Snobrdrkid's WJ Build Thread - Page 120 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 09-06-2011, 11:49 PM   #1786
straty1987
Originally Posted by snobrdrkid07 View Post
I guess that would still help! I can see how it would help with bugs too! Keeping crap out of the grooves!
Do you have the mechanical fan too? That is what splashes everywhere! The electric fan isnt bad because it is in the shroud
i have the Hydraulic Engine Cooling system, just the plastic fan blades
this is what my engine looked like after my trip, not allot but am still getting the mud out. i was driving in muddy water that was around the top of the bumper. mostly got the passenger side, thinking of fabing up some type of plastic splash guard. i should of just taking my bumper off to clean because i had the hose for over 20 min and still had mud/dirt coming out from behind the bumper. swamps smelt bad but it looked cool driving threw.
straty1987 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2011, 11:50 PM   #1787
snobrdrkid07
snobrdrkid07's Avatar
That is pretty much what mine looks like too! It is a really big PIA!!!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2011, 11:55 PM   #1788
JerzeyBoyWJ
2003 WJ
i put in my .75 spacers in the front today...and cant really tell a difference?? hah
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 09-07-2011, 12:24 AM   #1789
Ljohn221
Lol fail
Check out my 1999 WJ build>
http://www.jeepforum.com/forum/f22/ljohns-1999-wj-build-forum-1188750/#post11260881
Ljohn221 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2011, 12:28 AM   #1790
JerzeyBoyWJ
2003 WJ
Originally Posted by Ljohn221 View Post
Lol fail
yeah hahah ...kinda shows how much the RC lift sagged...cause its supposed to be 3.5 in the back and now the front is completely level ...you can kinda tell ..you just gotta double look
Unread 09-07-2011, 05:54 AM   #1791
snobrdrkid07
LOL that is kinda of fail. I noticed on mine and there was a measured difference and my front LCA went out of parallel to the ground afterwards.
-Michael-
Unread 09-07-2011, 06:15 AM   #1792
Thomahawk
Thomahawk's Avatar
So, Whats the best springs at stock or 1-2" lift height That Are most resistant to sagging?
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 09-07-2011, 06:51 AM   #1793
snobrdrkid07
Any Spring that is not stock (that I know of) has a higher spring rate (meaning stiffer). But honestly the main reason for WJ sagging is the rubber isolators crushing over time.
-Michael-
Unread 09-07-2011, 06:55 AM   #1794
Thomahawk
Thomahawk's Avatar
Ok, That makes sense, i just cant decide If i am going for new springs or just isolators. Also springs with higher spring rate Will improve road manners but Will reduce comfort, dont want it to be too stiff either.
Unread 09-07-2011, 06:59 AM   #1795
snobrdrkid07
Ok, That makes sense, i just cant decide If i am going for new springs or just isolators. Also springs with higher dpring rate Will improve road manners but Will reduce comfort, dont want it to be too stiff either.
Isolators are always a good choice. OME springs has a really nice road handling ride and a comfortable ride. They seem to be a good balance between the two. Especially with the bilstien shocks paired with them. Ask Kolak about spring rates. He knows the more technical aspect about them (or I would assume)
For my lift at one point, I was looking at 2" BDS coils. Hearing good things about them
-Michael-
Unread 09-07-2011, 07:11 AM   #1796
Thomahawk
Thomahawk's Avatar
Thought i could Ask YOU, seems like you know EVERYTHING. Ha ha ha 
Unread 09-07-2011, 07:33 AM   #1797
snobrdrkid07
Hahahahaha. Well I COULD look it up HOWEVER, I'm sitting in chem class. Trying to balance jeepforum and notes haha.
-Michael-
Unread 09-07-2011, 07:42 AM   #1798
Thomahawk
Thomahawk's Avatar
I Will find out myself, no woories, close your app man, and focus on your studies.
Unread 09-07-2011, 07:53 AM   #1799
snobrdrkid07
Tehehe. I'm out of class now and have an hour break until the next one. I do know that there are 3 types of OME for the WJ, light/medium/heavy. Ill look for the numbers to each and try to compare them to stock, and other company springs
-Michael-
Unread 09-07-2011, 01:02 PM   #1800
Thomahawk
Thomahawk's Avatar
^^^X2 i Really want to see, What do you guys Think about plenum size of the intake theory, i know people have tried it out at BMW's before and Dyno shows That stock can be better over CAI due to larger plenum....
Ok, i Will answer My own question. Ha ha ha
Posted by MWF:
There is a link between plenum length/volume and the powercurve of an engine, longer usually means better torque and shorter better top end power. So it can be beneficial on some engines to have longer and more complex systems.
On top of that you have the issue of turbulance vs laminar flow, some filters can create massive amounts of turbulence which in turn create dead spaces and vortexes in the induction system which actually reduce flow overall.
ome hd , OME lift kit , snobrdrkid , wj
