Snobrdrkid's WJ Build Thread - Page 282 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!1976-1986 Jeep CJ7 with Stationary Vent Windows Weatherstr
Unread 06-12-2012, 08:47 PM   #4216
Larryftmfw
Originally Posted by snobrdrkid07
What lift do you have? Which end did it grenade on? Axle or t-case.
6.5 long arm, the worst was the t-case
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 06-12-2012, 08:49 PM   #4217
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Yup, that is a big lift. Custom driveshaft or stock double cardon? Front adjustable long arms? Which brand lift?
I am not sure if even the front stock double cardon driveshaft can handle that much lift.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-12-2012, 08:58 PM   #4218
snobrdrkid07
Mr. WJ
Update, in preparation to do as many pictures/measurements as I can with the MOOG TRE's compared to factory I bought a digital set of Calipers to get very precise measurements! Since I will be going away and having all the brakes/tie rods done for me while I am gone, there may be lacking side by side photos. However, I will ask to keep all the parts and still get measurements on the factory stuff and photoshop side by side if need be.
I will be getting these numbers:
1. Weight, OD (on the middle and outer section, they differ), ID (threads), and thickness of the material of the tie rod sleeve AND the drag link.
2. I want to to get weights of the Moog TRE's aswell as the thickness of them
3. Anything else?
I did a little test for fun and on the bathroom scale the tie rod sleeve was about 14 pounds mines the locking brackets. With all the hardware and the sleeve, I would guess close to 16 pounds!
-Michael-
For Sale:
Unread 06-12-2012, 09:32 PM   #4219
Larryftmfw
It's the iro, and it's the shaft that's all u joints. Non adj front long arms
Unread 06-12-2012, 09:34 PM   #4220
snobrdrkid07
Mr. WJ
Well there is no adjustment in caster if your long arms are not adjustable? I don't think. Unless, no wait a minute, there is caster adjustment with the IRO 3-link setup. That gold bracket should be caster adjustment.
Did you mean IRO front driveshaft?
-Michael-
For Sale:
Unread 06-12-2012, 09:37 PM   #4221
Larryftmfw
Iro lift, and yea caster is adj.
Unread 06-12-2012, 09:41 PM   #4222
snobrdrkid07
Mr. WJ
Okay okay, makes sense now. SO to keep your caster where it needs to be, that means that the pinion angle on the diff side is going to be steep. Kinda surprised that the axle side didnt go first. That is if your caster is in spec. Maybe it is time to go to a double double driveshaft?
-Michael-
For Sale:
Unread 06-12-2012, 10:03 PM   #4223
Larryftmfw
What's that look like?
Unread 06-13-2012, 07:37 AM   #4224
snobrdrkid07
Mr. WJ
I am not an expert on that amount of lift and such. BUT a double double cardon driveshaft is a driveshaft with two u-joints on each side. So, what you have at your t-case would ALSO be at the axle side too. I do not remember many people needing this though. That is why I am conflicted here.
-Michael-
For Sale:
Unread 06-13-2012, 08:05 AM   #4225
Larryftmfw
Yea, iro said that my style driveshaft would be more than able to handle this lift! So I'm thinking it was improperly aligned
Unread 06-13-2012, 08:21 AM   #4226
snobrdrkid07
Mr. WJ
Do you have any alignment specs from your last alignment?
-Michael-
For Sale:
Unread 06-13-2012, 08:54 AM   #4227
Larryftmfw
Not sure, the shop charged me 75$ just because it's lifted.... I'm never going back there
Unread 06-13-2012, 09:57 AM   #4228
snobrdrkid07
Mr. WJ
Well there is a place that I have taken the Rubicon too and it was 100 bucks. But they specialize in lifted vehicles and Jeeps. With lifted Jeeps/vehicles I would feel thatd be necessary. But, with my WJ for example, i dont have adjustable caster or adjustable trackbar in, so i still feel a regular alignment shop can handle it.
-Michael-
For Sale:
Unread 06-13-2012, 09:58 AM   #4229
billzcat1
Chicken in a Turkey Suit
2003 WJ
Sounds like the pinion angle was the problem. Alignment shops will set caster with no concern for pinion angle. Voila, driveshaft is toast. Shouldn't need a double-double, those are actually very hard to balance and not get vibes from since each end has so much more free travel than a single joint when combined with a center slip joint.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 06-13-2012, 10:00 AM   #4230
billzcat1
2003 WJ
Most alignment shops won't touch an adjustable track bar. Standard shops will limit themselves to the factory adjustments only. If you need the control arms adjusted for pinion/caster then you need to pre-qualify the shop on whether they do that work.
ome hd , OME lift kit , snobrdrkid , wj
