Snobrdrkid's WJ Build Thread - Page 234 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-23-2012, 06:02 PM   #3496
snobrdrkid07
snobrdrkid07's Avatar
Well had 5 people and going through the mountains and got to the restaurant and smelled something burning. Probably the transmission.
Edit: I we drove another 50 miles after I smelled it, We were on the highway. When we got to our next destination didn't smell anything. Went and checked the transmission fluid it was about 65-70% up from between the two "hot" dots. So fluid level was good. (Yea I had the engine running and in neutral). The fluid wasn't burnt and it was still nice and red. So I guess it will be fine.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 03-24-2012, 12:13 AM   #3497
billzcat1
Chicken in a Turkey Suit
2003 WJ
Check around your rear diff. During some long, heavily loaded trips I will get a little seepage from the rear diff at the pinion and right side axle seal. Stuff gets everywhere. Then it doesn't leak again for 6 months. But the gear oil sure smells awful. Hopefully its something benign like that.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 03-24-2012, 01:07 AM   #3498
snobrdrkid07
I just had my rear axle seals replaced. Would hope that isn't it! Will check the diff at the pinion as you suggested.
When I checked the fluid (transmission fluid) it seemed fine. For a color reference of what I saw. Refer to this here and my fluid color was the color of the first swatch of the "new fluid" if not slightly darker. But I would not consider it anywhere near the second color swatch. Are there supposed to be bubbles in the fluid? There were some tiny bubbles coming up on the dipstick when I was check the fluid level.
EDIT: Spent the last 90 minutes reading up on Transmission coolers. The FSM Claims that an Aux cooler is not needed. "DESCRIPTION: An internal high capacity/high efficiency cooler is used on all vehicles these coolers are an oil-to-coolant type which consists of plates mounted in the radiator outlet tank (Fig. 31). Because the internal oil cooler is so efficient, no auxiliary oil cooler is offered The cooler is not servicable seperatly from the radiator."
Yeah "So efficient"..... Also, what do they mean by oil-to-coolant???
-Michael-
Unread 03-24-2012, 11:21 AM   #3499
compcrasher86
I trust the FSM but their cooler is meant for whatever they define as normal use. Towing more than the rated capacity, or going up and down rough terrain, or even wheelin it, all break that normal use rating. Id still be looking at an aux cooler. Also with ATF+4 the color of the fluid is no longer a proper indication of the condition of the fluid, so the ol' mechanics tricks fail here. What can happen is the fluid can get hot enough to degrade its lubricative properties before it gets hot enough to burn the color of the red dye, which yes in ATF4 it's just a dye that makes it red.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 03-24-2012, 11:33 AM   #3500
snobrdrkid07
Well darn. It looks like I really need to look for aux cooler, seriously this time after this happened. I've been looking at them on etrailer.com. They seem to be pretty decent. Ill post a link shortly to what I was looking at. Also ill have you look at it and see if I need any more parts too. This is the aux cooler I was looking at getting http://www.etrailer.com/Transmission...eid=2004753758
Crap on the trans fluid color. Aside from the guys in my club id have to take it to a dealer for a fluid/filter change.
-Michael-
Unread 03-24-2012, 12:33 PM   #3501
compcrasher86
That'd be perfectly adequate, in fact the one I installed was the smaller $40 autozone one and I couldn't be happier with it. Definitely stick with that style plate and fin cooler though they're nice. I don't know how applicable my little pic tutorial will be for you but as you can tell it only took me a short while to figure out how to do mine
Matt
Unread 03-24-2012, 12:38 PM   #3502
snobrdrkid07
I am going to be towing literally every other day over the summer so this is probably a good investment. I am going to go order it. Did you need any extra fittings with yours? Think I need a bigger one or will that be fine? Did you need any other parts??
I am going to order:
Cooler
Barbs 1
Barbs 2 Do I need these?
From what I have been reading the oil "progression" will be: Hot oil from Trans, OEM Cooler, OEM Cooler out, to the Aux cooler, then back to the Trans. Shouldn't be too hard. I guess it is just adding an extension to the one line.
-Michael-
Unread 03-24-2012, 01:13 PM   #3503
compcrasher86
Yupp that looks like just about what you need. I'm not sure if the fittings are necessary because your tranny cooler line setup could be different than mine. Check out my pics from the install and check in the same spot under your Jeep next to the oil pan to see if it looks the same. Take a pic maybe. If it does then follow my tutorial exactly and skip the extra fittings. You will probably need another 5-6 ft of tranny cooler hose which you can grab at your local auto parts store just bring the same hose that comes with your cooler and be like "I want more of THIS"
Matt
Unread 03-24-2012, 01:21 PM   #3504
snobrdrkid07
I will get under there today at some point and check out the fittings and the lines and take some pictures. Which side is it going to be one. The driver's or the passenger side? So you did or did not need those set of barbs? From what it looked like on what you did, you just cut the rubber hose and put the trans cooler in at that point.
