Snobrdrkid's WJ Build Thread - Page 249 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 04-13-2012, 09:19 PM   #3721
billzcat1
Chicken in a Turkey Suit
2003 WJ
Sorry. I can be a real cake-taker sometimes.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 04-13-2012, 11:07 PM   #3722
compcrasher86
Originally Posted by wyattwj123 View Post
Well why do I need the yoke and the alignment
Yoke because you're getting a new driveshaft with u-joints that wont mesh with the old rzeppa end on the transfer case.
Allignment because you're getting all these adjustable components and someone has to adjust them for you using a professional allignment rack/machine. Factory specs will not work as you've raised the height of the suspension so things like the adjustable arms will need to be adjusted to fix your castor, if you're getting an adjustable track bar it needs to be adjusted to center the axle under the Jeep (as you lift an unadjustable track bar will pull the axle to one side) and you also will need your steering wheel recentered when your drag-link angle changes but the length remains the same so your steering wheel gets off center. Granted you can try your own allignment but best leave it to the pros thats a very essential aspect for not wearing tires fast, getting driveline vibes, and crappy ride. Lastly, your allignment can fall out of spec over time so usually when getting new tires is the generally accepted period to get a new allignment... toe is the most important and improperly adjusted will screw your tires up big time, cause weird wear, have MPG issues, introduce death wobble, etc. Balancing the tires is just a necessity... you cant mount a tire and not balance it and expect to be able to go over 10mph without serious vibes.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2012, 08:20 PM   #3723
Cowboyup94
I recall you stating before that you didn't mind us asking a question here or there, so...
Today I went to the U pull I found rumeraging and sifting through a wj and saw in the cargo area still installed a power outlet that goes into the right side panel. I got the panel off (I just did the wiring for my hitch so I knew the process) and kinda figured the harness would be right there. So a google search later I end up on WJJEEPS and on there they stat every jeep does not have the outlet, but they do indeed have the harness to hook one up in every vehicle.
So after looking NOTHING! has anyone experienced this? Is it just hiding or not ran all the way back to the proper location?
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2012, 08:46 PM   #3724
snobrdrkid07
snobrdrkid07's Avatar
My Jeep did NOT have the rear harness like WJJeeps said. I have a 12v power outlet sitting back there with no wires hooked up to it.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2012, 09:17 PM   #3725
Cowboyup94
Alright thanks Mike. Man this sucks anus! First thing I have found on WJJEEPS not to come out true. This is one of those times Jeep pisses me off!
JEEP
Unread 04-14-2012, 09:18 PM   #3726
snobrdrkid07
No problem man. Maybe I have not torn it apart enough to find it but, I could not see anything that would be the harness.
-Michael-
Unread 04-15-2012, 04:28 PM   #3727
snobrdrkid07
-Michael-
Unread 04-15-2012, 10:37 PM   #3728
billzcat1
2003 WJ
You forgot the "Imawanker2012" coupon code.
Unread 04-15-2012, 10:41 PM   #3729
snobrdrkid07
:P I can sell my Jeep and buy what's on that page. Hahaha. Those axles are some serious money.
I got to sit in a v8 Jeep today, because it was dead and I was helping the guy jump it. I really want a v8 now lol.
-Michael-
Unread 04-15-2012, 10:45 PM   #3730
compcrasher86
^bahahha and you didn't even drive it yet!!
Matt
Unread 04-15-2012, 10:46 PM   #3731
snobrdrkid07
I got to sit in it and feel it run and it was amazing. The adjustable pedals were so sweet too. The Jeep was so trashed though.
-Michael-
Unread 04-16-2012, 02:14 AM   #3732
robd2003
V8 grand is amazing btw I miss mine very much, especially seeing it here and there
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2012, 10:43 AM   #3733
snobrdrkid07
Oh man, that has to be tough seeing it around. =/
-Michael-
Unread 04-16-2012, 11:32 AM   #3734
snobrdrkid07
Aside from the terrible MS paint skills. I want to make my roof rails silver. Thoughts? I kinda like the blue/silver accents.
edit: oops need to attach picture! Durr!
-Michael-
Unread 04-16-2012, 11:46 AM   #3735
Thomahawk
Thomahawk's Avatar
That look AW!!!
Thinking of doing mine to, great idea...
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
