Snobrdrkid's WJ Build Thread - Page 225 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineGibson WK HEMI 3" Catback - 5 Day Special!The ULTIMATE "Selectable" Locker System! Brough
Unread 03-10-2012, 09:30 AM   #3361
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Originally Posted by 99WJdan View Post
Its not really rebuilding, more of replacing the wear and tear parts. I would just replace the piston rings, bearings, valve seals, and pick up a complete engine gasket kit. Maybe the lifters if they were tapping. Then have a machine shop do a valve job, weigh the pistons, and check clearances. Probably resurface the head and cylinders if they're bad. After all of that its practically a new engine. Removing the engine is easy as long as you label everything. It just takes time and patience if you have the right tools. Then you put everything back together and hope that it starts up again haha. I rather remove the engine then mess around with the differential. I hate messing with those clearances with the ring and pinion.
Okay I got ya there. Hah my 4.0 loves to tap on cold starts, but everyone says that is okay for the 4.0. Ziplock bags and a sharpie are a must for an engine rebuild! Maybe if down the road I will have my 4.0 rebuilt (with the intent of making it a 4.6 engine) and then rebuild and then beef up the 42re turd behind it.
Yeah the ring and pinions can be a bit** if you don't do that right!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 03-10-2012, 09:43 AM   #3362
99WJdan
Yeah I have slight tap too. Its actually covered up now by a bad pulley somewhere, pretty sure its the tensioner. I should have known to replace that when I did the water pump in August. If/once I do decided to rebuild the diff Im just going to give it to my local off road shop. Ever since converting the front diff to a u-joint Ive been worried about it. A song came on the other day while driving that sounded like a high pitch wine that got louder and louder. Scared me half to death haha.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 03-10-2012, 09:47 AM   #3363
snobrdrkid07
Mr. WJ
Tapping in the 4.7 isnt good. Lol. I tell you what though, my 4.0 sounds like a diesel engine when it is idling. I do not know if it good or bad but sure enough. Got a little tractor engine going on in there!
You think when you broke and torqued the new u-joint that could have messed it up somehow? Do you have quadra-drive?
-Michael-
Unread 03-10-2012, 09:53 AM   #3364
99WJdan
No I have quadra-tec II. I know I did it right I'm just paranoid when it comes to stuff like that haha. Plus with the high miles I have on it and being away at college I'm paranoid something big will break haha.
Unread 03-10-2012, 10:06 AM   #3365
snobrdrkid07
Mr. WJ
Oh ok. Can you chirp tires when flooring it off the line??
How many miles are you at? Same here if something breaks at college I am kinda stuck but the guys in my off road club are very very handy and there is always a stealership close by.
-Michael-
Unread 03-10-2012, 11:03 AM   #3366
snobrdrkid07
Mr. WJ
Okay I am getting disappointed with my WJ. I am still timing 0-60 at around the middle 10's. Which is pretty crappy. I have been looking at some other 4.0 WJ's and they are getting middle 9's which is a whole second faster. Which I think is a good amount. Comparing my videos to others, it seems that my upper end of first gear is lagging where others are moving quicker.
I am about to rip out my exhaust and intake...
I timed this guy at around 8.1-8.2 seconds! Dayum!
-Michael-
Unread 03-10-2012, 11:14 AM   #3367
compcrasher86
You can't time a YouTube video... Honestly the rated 9.6 or so that the wj does is optimized no passengers or weight in willing to bet you have at least 300lbs of audio equipment which will do it alone also aren't ur tires slightly bigger than stock? Regardless they're ATs which oughta have slightly more rolling resistance than the all seasons these things get tested with
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 03-10-2012, 11:18 AM   #3368
snobrdrkid07
Mr. WJ
I have been using a stop watch to time the video. Letting them play and clicking start/stop on the app accordingly. But I agree you can not use the little bar and expect an accurate result from that.
The tires are 245/70/16 which is the size that came on it from the factory. But I have A/T's on it now which have a bit more meat on them.
Then audio, gas, and another person, then all my Jeep cleaning liquids probably aren't helping.
-Michael-
Unread 03-10-2012, 02:01 PM   #3369
compcrasher86
yeah, like the rated 9.5 or so you'll see on wjjeeps involves a light weight laredo without any extras and one normal weighted person and just enough gas to let it run. The engine is fresh and new and is making all of its rated power. no doubt after 100k miles your i6 isnt in its prime anymore. Then add a couple hundred pounds of your audio equipment and a couple hundred for two people and you could easily be seeing low to mid 10s.... jeesh I dont even want to know what mine is....
oh and that 8 second guy has somethin up with his video... he goes around to everyones i6 videos and flaunts his Jeep so I'm thinkin he's fishy. I also hear a weird whine at 3krpm... the intake should not be whining that soon but I'm not accusing it of being boosted or anything its Just something on that engine isnt stock
Matt
Unread 03-10-2012, 02:09 PM   #3370
snobrdrkid07
Mr. WJ
Maybe over the summer I will strip it out and put just enough gas in there and see how it does. Along with my upcoming mods for more power :P My goal is to get it into the High 8's
Yeah that is the truth, sadly she isn't as powerful or fuel efficient as she was new! My step-mom got 26 mpg out of it back in 2005 or 2006 coming home from a PA trip. It was just her and a bag or 2. Got great MPG. Now I am struggling to get 21-22 on the highway. Makes me sad to see her get old!!
So for all reasonableness. 2 people (220 + 170) and ~300 for audio (those voice coils are heavy and the box and amps) 1/2 tank of gas. A/T Tires. Then 100K miles. I guess mid 10's are not all that bad in reality. So that is 700 pounds over curb weight (I do not remember what all is included in curb weight, gas or no?)
-Michael-
Unread 03-10-2012, 02:12 PM   #3371
JerzeyBoyWJ
2003 WJ
just cut off your muffler hahah adds 20hp
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 03-10-2012, 02:14 PM   #3372
snobrdrkid07
Mr. WJ
Don't tell me that. I was fighting all day to not get out my sawzall and cutting it all from cat back.
-Michael-
Unread 03-10-2012, 02:17 PM   #3373
compcrasher86
lack of backpressure on the 4.0... will that cause an issue?
Matt
Unread 03-10-2012, 02:18 PM   #3374
snobrdrkid07
Mr. WJ
We are about to find out...
-Michael-
Unread 03-10-2012, 02:22 PM   #3375
JerzeyBoyWJ
2003 WJ
ome hd , OME lift kit , snobrdrkid , wj
