Snobrdrkid's WJ Build Thread - Page 217 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-04-2012, 04:51 PM   #3241
compcrasher86
I think my shocks are doin the same exact thing and they are my prime suspects
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2012, 05:21 PM   #3242
snobrdrkid07
snobrdrkid07's Avatar
So that kind of play will cause road noise and clunks?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2012, 05:23 PM   #3243
snobrdrkid07
I almost look like an 04 special edition.
Too bad that one was beat to crap!
-Michael-
Unread 03-04-2012, 06:15 PM   #3244
99WJdan
Yeah that will make a ton of noise while driving. My tb adjusting nut was loose and it made a pop/click/vibrate when tuning an highway driving.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 03-04-2012, 06:34 PM   #3245
snobrdrkid07
Ah wonderful. At least I can say that I tracked down the problem...
-Michael-
Unread 03-04-2012, 06:45 PM   #3246
99WJdan
Now you have a reason to get a lift haha. Thats how I got my lift past my parents.
Unread 03-04-2012, 06:51 PM   #3247
snobrdrkid07
Needing bar pin eliminators = needing lift? haha
-Michael-
Unread 03-04-2012, 06:55 PM   #3248
99WJdan
Haha might as well do it all right?
Unread 03-04-2012, 06:57 PM   #3249
snobrdrkid07
I still need some shocks for a 2 to 3 inch lift. But the BPE's give a little bit more down travel to at least compensate a 1/2 inch of lift ha!
-Michael-
Unread 03-04-2012, 07:11 PM   #3250
99WJdan
Haha yeah man. With my Bilstiens i dont need bpe. You could get those and save some money. I think mine are for 0-3" lift? So you could do springs later. Just an idea
Unread 03-04-2012, 07:16 PM   #3251
snobrdrkid07
I have my OME HD "B" Springs and a JKS Track bar that I got both all new for 250.
If that is true about those Bilstiens, that would be really really sweet.
I am thinking that I am going to net right around 2-2.5 inches with my OME HD's and I can squeeze that out with my stock shocks hopefully for a little while.
-Michael-
Unread 03-04-2012, 07:20 PM   #3252
99WJdan
Talk to kolak about the bilstiens but im pretty sure mine are for like a 0-2 lift because i asked him about them with my hd springs and he said its ok because there actually longer. Its like 310 for them. And thats a good deal on springs/ tb
You should be fine on stock shocks as long as you dont wheel it.
Unread 03-04-2012, 07:23 PM   #3253
snobrdrkid07
Talk to kolak about the bilstiens but im pretty sure mine are for like a 0-2 lift because i asked him about them with my hd springs and he said its ok because there actually longer. Its like 310 for them. And thats a good deal on springs/ tb.
I will have to give him a shout. I was hoping to run just the springs and get away with waiting until the summer to do the shocks.
Thanks, I got them from a JF Member who wanted all the "A" springs on the OME HD's and he didnt need the track bar so he helped me out.
-Michael-
Unread 03-04-2012, 07:28 PM   #3254
99WJdan
Just make sure that nut on the tb is tight. It backed off 2 times on me and made noise. I used loctite this time.
Unread 03-04-2012, 07:30 PM   #3255
snobrdrkid07
I actually didnt even plan on using the JKS at the moment.
I am bring the springs back up with me after spring break. I am then going to put the springs on and see where they net me in lift.
Then depending on the ride, I may have to take them off until I get shocks for them.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