-Michael-
Unread 03-24-2012, 01:36 PM   #3505
compcrasher86
It's going to be in the drivers side, or at least it was on mine... On mine I found a point where two hard lines were connected by this piece of soft line and just completely removed the soft line, no cutting involved. Then I reused the barbs that were already on there from the factory for this soft line. So I basically "interrupted" this return line from the factory trans cooler with my aftermarket tranny cooler. More specifically the end coming from the factory cooler output went to the aftermarket cooler input then the output from the aftermarket cooler goes to the return line to the Trans (other end of the line I removed that goes back into the Trans)
Matt
Unread 03-24-2012, 01:47 PM   #3506
snobrdrkid07
So for you that was actually pretty simple. With no cutting and no barbs. So is there a "factory" metal line coming out of the factory trans cooler, so you basically just stuck the rubber hose on it with a hose clamp. So then you did not have to use ANY of the little barbs? That would be really nice if mine is like that because not having to spend the extra money, and I am good with just putting a rubber hose on a metal line? Gonna go take some pictures!
-Michael-
Unread 03-24-2012, 02:30 PM   #3507
snobrdrkid07
Okay guys this is what I found: (Matt, it seems to be the same setup as yours)
Lines coming from by the oil pan
those two lines meet these two at the bottom of the radiator
Next: this is where it appears the trans oil lines connect to the AC CONDENSER on the drivers side
Here is what looks to be the AC Lines that connect to the AC condenser on the passenger side
Then, slightly unrelated, I opened the trunk and got a shower of water from where that little wire is sticking out on the trunk hatch. that is the defroster power line. Came form inside the trim too... really odd
-Michael-
Unread 03-24-2012, 03:31 PM   #3508
snobrdrkid07
Well I went ahead an ordered the transmission cooler. Bought this one here Dorale 8000 Series Yay actually bought something for the Jeep other then gas!
Start posting up some tips! Which line is the "cooler" return line... assuming that is going to be determined by which one feels cooler. Then how to secure it to the other radiators.
-Michael-
Unread 03-24-2012, 04:03 PM   #3509
compcrasher86
I updated some of my pics to help you out....
-Get a drip tray underneath (wont be much that comes out) and slide the hose clamps off the barb underneath and pull this line. Tips: its gunna be stuck on there like hell so grabbing the ends with pliers and twisting them around a bit will help. I did that and used a flathead screwdriver and a lot of elbow grease and twisting to get em off. I guess if you have no remorse you could also just cut it off but then theres no turning back
(editing pic)
-Get your two pieces of hoses attached to the cooler outside the Jeep, tighten the hose clamps nice and tight
-Take off your grille, a couple hex screws on top and a couple in the slats
-You will probably need to "modify" your header panel to slip the cooler in there... honestly I didnt see the header panel grille slats as all needing to be perfectly strong and intact so with some big clippers I just snipped through one of the plastic supports and bent it outta the way while I slipped the cooler in. This pic shows where I ziptied the cooler to. I routed the hoses through a convenient little hole in the rubber fin (next to the radiator) towards the airbox
Then after thats all secure route the lines down towards the factory ones. For me I went over and in front of the steering box. If you decide to do this throw wire loom over the hose anywhere where it has the potential to chafe. Make sure moving parts wont hit it, etc etc.
Then use some more hose clamps (should be included with the kit) to hook up right to these lines. Trim any excess line you may have but make sure its not too tight and pulling too much on the lines.
(editing pic)
Its notable that I designated the top line coming out of the aftermarket cooler as my "output" and the bottom as "input" so any air bubbles get pushed up and out. Theoretically its not "bad" if you mixed them up but might as well do em like this. Now make sure everything is good and tight start up the Jeep in Neutral with the ebrake set and watch for leaks. After a couple minutes throw your grill back on and go for a test drive. Come back and check the tranny fluid and add as necessary.
Matt
Unread 03-24-2012, 04:09 PM   #3510
JerzeyBoyWJ
2003 WJ
dont you have the towing package? ..i thought the towing package come with an oil cooler ...if not you got jipped!!!!
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
