a stock tie rod...
Unread 06-17-2012, 06:42 PM   #4348
snobrdrkid07
Gotcha. Didn't know if it was after market or something like that.
-Michael-
Unread 06-17-2012, 06:55 PM   #4349
99WJdan
yeah i did the moog upgrade. Defiantly tightened my steering up, but it needs an alignment. The threads on the moog tres vs stock are different i believe. It still tracks straight, but i have horrible tire wear now (ordering new tires soon). Plus my steering wheel is off centered. An alignment should fix everything once and for all. Not sure about bump steer tho, you would need to mess around with the geometry and that can get expensive.
Unread 06-17-2012, 07:12 PM   #4350
snobrdrkid07
Anything suspension is gonna be expensive. Ughhhh. It sounds like you need a serious alignment. Why would you wait???
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
