Snobrdrkid's WJ Build Thread - Page 192 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-06-2012, 11:19 PM   #2866
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by Ljohn221 View Post
Stock shocks, didn't tighten them all the way and they rattled
Gotcha, gonna have to check mine out!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 11:20 PM   #2867
snobrdrkid07
Virginia Beach Auto Show, Pictures Focused on Jeep. Last one is me sitting in a 2012 Overland Summit!
-Michael-
Unread 01-07-2012, 07:25 PM   #2868
snobrdrkid07
Taking the Jeep into my Friend at the Dealer.
1. Checking the brakes
2. Checking all the fluids - power steering, brake fluid, coolant
3. Seeing what is going on with the vibrations at idle.
4. Replace both the PCV valves on the valve cover
5. Check the motor mounts
The noise from the rear end I am pretty sure is coming from the shocks.
I think that is all I can afford for now.
Went down to Hatteras today.
Yes we power washed all the salt and sand off afterwards!!
-Michael-
Unread 01-07-2012, 10:00 PM   #2869
Bama_WJ
Those Overland Summits are way nice. To much $$ for my blood though.
And I've always wanted to cruise down a shoreline and just blow through the waves coming in.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 01-07-2012, 10:10 PM   #2870
snobrdrkid07
Was thinking about putting a 2013 WK2 Overland on order with the hemi and the new 8 speed transmission!
Oh it was too much fun riding in the water! If I did that in the WJ she would not like it, I would have to scrub the underneath to prevent the rust!
-Michael-
Unread 01-08-2012, 12:36 PM   #2871
snobrdrkid07
Well I am retarded, I should have figured to check all the bolts on the shocks to be tight. There was the upper driver side bolt was super loose! Tightened that b**** down and that took alot of the noise away. Must have been loose and had play in it. Why did I not think to check that! haha
-Michael-
Unread 01-08-2012, 08:43 PM   #2872
snobrdrkid07
Took some pictures. So apparently it is true if you leave your turn signal on for over a mile, the overhead console yells at you!
-Michael-
Unread 01-09-2012, 12:41 AM   #2873
alwaysHI
2003 WJ
WOAH! didnt know that....i feel like doing that for the heck of it now
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/ - SOLD
alwaysHI is offline   Reply With Quote Quick reply to this message
Unread 01-09-2012, 09:22 AM   #2874
snobrdrkid07
I was reading on the functions on the EVIC and was like ohhh yeahhh! Have to try this out! Sure enough, after a mile. That message will come up!
-Michael-
Unread 01-09-2012, 10:48 AM   #2875
JerzeyBoyWJ
2003 WJ
im gonna come a visit you so you can wax my jeep hahaha yours is like show room condition
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 01-09-2012, 03:59 PM   #2876
snobrdrkid07
Hahahahah. Thank you man! If you're ever around the Virginia Tech area ill do that for you!
-Michael-
Unread 01-10-2012, 04:50 PM   #2877
snobrdrkid07
Alright, so my mechanic called back and here is the rundown:
1. Brakes have about 5 or 8 thousand miles on the front rotor/pads - 220 (going to wait a little on those)
2. The engine and transmission mounts are cracked/shot - 400 for parts and labor
3. The rear a-arm bushings on the frame are shot and the he suggested to do the ball joint at the same time. He said the whole a-arm needs replaced because the bushings on the frame side only come with a new arm, then the ball joint is seperate - 350 for new a-arm, ball joint, and labor
4. Replacing both the PCV valves - 40 bucks parts and labor
5. He test drove and said everything else looked good - check
6. Checked all the fluids and were good. - check
Called dad and was pissed and didn't want to do any of that excpect the PCV valves...
what do you all think?
-Michael-
Unread 01-10-2012, 04:57 PM   #2878
alwaysHI
2003 WJ
350 for a-arm??.....buy the IRO adjustable one and put it in for 300 bones!!!!
Unread 01-10-2012, 05:16 PM   #2879
85IrocZ-28
First of all, you can do ALL of these things on your own, nothing on your list is that complicated. Even with little wrenching experience, you can figure this stuff out.
Additional Thoughts:
3. X2 on the IRO arm, then you will have it if you decide to put on a lift later. 5 bolts to take the old stuff off, 5 bolts to put it all back together.
4. Seriously, this will take you less than 2 minutes once you pop the hood (if they are located on top where I think they are)
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- [URL=http://www.jeepforum.com/forum/f197/project-yeti-abominable-wj-1125665/]Project Yeti Build Thread[/URL]
85IrocZ-28 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2012, 05:28 PM   #2880
smunns
Does he include a complimentary bottle of anal lube? Seriously. I changed my transmission mount recently and it took 15 minutes. $40 part. Motor mounts aren't that hard or expensive either. And those a-arm bushings are available separately. $8-$13 each on Rock Auto.
smunns is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
