Snobrdrkid's WJ Build Thread - Page 261 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Cure for your Tie Rod Roll!Steering and more from Ruffstuff!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 05-04-2012, 02:46 PM   #3901
Cowboyup94
"Lash that yard waste down!" BAHAHA Sorry Billzcat but I had to laugh. "Yard waste," why not just say *****?
All this trailor talk I wish I knew the weight of my trailor. Ehh o well.
Hey comp crasher I wanted to say thanks for helping me out for my overheating problem. I should get the relay tonight and have it done tomorrow morning.
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 02:48 PM   #3902
Cowboyup94
Comp: is there anyway to see the relay? Or is it completely hidden? If just take the passenger headlight and decide to do the drilling thing where do I drill?
JEEP
Unread 05-04-2012, 02:56 PM   #3903
billzcat1
Chicken in a Turkey Suit
2003 WJ
Mostly because of the board censoring program. That's exactly what I was thinking, just had to find a JF-friendly way to say it.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 02:57 PM   #3904
Cowboyup94
NVM got the location.. http://www.jeepslimited.com/index.ph...=37&Itemid=127
JEEP
Unread 05-04-2012, 03:04 PM   #3905
snobrdrkid07
snobrdrkid07's Avatar
I think with the upgraded brakes I wont have an issue with what I need to do. Now, I know some rules/limitations to keep it legal too.
Also, I think I may need to check my fan relay as well. Hard to get in there with the mechanical fan being there too. I.E. can't tell if spinning with the mechanical fan going.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 03:10 PM   #3906
Thomahawk
Thomahawk's Avatar
What brakes Are you going for?, i am looking into new brakes myself. Heard great things about the Black magic pads, also s little sceptic to drilled and slottted Rotors, lots of users reports that they Are noise and that you can feel the slotts thrue the pedal. IDK.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 03:26 PM   #3907
snobrdrkid07
I don't know of either of those thing? Apparently with the drilled you get a "woooshhhing" type sound.
I am looking to go for Stillen Drilled front rotors and Stillen Metal Matrix Pads
-Michael-
Unread 05-04-2012, 03:31 PM   #3908
billzcat1
2003 WJ
Yeah, it's sort of a grinding, grabbing feel you get through the pedal and a low-frequency hummmmm you can hear on the brakes. I found that I had pretty awful pad wear with any of the slotted, grooved, drilled, dimpled brakes and I now prefer flat faced. However I have heard nothing but good things about the Kolak Stillen brake package. Since cost is an issue I'll be trying out the Hawk LTS pads. I sold a lot of Hawk pads in the past with good feedback on them and the LTS compound is well-reviewed.
Unread 05-04-2012, 03:36 PM   #3909
snobrdrkid07
Is it annoying or really not that big of a deal? I believe the Stillens are ONLY drilled, no slots, dimples, etc if that makes a difference. I would like to get the Stillens because they have been raved about by so many, like you said. People wouldn't make that up.
-Michael-
Unread 05-04-2012, 03:45 PM   #3910
billzcat1
2003 WJ
Its not bad. It's not as bad as say... squealing or metal-on-metal grinding. More like the sound a bad wheel bearing makes, but softer. A combination of hummmm and wooosh. Hoooossh? There's some onomatopoeia for you! Just something to be aware of.
Unread 05-04-2012, 03:48 PM   #3911
snobrdrkid07
So you WILL hear them from inside when stopping? But only slightly? Onomatopoeia, I still can not spell that word (that is why I am going to be an engineer)
-Michael-
Unread 05-04-2012, 04:18 PM   #3912
billzcat1
2003 WJ
Yes, you will probably hear it a little and feel it in your brake pedal just slightly. Most people who use them either don't notice or don't care enough to change it.
Unread 05-04-2012, 04:52 PM   #3913
Thomahawk
Thomahawk's Avatar
^^^Thanks guys, then i Will go for the wooshy cool stilen Rotors, what pads Are the best to Go with at the stillen Rotors?
Btw, you guys Are great, thumbsup!
Unread 05-04-2012, 04:58 PM   #3914
snobrdrkid07
I can take that trade off for the extra stopping power. I think it'd be worth it. It could sound cool! Just got to finish my Finals, get home and order this stuff!
Kolak offers the Stillen Rotors and the Metal Matrix Pads (by Stillen) as his WJ brake upgrade.
-Michael-
Unread 05-04-2012, 05:33 PM   #3915
billzcat1
2003 WJ
Might as well. The Black Magic pads would be a good choice as well. I'm anxious to try out my Hawk LTS pads which are a bargain at $70/set as opposed to $125+.
ome hd , OME lift kit , snobrdrkid , wj
