Snobrdrkid's WJ Build Thread - Page 284 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Cure for your Tie Rod Roll!Steering and more from Ruffstuff!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 06-13-2012, 09:38 PM   #4246
Larryftmfw
Originally Posted by snobrdrkid07
That is the type of fix that is awesome.
Do you have any pictures of your front pinion angle?
Not yet and my front ds is still off. I'm guessing my starter should still be replaced?
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 06-13-2012, 09:41 PM   #4247
PhantomWJ
2003 WJ
Yeah...unless you plan on getting dirty at the wrong place and wrong time whe. It.decided not.to.engage and u have to tap it....
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 06-13-2012, 09:54 PM   #4248
snobrdrkid07
snobrdrkid07's Avatar
I mean, I have heard them locking up like that when they are hot. If it does it again, I would replace.
You can still snap a picture of your diff and yoke, Id like to see the angle it is at. But, it is not going to be as good as with the DS on there...
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 05:16 PM   #4249
snobrdrkid07
Need more lift in the rear. As it sits with a full tank of gas. Front is 20.5 and rear is 20.5 hub to fender. Throw the trailer on there and pulls the front up to 21 and sags the rear down to about 20. I am thinking of putting another 3/4 inch spacer in the rear. OME gave me 1.5 inches over stock (keep in mind so-so iso's) then adding the 0.75 inch spacer gave me around 2.25 inches, then another will put me at 3 inches of lift and 21 hub measurement. No, I am not going to stack them either, I will put one on the frame and on the axle. I figured if I can find a cheap rear 3/4 spacer, that would be less expensive then buying isolators? haha. My main concern is that I want to keep the front end DOWN as much as possible. Any other ideas? Oh, there is only about 100 pounds tongue empty and probably 200-250 at the most when loaded with whatever. I was thinking air bags as an option but ehhh.
-Michael-
Unread 06-14-2012, 05:43 PM   #4250
billzcat1
Chicken in a Turkey Suit
2003 WJ
I think you're way over-thinking this. Don't double-space the rear to give you the best stance while towing with 200lbs tongue weight. Would you double up spacers just because you had a passenger in the back seat?
Just deal with it. Vehicles squat down with a trailer. Squatting 1/2 inch is nothing.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 05:51 PM   #4251
snobrdrkid07
Oh, ive been know to way over think things and i dount doubt that haha.
I just dont like how the rear end is lower while there isnt a trailer on it. Its just bugging me and ive probably lost my marbles.
-Michael-
Unread 06-14-2012, 05:52 PM   #4252
billzcat1
2003 WJ
Slap yourself in the face!
Consider this your friendly trans-continental sanity check.
Unread 06-14-2012, 05:55 PM   #4253
snobrdrkid07
Hahahaha will get right on that! Thanks man.
-Michael-
Unread 06-14-2012, 06:28 PM   #4254
Larryftmfw
Just get bigger springs.
Unread 06-14-2012, 08:27 PM   #4255
JerzeyBoyWJ
2003 WJ
iro 3inch lift and I think you will be happy
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 08:31 PM   #4256
snobrdrkid07
Well ive got basically 3 inches in the front already. I just need to bring the rear up another inch to have it sit where i want just normally.
-Michael-
Unread 06-14-2012, 10:31 PM   #4257
Cowboyup94
Add another .75 " and then without the trailor the jeep looks goofy as hell...
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 10:34 PM   #4258
snobrdrkid07
Actually, If I add another spacer. It will give me my factory 1 inch rake back. (when not towing) and that is what I want. So when I do two, it will take that inch and sit level.
-Michael-
Unread 06-14-2012, 10:42 PM   #4259
Cowboyup94
Ehh whatever you like. I'm not a fan of the rake effect because I don't want my jeep to look like a minivan. To each his own.
JEEP
Unread 06-14-2012, 10:45 PM   #4260
snobrdrkid07
With nothing on it, it will sit almost level. So the 3/4 in the rear will just be a tad bit more in the rear and will give me the rake back. Which, will make me happy AND give me enough lift to run the IRO rear a-arm
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
