Snobrdrkid's WJ Build Thread - Page 211 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 02-22-2012, 12:53 PM   #3151
compcrasher86
How do you figure that? Stock specs are 190/210? Don't think the superchips could add more than 10hp. You're right too most of my hatred is in the 42re and I disguise it by blaming the other components. My 4.0 itself has been nothing but a pleasure as far as maintenance goes. Seems to be loving the Rotella oil. It doesn't sound like a diesel anymore on start up now that I've finally fed it turbo diesel oil... Go figure, Jeep has an attitude
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 02-22-2012, 12:57 PM   #3152
snobrdrkid07
snobrdrkid07's Avatar
Stock is 195 hp and 230 ft pounds at its peak.
Superchips adds 25 hp and 25-28 torque
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 02-22-2012, 12:58 PM   #3153
compcrasher86
Jeeeeeezusssss I gotta get me one of them. Ever figure that's why ur mileage is suffering lol? If my WJ can hold OD on the highway with 33s I promise I'll shut my mouth about it lol. I'm thinking shift kit this summer cus it's cheap
Matt
Unread 02-22-2012, 01:03 PM   #3154
snobrdrkid07
Then when I add a K&N CAI and then a new exhaust that will really make the superchips come out and play. Superchips also refines the transmission. So they say. Haha
Mpg is probably my driving more or less, because its either heavy stop and floor city or really moving the brick fast on the highway. I don't ever get to cruise at 55 or 60 on flat ground haha. (Which I can get 24 mpg out of that)
-Michael-
Unread 02-23-2012, 04:24 PM   #3155
snobrdrkid07
There are double cardon drive shafts at a local yard for 75 bucks. I want to get one. Cause I know I am going to blow out my rzeppa joint when I put the springs on. Probably could find a yoke there too.
Was reading the WJ F&Q's and it said that the rear shock bolts need to be torqued to 85 ft-lbs... So I need to go redo those. I am getting some clunking in the rear again. Tightening the shock bolts fixed it, but I guess I did not get them tight enough the first time.
-Michael-
Unread 02-24-2012, 07:00 AM   #3156
compcrasher86
I put upwards of 100ft lbs on em... Don't think they were the culprit though. Are you running BPEs in the front? I found out my noise was actually coming from the front. Go figure huh
Matt
Unread 02-24-2012, 10:46 AM   #3157
snobrdrkid07
Holy **** that is alot of torque. I think I am going to run them with some washers in the rear to help compress the bushings. What size are the bolts?
I am not running BPE's. Also im 90% sure I have clucks in the rear and in the front. But the rear is more noticeable and more frequent.
-Michael-
Unread 02-24-2012, 11:00 AM   #3158
compcrasher86
Yeah I don't like loose components. Never will thou find a loose component on my front end it's the little things that prevent DW. I still feel like its looming on the horizon hence why I'm upgrading a bunch of stuff and doing all the ball joints this summer. I oughta look at getting a torque wrench eventually. I'm on a campus bus right now that's DW'ing and it sucks
I have no clue what size the rear bolts are I just remember they take a 15mm socket.
I thought my clunks were completely from the rear till I rocked the jeep from outside and then realized they were coming from the front have a buddy rock the jeep by the roof rails while you walk around looking for the noise/play.
Matt
Unread 02-24-2012, 11:04 AM   #3159
snobrdrkid07
Nope they are never good when things are loose. I have my front end looked at frequently and it is all in good shape. For now at least. Haha, DW bus, sounds like a blast.
Hmmm. Ill Google around.
I think my rear may be the shocks for sure, but also the a -arm or just the shocks. Don't know yet. Hoping its just the shocks. Roof rails are not a good place to rock the jeep on. I've ripped one out before (well dad did) and we had to like silicone or expoxy the bolt back in there. They are lose enough as it is.
-Michael-
Unread 02-24-2012, 01:21 PM   #3160
compcrasher86
Guess they had budget cuts in the later years haha mine feel like they're "bolted to the frame" lol
Matt
Unread 02-24-2012, 02:00 PM   #3161
snobrdrkid07
Stupid roof rails. Your rails don't move at all when you put pressure on them?
-Michael-
Unread 02-24-2012, 09:22 PM   #3162
snobrdrkid07
Yay!
-Michael-
Unread 02-24-2012, 09:52 PM   #3163
Cowboyup94
Originally Posted by snobrdrkid07 View Post
Yay!
do you really like the mud flaps?
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2012, 09:58 PM   #3164
snobrdrkid07
Everyone be hating on the mud flaps! Haha
-Michael-
Unread 02-24-2012, 10:30 PM   #3165
alwaysHI
2003 WJ
thats the dirtiest i've ever seen your WJ...haha. looks like someone had a blast ah!
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/ - SOLD
alwaysHI is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
