Snobrdrkid's WJ Build Thread - Page 250 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 04-16-2012, 11:05 AM   #3736
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Originally Posted by Thomahawk View Post
That look AW!!!
Thinking of doing mine to, great idea...
Assuming you mean Awesome! Haha
I believe this is the color that Jeep used on the Freedom edition. radiant-silver-metallic
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2012, 11:38 AM   #3737
billzcat1
Chicken in a Turkey Suit
2003 WJ
I've seen much worse in terms of paint/photoshop. That looks really good though. The trick is finding a good looking silver paint, most of them look like crap. I'd go and get a spray can of Jeep "Bright Silver" and use that.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2012, 11:42 AM   #3738
snobrdrkid07
Mr. WJ
Hahaha. Thanks!
I got the idea the other day from this post here, then a few posts down he said that he had used the radiant silver metallic. I also looked on WJ Jeeps and the freedom rails are the same. I think a few coats of that should mask the black?
-Michael-
For Sale:
Unread 04-18-2012, 09:22 PM   #3739
snobrdrkid07
Mr. WJ
So finally got my little OBD II dongle to finally pair with my phone (stupid pass code was 6789... WTH, why you no be 1234). So after googling around I was finally able to get that code. Anyways, the point being is that the OBD II is reading the rpms to be ~650 and the gauge is reading ~550. So oddly the Overland Cluster is reading the RPMS about 100 lower then what the ECU is reporting. Which also confirms my suspicion of the gauge reading low at highway speed. Before the swap my stock cluster read 2000 rpms at 65 mph. While the new cluster reads 1900 rpms at 65 mph... dont know why it is doing this. Not a real big deal, but still odd.
-Michael-
For Sale:
Unread 04-18-2012, 11:09 PM   #3740
compcrasher86
I'll check mine this weekend... I have an elm scan interface for a laptop (iPhone + Bluetooth no bueno).
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 04-18-2012, 11:27 PM   #3741
billzcat1
2003 WJ
Just a slightly-misplaced gauge needle. 100rpm is nothing to worry about. Or maybe you got a mystical 5th gear installed with the cluster. We'll never know for sure.
PS: haven't forgotten about the EVIC, just haven't been in the direction of the post office.
Unread 04-19-2012, 12:04 AM   #3742
snobrdrkid07
Mr. WJ
Perfect Opp to totally destroy iPhone. Lol. Anyways that cheapy adapter I had bought def has some quirks. But it still works eventually. I do remember you saying that the iPhone wouldn't pair, I forget why though. Something to do with iPhone's protocols? Im interested to see if your cluster is off too.
While that makes sense. IIRC the first Electro gauges did the same thing, were reading low. But its been awhile now since the initial swap. But like yoy said, it really is not a huge deal, was just curious. I wonder how close 4th and 5th gear had to be to lower the rpms by 100. Haha. Is it even worth trying to "fix"?
Thanks man, no rush. I wont be able to 'use' it until I get home in the beginning of May when I put the other rims on (with the TPMS). I am pretty sure the EVIC wont like it when there are no sensors.
-Michael-
For Sale:
Unread 04-19-2012, 12:10 AM   #3743
billzcat1
2003 WJ
No, you'll just make it worse if you try to fix it.
And it doesn't like it with no sensors, it just gives you two double-beeps every time you start the vehicle. Hence the reason I replaced it.
Unread 04-19-2012, 12:12 AM   #3744
snobrdrkid07
Mr. WJ
I thought so. Honestly id be to afraid to dig into the gauges. To me they seem like they would be very very fragile.
Does it only Beep when you first start? Or also when driving down the road constantly?
-Michael-
For Sale:
Unread 04-19-2012, 12:14 AM   #3745
billzcat1
2003 WJ
Just when you start.
Unread 04-19-2012, 12:22 AM   #3746
snobrdrkid07
Mr. WJ
Oh that is not too bad, I guess if I fill my washer fluid back up, the TPMS beeps can take its place.
Talk about annoying beeps, the freaking LR3, Bimmer, and Benz are all obnoxious. The first 30 seconds of the video says it all:
-Michael-
For Sale:
Unread 04-19-2012, 12:45 AM   #3747
billzcat1
2003 WJ
It's alive and it's going to eat my face.
Unread 04-19-2012, 12:48 AM   #3748
snobrdrkid07
Mr. WJ
Exactly. I think the best part of the clip is, "cheap *** interior."
-Michael-
For Sale:
Unread 04-19-2012, 12:59 AM   #3749
snobrdrkid07
Mr. WJ
Oh my gosh. This is so awesome.
1930's FTW.
-Michael-
For Sale:
Unread 04-19-2012, 10:01 AM   #3750
billzcat1
2003 WJ
Hmmm we have to make a technical video... how do we keep the people's attention? Circus acts!
I suppose this is the most epic of all re-posts too. I mean come on, this is SO 1937.
ome hd , OME lift kit , snobrdrkid , wj
