Snobrdrkid's WJ Build Thread - Page 235 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 03-24-2012, 04:16 PM   #3511
snobrdrkid07
snobrdrkid07's Avatar
Matt!!! Thanks for the awesome instructions and pictures! This shouldn't be all that hard now! From what it looks like the "bottom" silver cable is the return line. Then the outer silver line that leads to the radiator. Also good point about having the fluid pushing the air "out" the to of the cooler. Secondly does it matter which way the oil flows inside the aux cooler? One inlet and one designated outlet?
Jerzey- I do have a cooler for the transmission already, just adding the auxiliary cooler. Jeep had deemed the stock cooler to be "good enough" for normal use. But not for me!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 03-24-2012, 04:16 PM   #3512
compcrasher86
Originally Posted by JerzeyBoyWJ View Post
dont you have the towing package? ..i thought the towing package come with an oil cooler ...if not you got jipped!!!!
the 04s they decided it didnt "need" one... I call BS on their decision
and michael.... no it doesnt matter which direction it flows in the aftermarket cooler
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2012, 06:24 PM   #3513
JerzeyBoyWJ
2003 WJ
got the clay bar kit today from walmart ...got 10% off cause my buddy works there and he rang me up ...my jeeps paint is so SMOOTH now ,thanks!!!
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 03-26-2012, 07:49 PM   #3514
snobrdrkid07
bro that is great! it takes a lot of effort but the end results are awesome!
My Jeep is so dirty right now and it makes me sad!
-Michael-
Unread 03-26-2012, 10:23 PM   #3515
snobrdrkid07
Hey everyone, calling in a favor. (Forgive me in advance if I can't do this) but our Jeep club at VT is in a contest for best picture and the prize is 500 bucks. All you have to do is like the photo on facebook! Here is the link Thank you guys!
-Michael-
Unread 03-27-2012, 09:13 PM   #3516
snobrdrkid07
Matt and I have been talking about aftermarket exhausts. We were getting mixed results on the cat diameter size. Some said 2.25 and some said 2.5 inches. So I went out and measured mine today. On my Jeep, my Cat is 2.5 inlet and 2.5 outlet. My Muffler is 2.5 in and 2.25 out. I used some string to get the circumference and then found the diameter. So wa-la.
-Michael-
Unread 03-27-2012, 09:43 PM   #3517
compcrasher86
Yeah mines 2.25in to the cat 2.5 outdo I'll have to get a Magnaflow cat
Matt
Unread 03-27-2012, 09:45 PM   #3518
snobrdrkid07
Did you say that backwards?
-Michael-
Unread 03-27-2012, 10:00 PM   #3519
compcrasher86
Why yes... Yes I did LOL
Matt
Unread 03-27-2012, 10:03 PM   #3520
snobrdrkid07
Ah okay, was just x2 checking. Ha. Well at least you will get a "hi-flow" cat.
Any ideas on the muffler you want or looking at? I am probably just going to save the cash and pick up a 2.5 inch v8 tail pipe. that is all the I6 needs is a 2.5 through out the whole setup.
-Michael-
Unread 03-27-2012, 10:59 PM   #3521
JerzeyBoyWJ
2003 WJ
http://www.ironrockoffroad.com/Merch...egory_Code=WPA
Unread 03-28-2012, 12:39 AM   #3522
snobrdrkid07
I need a muffler and v8 tail pipe off of another grand. That should run me less then that... hopefully.
That pipe looked kinda lame. I like the 3 inch tip of the v8 grand exhaust.
-Michael-
Unread 03-28-2012, 12:42 AM   #3523
billzcat1
Chicken in a Turkey Suit
2003 WJ
But it'll lower your 1/4 mile from 17.62 to 17.14 seconds!!
I tell you what, if they are getting 17 second quarter-miles out of a 4.7 HO they are doing something wrong.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2012, 12:46 AM   #3524
billzcat1
2003 WJ
Clay bar-ing a Jeep, minus 10 points.
Unread 03-28-2012, 12:46 AM   #3525
snobrdrkid07
Uh ohhh! I have been caught reverting back to wanting of "wwooooshhhh" intake sound and "vrrrrooooommmmmmmmm" engine sound.
Looking to get a mild muffler and pair it with v8 pipe for dirt out of a junkyard. Don't think that would be a bad idea.
What is 1/4 miles supposed to be?
I am pretty sure that I am in the hole big time with the WJ. But the Rubicon has lots of "good" points!
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
