Snobrdrkid's WJ Build Thread - Page 158 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 11-20-2011, 07:17 AM   #2356
snobrdrkid07
snobrdrkid07's Avatar
Okay does it matter that it idles better when in park then drive?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 11-20-2011, 08:12 AM   #2357
Thomahawk
Thomahawk's Avatar
No, clean it, atleast remove the air intake, turn the Throttle plate and have a look in there.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is online now   Reply With Quote Quick reply to this message
Unread 11-20-2011, 08:39 AM   #2358
mrJ
2002 KJ Liberty
What's the best cleaning solution for the IAC?
Build In Progress...[url]http://www.jeepforum.com/forum/f22/03-wj-limited-build-she-needs-name-1113549/[/url]
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline   Reply With Quote Quick reply to this message
Unread 11-20-2011, 08:46 AM   #2359
Thomahawk
Thomahawk's Avatar
Throttle body cleaner, i used carburator cleaner.
Be sure you hold that IAC with the plunge downwards when you spray it, so the sollution doesnt Goes inside the IAC itself.
Wjjeeps have a good write up on TB cleaning.
Unread 11-20-2011, 10:00 AM   #2360
snobrdrkid07
So far I've taken off the resonator and exposed the throttle body. removed the throttle cables as well.
Was able to get the iac wire off and the wire closest to the driver's side. Yet to get the last one off with a yellow plug.
The throttle body is def dirty. I bought throttle body and air intake cleaner and plan on spraying that all in the throttle body (after its off the jeep) the taking out the iac motor and cleaning the plunger and cleaning the iac housing.
-Michael-
Unread 11-20-2011, 10:06 AM   #2361
Thomahawk
Thomahawk's Avatar
Before and after pics? Or it didnt happen, lol
Unread 11-20-2011, 11:03 AM   #2362
compcrasher86
When I did my TB honestly I just took the whole damn thing off took all the sensors off and went at it with cleaner and an old tooth brush. Got so much carbon out plus I didn't have to hear the Jeep whine and struggle to start with all the cleaner sitting in the intake.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 11-20-2011, 11:20 AM   #2363
snobrdrkid07
That is exactly what I intend to do. When I can get that one last damn wire off. then ill be able to take the whole thing off and clean it out
-Michael-
Unread 11-20-2011, 12:50 PM   #2364
snobrdrkid07
Ok guys I am having a really tough time cleaning the crap of the iac. Help!
-Michael-
Unread 11-20-2011, 01:07 PM   #2365
mrJ
2002 KJ Liberty
Soak and toothbrush son
Unread 11-20-2011, 01:10 PM   #2366
snobrdrkid07
I've been spraying it with the TB cleaner and trying to use a toothbrush. I just don't want to be hard on it. Im basically trying to not even use enough force to move the plunger....
-Michael-
Unread 11-20-2011, 01:16 PM   #2367
Thomahawk
Thomahawk's Avatar
Its no problem if you move the plunger, i was also afraid of that, cleaned it and forgot, fickled with it and pulled it out.
Aaaaahhhhh, no no no.
It was no problem, just put it back, disconnect battery for a while, it Will relearn itself, no prob...
Unread 11-20-2011, 01:20 PM   #2368
mrJ
2002 KJ Liberty
Maybe one of this handheld steamers. I know my buddy cleans his percolators with one and it works really well
Unread 11-20-2011, 01:34 PM   #2369
snobrdrkid07
I've gotten the tip pretty clean. The shaft has some good amounts of carbon left on it.
That makes me feel way better.
-Michael-
Unread 11-20-2011, 01:35 PM   #2370
snobrdrkid07
Now I can't get the iac back in the hole.... wtf
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
