Snobrdrkid's WJ Build Thread - Page 191 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 01-03-2012, 09:43 PM   #2851
snobrdrkid07
snobrdrkid07's Avatar
double post
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 01-03-2012, 09:48 PM   #2852
snobrdrkid07
Sunk my Jeep in some mud, was able to get out in 2wd. Was to lazy to put in 4wd cause I knew it would have been a fight to put it back in 2wd
Idle is still crap in gear. Also the something was grinding only in Neutral.
I can not figure out if it is my rear a-arm ball joint or my after market shock bushings that are lose.
But it is what it is. It would not be a Jeep if it was running perfect all the time. Taking her on my date tomorrow still
-Michael-
Unread 01-04-2012, 04:53 PM   #2853
snobrdrkid07
Been itching to put the OME Springs on so so bad ever since Comp put his on!
Also having a blend door problem, I think, hot on the drivers side, but cooler, noticeably cooler on the passenger side. That doesn't seem to be good.
-Michael-
Unread 01-04-2012, 06:46 PM   #2854
JulietheJeep
I'd try some carb cleaner on your throttle body, don't be easy with it either soak the crap out of it and clean it good.
I want to seafoam too. Usually with seafoam you use 1/3 in the brake booster line, 1/3 in your gas tank, and the other third in the crank case with the oil. Although a lot of people don't like to put any in the crank case.
I just ordered a new Rancho HD SS from kolak since I broke mine offroad, and my steering is getting really sketchy! I don't have the money right now but I plan on getting new tie rod ends, all 4.
I have at least 5" of play in my steering wheel and driving is getting really scary
Steel Blue WJ named Julie.- R.I.P. Julie the Jeep
Another Steel Blue WJ named Jenn.
3" IRO Lift, Bilstein 5100s, 32s, Roof basket
JulietheJeep is offline   Reply With Quote Quick reply to this message
Unread 01-04-2012, 09:00 PM   #2855
snobrdrkid07
I recently took the whole throttle body off and cleaned it all, and then even put in a new IAC (its an autozone brand though, not mopar IAC) and it really didn't help. The problem with the idle started after the jeep sat forever then it has never run the same since I left it for college.
I don't want to sea foam: 1. I just changed the oil. 2. I don't want to foul my spark plugs which are pretty new. So where would I put it? The throttle body? Or the brake booster line?
Yeah I am not sure how much the SS will help with all the play. That might be more TRE related. I have play in my wheel. But not quite as much, most of mine is my steering box. (It is a jeep, not a mercedes or a bmw)
-Michael-
Unread 01-04-2012, 09:34 PM   #2856
JulietheJeep
The big brake booster line that goes to the throttle body, suck it out of the can like a straw but "sip" it out. Dont let it stall
Unread 01-04-2012, 09:39 PM   #2857
snobrdrkid07
There really aren't any negative effects of it? What is the whole detailed process??
-Michael-
Unread 01-04-2012, 09:58 PM   #2858
JulietheJeep
You can look up some really detailed write ups and youtube videos but here's the basics.
Get your Jeep to normal operating temp, and pull off the brake booster line, dip the line in and suck out the seafoam slowly and take sips and let it get air so it doesn't stall. Your Jeep will start pouring out white smoke, this is all the crap in your cylinders burning, it's a good thing.
Once you've used about 1/3-1/2 (if you dont plan on using any in the crank case) shut the Jeep off and let it sit for about 5 mins, then start it up again and drive it hard. Take off a few times accelerating hard. Drive until the smoke stops and put the other 1/2 in the gas tank. It won't crude up your plugs it will just clean the fuel lines and fuel injectors. Give you a little gas milage.
Good luck
Unread 01-04-2012, 10:29 PM   #2859
snobrdrkid07
Ah man I really wanna do this now! Maybe I can get to it in the next few days! I am just so nervous I am gonna eff it up!
-Michael-
Unread 01-06-2012, 10:28 AM   #2860
snobrdrkid07
Was playing around with the Jeep again, trying to figure out all the noise that is going on in the rear when going over bumps. I took the tire and pushed it side to side and it was all solid, the axle moved with the body and there was no noise and it all seemed okay. It must be the shock bushings, I have read that the the after market shock bushings are not as "tight" in the mounting locations and can make noise because they have play in them and can move around.
-Michael-
Unread 01-06-2012, 11:36 AM   #2861
Bama_WJ
This is what I follow whenever I seamfoam something.
http://ls1tech.com/forums/general-ma...-your-car.html
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 11:56 AM   #2862
snobrdrkid07
Wow what a great article! Thank you!
-Michael-
Unread 01-06-2012, 02:01 PM   #2863
Ljohn221
Same thing happened to me one time when I took my shocks out
Check out my 1999 WJ build>
http://www.jeepforum.com/forum/f22/ljohns-1999-wj-build-forum-1188750/#post11260881
Ljohn221 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 02:04 PM   #2864
snobrdrkid07
You had a bunch of noise with your aftermarket shocks?
-Michael-
Unread 01-06-2012, 06:32 PM   #2865
Ljohn221
Stock shocks, didn't tighten them all the way and they rattled
ome hd , OME lift kit , snobrdrkid , wj
