Snobrdrkid's WJ Build Thread - Page 289 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 06-16-2012, 11:01 PM   #4321
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by mreed21 View Post
6 months ago.
Sent from my DROID RAZR using JeepForum
Not sure man?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-16-2012, 11:04 PM   #4322
billzcat1
Chicken in a Turkey Suit
2003 WJ
Thanks for the pics. The original tie rod and drag link are .125 wall so there's a pretty decent improvment in wall thickness.
Can you do an ID measurement on them? That's what the prongs are for that are above the display, near the in/mm button. If it's too late, that's ok too.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 06-16-2012, 11:16 PM   #4323
snobrdrkid07
Is this it?
I would also like to point out that the 'grey' part of the sleeve, the main part, that the ID does not change at all and that the thickness of the tubing is significantly more in the center where there are no threads.
Edit: My calculations give the main part of the sleeve a wall thickness about 0.23 inches! It is tapered down on the ends, BUT the inside is the same ID all the way through. They are very thick!
-Michael-
Unread 06-16-2012, 11:21 PM   #4324
billzcat1
2003 WJ
Perfect.
Unread 06-16-2012, 11:22 PM   #4325
snobrdrkid07
Great! I added some more info above in case you missed it.
-Michael-
Unread 06-16-2012, 11:26 PM   #4326
billzcat1
2003 WJ
So you have 1.376 OD on the main body with .906 ID (or more in the non-machined center). Looks like .235-wall tubing. It's probably .25-wall tubing, just the ends are bored to accommodate stock-type TREs.
That's a HUGE improvement over the stock .125-wall tubing. I'll be getting this for sure when I do the TREs. This is a note-worthy upgrade for both tie rod and drag link and should not only improve feedback, but also durability on the vulnerable tie rod. Now the JKS is .375 wall-tubing so it's not quite THAT burly, but still a mod worth doing.
Unread 06-16-2012, 11:51 PM   #4327
snobrdrkid07
Shoot man, it is DOUBLE the factory stuff. I am very pleased to hear this news, you can not go wrong for freaking 20 bucks! While it may not be as thick as the JKS it is still pretty dang awesome for a tenth of the price! Shoot this is probably already overkill. But, if it is worth doing, it is worth OVER doing! Glad I could help out.
Those numbers varied slightly with 1.375 OD and 0.900 ID being the average. Those numbers apply to both the Tie Rod sleeve and Drag Link.
-Michael-
Unread 06-17-2012, 12:01 AM   #4328
Larryftmfw
Very nice! There moog tre's right?
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 12:03 AM   #4329
alwaysHI
2003 WJ
Originally Posted by snobrdrkid07
IRO 3 Inch rear sway links will also be here on Monday, thank you AlwaysHI!
Hahah you welcome!
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/ - SOLD
alwaysHI is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 12:28 AM   #4330
PhantomWJ
2003 WJ
Yeah, JKS bars still get bent; mine got bent.
It is a good thing I did not buy it new, it came with axles, cause I would not want to spend that much money for it to bend.
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 06-17-2012, 12:36 AM   #4331
billzcat1
2003 WJ
Originally Posted by snobrdrkid07 View Post
Just a quick tip from the ex-machinist in me - When measuring the thickness of just about anything (especially wall thickness on a tube like this), only use the beveled tips of the caliper. That's where the calipers will be most precise for you. Use the thumbwheel and apply light pressure - you'll be able to make those calipers flex a lot if you use too much pressure.
As for the OD - all raw stock runs oversized. So if you need a 1.375" part, you buy 1.375" stock which measures out at a nominal 1.380". Moog just left the body in the original mill finish - no need to turn it down. It would only add cost with no added benefit.
Unread 06-17-2012, 10:13 AM   #4332
snobrdrkid07
All Moog TRE's and adjusting sleeves.
Originally Posted by alwaysHI
Hahah you welcome!
Well thank you too. The first package to come to me from Hawaii ever!
How in the world did it get bent??
-Michael-
Unread 06-17-2012, 10:25 AM   #4333
snobrdrkid07
Thanks for the tip with the Calipers, good to know.
Hmm, did not think of that but that makes perfect sense.
-Michael-
Unread 06-17-2012, 03:46 PM   #4334
snobrdrkid07
Question. When I hit a bump it makes the Jeep go off track some (mostly when not holding the steering wheel) anything I can do about this? Caster issue or TRE issue? I have not installed my new Moog TRE stuff yet. That has been my only complaint so far with the new lift.
Second, Is ~4" of up travel on the front shocks too little? The space from the axle to bump stop is about 4" as well. So, going full bump would be fully compressing the shocks and hitting the bump stops. I don't know is DD'ing will cause it to have that much uptravel. Was just wondering what you all thought. I am not too concerned about it at the moment.
-Michael-
Unread 06-17-2012, 03:49 PM   #4335
Larryftmfw
My jeep does the same thing, kind of feels like the front end goes light? Could be the tre's
ome hd , OME lift kit , snobrdrkid , wj
