Snobrdrkid's WJ Build Thread - Page 208 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 02-14-2012, 10:26 PM   #3106
snobrdrkid07
snobrdrkid07's Avatar
So what exactly is a "carrier break" in the differential?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2012, 10:40 PM   #3107
compcrasher86
^belong in Project Yeti thread?
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2012, 10:40 PM   #3108
snobrdrkid07
Am I not aloud to have a technical question?
-Michael-
Unread 02-14-2012, 10:44 PM   #3109
compcrasher86
lol no but I saw them just talking about carrier breaks over there and everything so I thought maybe you accidentally posted in the wrong thread I have no clue what a carrier break is lol
Matt
Unread 02-14-2012, 10:46 PM   #3110
snobrdrkid07
Link? haha
I was browsing around and looking at re-gearing stuff. Was wonder about what exactly that was. From what I have looked at, once you hit a certain ratio, you need another carrier??
-Michael-
Unread 02-14-2012, 10:48 PM   #3111
compcrasher86
literally they just mentioned it so I figured it was too close of a coincidence lol http://www.jeepforum.com/forum/f197/...l#post13054518
Matt
Unread 02-14-2012, 10:50 PM   #3112
snobrdrkid07
LOL that is great. Apparently there is not a carrier break on the 44a... Man I should google this... hahaha
Googled:
Facts from dana/jeep that I(we) put togeather for the jeepwiki:
Dana 30:
Gearing options: 3.07, 3.31, 3.54 Carrier break 3.73, 4.10, 4.56, 4.88
http://www.jeepforum.com/wiki/index.php/Dana_30
Dana 35:
Gearing options: 3.07, 3.31, Carrier break 3.55, 3.73, 4.10, 4.56, 4.88
http://www.jeepforum.com/wiki/index.php/Dana_35
-Michael-
Unread 02-15-2012, 12:45 AM   #3113
snobrdrkid07
To do List
As stated, would copy Matt.
As the list goes down, the probability of it happening decreases (for the most part, started to lose track)
  • Get the Remote Start put in, (spring break)
  • Install the OME HD's (or at least bring them back to VT with me)
  • New Brake Rotors and Pads (saving that for summer, have enough left to be safe)
  • CB Radio Setup (maybe through the semester, depends on $$)
  • Heated Mirrors (would be a 50 dollar invest from eBay)
  • Get Bilstiens
  • Motor Mounts
  • Rear A-Arm
  • Tie Rod Ends
  • Transmission mount
  • Dynamat EVERYTHING
  • Check the A/C Drain, has leaked before
  • Fix the Sunroof (FML)
  • Fix the Power seat motor (again, FML)
  • Leather Seat Swap
  • Buy Tires for the Rouge Chromes
  • Quadra-Drive Axles
  • Buy an Overland (yeah if only)
Will add more as I think of it. That is probably most though.
There is not too much on maintenance because all of this was done with in 15k miles ago
  • Spark Plugs
  • Fuel Filter
  • Transmission Fluid
  • Differential Fluid (just done)
  • Transfer Case fluid
  • Power steering is clean
  • Brake fluid is clean
  • Coolant was good
-Michael-
Unread 02-15-2012, 08:35 PM   #3114
snobrdrkid07
Going to need to get a relay harness for the fog lights... Ughhhh
-Michael-
Unread 02-15-2012, 09:03 PM   #3115
Cowboyup94
  • Get Bilstiens
  • Motor Mounts
  • Rear A-Arm
  • Tie Rod Ends
  • Leather Seat Swap
  • Spark Plugs
  • Fuel Filter
  • Coolant was good
Why a CB? Do you think your a trucker? I see everyone putting them in. For all the hassle, if your on a trail why not just use a walkie talkie? No affence but do you even hit any trails hard enough to need one? (I know I don't )
Cowboyup94 is offline   Reply With Quote Quick reply to this message
Unread 02-15-2012, 09:06 PM   #3116
Cowboyup94
Car/degreasers always work the best for everything!
I disagree. But it's cool brah.
Unread 02-15-2012, 09:08 PM   #3117
snobrdrkid07
I like having a CB. Speaking of truckers, during trips I will have mine on and listen in for any updates on traffic or weather that they talk about.
I use it on a lot haha.
-Michael-
Unread 02-15-2012, 09:21 PM   #3118
compcrasher86
CB is nice to have and pretty unintrusive and cheap if you do it right. Total cost for my CB setup was under $75 and uses nice name brand stuff and good quality coax. When you do long trips (ie 7 hours straight for me no breaks) it gets pretty repetitive and sometimes lonely so it helps to have a CB handy to talk to the truckers, some of them are pretty funny and know a lot. They also like to call in weather conditions (plus there's weather band) speedtraps, accidents, etc.
Matt
Unread 02-15-2012, 09:23 PM   #3119
snobrdrkid07
That is for sure! That is why it is fun to have one in the truck!
Another reason why it is on the list. Fairly cheap mod!
-Michael-
Unread 02-16-2012, 04:31 AM   #3120
robd2003
I am going to invest in a nice LCD CB i seen at a truck stop.. looked real fancy! with a blue face haha.. but no really i liked having a cb in my other vehicles, would like to get my HAM license then that way worst comes to worst i can reach out further than cb could... even when theres no cell signal
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
