Snobrdrkid's WJ Build Thread - Page 278 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 06-07-2012, 08:46 AM   #4156
ChrisHager
ChrisHager's Avatar
The only reason shocks would affect lift height is:
1. Your old shocks were at their maximum length and were still compressing your springs.
2. Your new shocks are entirely too long and when fully compressed, they are extending the distance between the axle and body more than what the springs are doing.
If you gained height from these shocks, I would investigate the cause...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 06-07-2012, 09:44 AM   #4157
snobrdrkid07
snobrdrkid07's Avatar
1. Old shocks, when unbolted, didnt cause the jeep to raise up or anything like that.
2. The new shocks are for this amount of lift and have about 3 inches of up-travel left along with 4 or so inches of down-travel
My guess as to why they gave me some more height is because they take so much force to compress that that upward force is taking a little bit of weight of the springs and causing more lift. I had to heave half my weight on them to get them to compress
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-07-2012, 11:04 AM   #4158
billzcat1
Chicken in a Turkey Suit
2003 WJ
Yeah, that's actually normal for Bilsteins. Since they are a high-pressure monotube (and take a good 75lbs+ to compress) they actually do provide more than passive damping. They provide a little additional spring rate to the assembly and improve roll stiffness as well.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 06-07-2012, 11:16 AM   #4159
ChrisHager
ChrisHager's Avatar
Hmm. Makes sense in that aspect! I'm always learning something! Haha
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 06-07-2012, 01:44 PM   #4160
snobrdrkid07
Yup! Very nice to get rid of that bouncy front end!!! So that means I need to get the rear 5100's ASAP to bring the back end back up some. Rear is sitting .5 inch lower. I hope the front will settle in some more and come down from that 3" inch lift height or I might need to think of some other options to get that lower.
The rear springs do take the trailer weight well. Only sag about 5/8 with the unloaded trailer on them. Impressed by that.
-Michael-
Unread 06-07-2012, 02:54 PM   #4161
snobrdrkid07
If these dont tighten up my steering.... Holy crap this stuff is BEEFY
forumrunner_20120607_155124.jpg   forumrunner_20120607_155139.jpg   forumrunner_20120607_155158.jpg   forumrunner_20120607_155245.jpg   forumrunner_20120607_155303.jpg
-Michael-
Unread 06-07-2012, 03:41 PM   #4162
PhantomWJ
2003 WJ
SWEET! That WILL solve some problems...
PhantomWJ is online now   Reply With Quote Quick reply to this message
Unread 06-07-2012, 04:13 PM   #4163
billzcat1
2003 WJ
Nice. Thanks for confirming that they are greaseable.
Unread 06-07-2012, 05:20 PM   #4164
snobrdrkid07
I didnt have any problems with the steering. I could feel the bumps in the steering and i didnt like that. On some of the big bumps I could feel it wobble for a 1/2 second and didnt like that at all. My steering stabilzer is pretty new and aftermarket. Then i figured that the tie rods have 105k on them and are probably getting close to their end. Especially how I drive. So i am hoping that all these new parts will take care of that. If i ever have a lick of death wobble... i am just going to be pissed.
No problem. They fittings arent in obviously but they came with the grease fitting, a new nut and cotter pin.
-Michael-
Unread 06-07-2012, 09:29 PM   #4165
snobrdrkid07
So I get this right the first time. Wanted to double check with you all.
-Michael-
Unread 06-07-2012, 09:31 PM   #4166
compcrasher86
Just so you know (and I've stressed this before), you'll be feeling the bumps a whole lot more with these moog components. You won't get any wobbling or shaking but don't expect to float over bumps. Stiffer steering components means more gets transmitted through the linkage and to your steering wheel. I personally like the extra feedback. You'll get used to it and it feels a lot better.
Also an SS is just there to mask bad components, according to my roommate a steering linkage in perfect condition shouldn't need an SS. That's how I figured out I had bad components to begin with, took off my SS. Wanna experience DW full out uncontrollable? Take your SS off grip your wheel hard and hit a bump at an angle. Okay no don't do that you'll wanna drive your jeep to a used car lot and sell it on the spot lol....
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 06-07-2012, 09:35 PM   #4167
snobrdrkid07
I think they is a difference between feeling the bumps like I did when it was stock height. Compared to now where I feel the bump in the wheel and it wobbles for a split second. That is what I want to get rid off. That half second of wobble oh s*** moment. If I feel the bumps okay not a big deal. Just dont want ANY wobble feelings. Dealt with that enough with the other Jeep. Does that make sense what I said? Feeling the bumps in the steering wheel versus the wobble feeling?
No, I am good, I don't ever want to experience DW in my WJ. Because you are right, it would be going back to stock. That is for sure.
-Michael-
Unread 06-07-2012, 09:42 PM   #4168
billzcat1
2003 WJ
False. On our Jeeps, a steering stabilizer is necessary to prevent death wobble. The track bar/steering geometry can easily develop a resonant motion side-to-side merely on the bushing compliance and suspension travel. Voila, death wobble. This is specific to vehicles with a solid axle, coil springs, and recirculating steering arrangement. The steering stabilizer damps those vibrations and impacts to prevent the resonance from forming. Even stock JKs experience death wobble from undersized components.
Now on an IFS car with rack & pinion, a steering damper is unnecessary. A great many cars are shipped without them, although the driving experience is certainly more pleasant with it installed.
I also agree, heavier (stiffer) steering components give better feedback and the increase in unsprung weight can make a palpable difference in ride. I certainly felt a difference installing the JKS tie rod, even with original TREs.
Unread 06-07-2012, 09:52 PM   #4169
snobrdrkid07
I did not know that it was 100% necessary but that does make sense. Even stock height Jeeps can still get DW.
So what you mean by stiffer is that it gives a more responsive and sportier type steering? Will this new stuff help get rid of that slight wobble that I have on the big bumps?
-Michael-
Unread 06-07-2012, 10:07 PM   #4170
billzcat1
2003 WJ
I wouldn't say sportier. I would say more confident, more direct. The nature of the recirculating box steering arrangement doesn't lend itself to sportiness. I was actually surprised by the change from the JKS TR though. I wasn't expecting a notable difference from just doing the tie rod. It makes you realize how much flex there is in the OEM thin-tube tie rod. The new TREs will probably help more with the wobble than anything else.
Regarding steering stabilizers: I was feeling way too much steering wobble, and bumps were too harsh in the wheel. Hit a bump, have to correct the steering. All the TREs tested out ok by hand and my track bar has maybe 10k on it. Put the Moog STB on it, now it just rolls over bumps like a steamroller. Like the Jeep is flattening out the world. Made a huge difference over the OEM SS.
ome hd , OME lift kit , snobrdrkid , wj
