Snobrdrkid's WJ Build Thread - Page 244 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 04-08-2012, 09:08 PM   #3646
snobrdrkid07
snobrdrkid07's Avatar
I was using my torque wrench on my shock bolts... I was using a SAE? (not metric) socket on them, so it was not an exact fit (Did not have any 1/2 drive metric sockets, and lowes was out of 1/2 to 3/8 drive adapters today). So it tore up the socket but did not do any damage on the bolt...
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2012, 09:52 PM   #3647
robd2003
Ah okay, im used to just seeing one fan. My 03 I had came with the hydaulic drivin fan which was tits at cooling it down. Sounded like jumbo jet. Ha, and our 02 that we have now only has the Efan. But i also dont have the tow package either.
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2012, 09:53 PM   #3648
snobrdrkid07
Hahaha, I am sure it is just as loud as the mechanical fan is! But I like having both if the e-fan were to die on me.
-Michael-
Unread 04-08-2012, 09:58 PM   #3649
robd2003
Yeah my efan died out of town when we went to eat. let it sit a few days after we limped it home, tore apart the front end and diagnosed everything, threw it back together and no problems. This was in a 30min time span
Jeeps:
Unread 04-08-2012, 10:15 PM   #3650
snobrdrkid07
The 4.0 is much more forgiving with an overheat. I had mine start creeping past 210 on the beach when I was pushing hard. At the time my mechanical fan clutch was dead and the e-fan was not able to keep up.
-Michael-
Unread 04-08-2012, 10:16 PM   #3651
compcrasher86
ahhh, thats another +1 for the V8 WJs... Hydraulic fan, that thing is a beast!!! I want
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2012, 10:17 PM   #3652
snobrdrkid07
This is a -1 for the v8... less forgiving then an overheat. But my mechanical and e-fan do the job.
-Michael-
Unread 04-08-2012, 10:24 PM   #3653
compcrasher86
-1 for the i6 for having a crappy e-fan relay design that will just fail without warning and allow for overheat. And I wouldnt want to overheat my i6 in any circumstance simply because I do not trust the 0331 head just as much as I dont trust the alluminum 4.7 heads. I do agree the overheat with the v8 thing is a big nono but if everything is maintained and you're not doing something horribly wrong... there shouldnt be any overheating.
Matt
Unread 04-08-2012, 10:27 PM   #3654
snobrdrkid07
While I will agree about the e-fan being crap haha. Like I said, when my mechanical fan clutch was dead, the e-fan could not keep up on the beach. Granted it was 95 degrees, AC blasting, and my foot down hard on the beach.
Eww I forgot, the 2001's with that crappy cast...
I will also agree, there should not be a reason for overheating unless something is wrong with it. Under normal conditions you should be fine with the 4.7
-Michael-
Unread 04-08-2012, 10:28 PM   #3655
robd2003
I overheated the 4.7once with no problems afterwards to my surprise, guess luck of the draw
Jeeps:
Unread 04-08-2012, 10:28 PM   #3656
snobrdrkid07
It probably depends on the severity and duration...
-Michael-
Unread 04-09-2012, 02:20 AM   #3657
robd2003
True.
Tonight I managed to install the addcco rear sway bar from my first jeep.
It handles amazingly on highway and off ramps
Jeeps:
Unread 04-09-2012, 02:43 AM   #3658
compcrasher86
robd what are your suspension mods... she sure doesnt look stock from your avatar but your sig and Jeep info say otherwise. I'm curious because I was always interested in the addco but was nervous of adding it to a lifted Jeep. I know it stiffens the feel out alot but I'm not sure if... on a lifted Jeep with higher center of gravity... this puts it at a higher risk of lifting a tire and possibly flipping. With my OME's I've tested I can still... in normal conditions.... lose traction without getting near that "ohhh shhhhh we're going over" point
Matt
Unread 04-09-2012, 08:29 AM   #3659
robd2003
My avatar was my 03 V8 I had, it was lifted 4" with rc-x components, and 265/70R17 m/t's which measured almost 33's. It handled a lot better on highway, but off road really did limit about 3 inches of flex, when I get a chance this week ill take a pic of stock jeep flex on my log without swaybar and with sway bar so you see the difference.
I never once felt tippy offroad with it either.
Jeeps:
Unread 04-09-2012, 08:54 AM   #3660
compcrasher86
Awesome... How was that bar on the road while lifted? Michael I know this is in your build thread but it's relevant because you're going to be gettin one of these inevitably
Matt
ome hd , OME lift kit , snobrdrkid , wj
