Snobrdrkid's WJ Build Thread - Page 151 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting Sleeves
Unread 11-05-2011, 06:26 PM   #2251
robd2003
Yup, thats what me and the wife did some today after we picked up the radiator.
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2011, 06:47 PM   #2252
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
I am looking for a leather interior swap and a V8 cat back exhuast pipe (because it is bigger)
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2011, 07:55 AM   #2253
robd2003
what color leather, and how much you looking to spend?
Jeeps:
Unread 11-06-2011, 11:47 AM   #2254
snobrdrkid07
Mr. WJ
Gray leather. I have a gray interior. Don't have much budget, college student. It is a want more then a need
-Michael-
For Sale:
Unread 11-07-2011, 07:53 AM   #2255
snobrdrkid07
Mr. WJ
Some Exhaust questions. From the headers through the two cats to the muffler is 2.5 inch diameter tubing? Then from the muffler to the end is 2.25 inch diameter pipe.
I want to go to the junkyard and get a 2.5 inch v8 exhaust.
I just forget how the exhaust is setup under there. Being away from the Jeep I forget!
-Michael-
For Sale:
Unread 11-08-2011, 03:46 PM   #2256
snobrdrkid07
Mr. WJ
Alright guys time for a thanksgiving Jeep project. I want to rock lights with LED's
I have a 16 foot 600 white LED strip from eBay and I am going to cut them into 3 separate strips. 1 on each side and one on the front. Then possibly one in the rear if there is enough left over.
I want to have a switch that is single-pole double throw. Basically, I want them to come on with the dome lights but also have the control to turn them completely off and then 'on' whenever I want. I believe that the SPDT switch will do this. http://www.amazon.com/Automotive-Round-Rocker-Switch-Center/dp/B001TQMU5C
Here is a really crude diagram. I am not sure how to wire it all to the "on-off-on" switch. I do not think that I will need a relay or anything like that because the LED's draw so little power.
Diagram below. Any help please?
-Michael-
For Sale:
Unread 11-08-2011, 04:06 PM   #2257
snobrdrkid07
Mr. WJ
Did some more research. It seems like where I have that "ground" coming of the switch... that should be a "positive" power output to the LED's if I am not mistaken now...
Then I can just ground the LED's to the body or wherever I can get a good ground connection.
-Michael-
For Sale:
Unread 11-08-2011, 04:10 PM   #2258
Ljohn221
That sounds about right since I did my exhaust a couple weeks ago
EDIT*: it is 2.5 from the headers to the third cat then 2.25 from the third cat on
Check out my 1999 WJ build>
http://www.jeepforum.com/forum/f22/ljohns-1999-wj-build-forum-1188750/#post11260881
Ljohn221 is offline   Reply With Quote Quick reply to this message
Unread 11-08-2011, 04:13 PM   #2259
Thomahawk
Thats about right. It could be smart to use a relay and let the dome light and other switch to Control that relay.
Sent from my Iphone4
Buildthread [url]http://www.jeepforum.com/forum/f197/jeep-norway-2th-buildt-overland-upgrade-1813490/[/url]
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 11-09-2011, 09:15 AM   #2260
snobrdrkid07
Mr. WJ
Even on the v8? or is that for the 6? I though the v8 had 2.5 inch pipe all the way?
To use a relay to keep the draw off the interior light circuit? I still am not sure where I am going to hook them up at yet.
Edit: random but I haven't been getting email notifications about new replies like I was before. They are all really really delayed now.
-Michael-
For Sale:
Unread 11-09-2011, 11:05 AM   #2261
Thomahawk
Yes and more convinient, wiring wise, just draw that power wire with fuse and a relay mounted a practical place, then you can wire whatever you want to Control that relay. Just my thoughts on it, you can do this in several ways.
Unread 11-09-2011, 11:15 AM   #2262
snobrdrkid07
Mr. WJ
I will see if I can draw up a better diagram later and post it up and see what you all think!
-Michael-
For Sale:
Unread 11-09-2011, 01:21 PM   #2263
snobrdrkid07
Mr. WJ
Here is what I came up with!
-Michael-
For Sale:
Unread 11-09-2011, 01:52 PM   #2264
Thomahawk
Thats about as good as it can Get.
Unread 11-09-2011, 02:07 PM   #2265
snobrdrkid07
Mr. WJ
Hahaha thanks man! I did that on a program called OneNote by microsoft. It is supposed to be used to take notes in class etc.
-Michael-
For Sale:
ome hd , OME lift kit , snobrdrkid , wj
