Snobrdrkid's WJ Build Thread - Page 108 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 08-30-2011, 09:47 AM   #1606
JerzeyBoyWJ
2003 WJ
Originally Posted by snobrdrkid07 View Post
Is that a 5 speed manual?
yepp..my buddy has it is his YJ...well i guess i can still call it his ..its forsale
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 09:54 AM   #1607
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by 1stblack97ZJ View Post
yessiree!
That'd be a cool swap, I've seen a thread on it. AgitatedPancake did the swap!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 12:00 PM   #1608
SnowLeopard
What I want to know is why they stopped using the Aisin Warner transmission.
http://en.wikipedia.org/wiki/AMC_and...s#Aisin-Warner
That thing is a lot stouter than the 42RE, no? I'm sure we could swap, but what would the issues be with CELs? I think some people have done it before. I'd likely do that if I ended up needing a tranny swap.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 12:08 PM   #1609
snobrdrkid07
So the AW4 mirrors the 42re pretty closely and is supposedly a better trans AND fits with the 4.0. But I wonder what codes etc it would through with the WJ
-Michael-
Unread 08-30-2011, 01:29 PM   #1610
SnowLeopard
I know that it'll fit and has been done before in ZJ's. I don't know about it working in a WJ. The issues arise from the 42RE being electronically controlled and so forth. The AW4 is mechanical.
Unread 08-30-2011, 02:32 PM   #1611
snobrdrkid07
Oh there are electronics in the 42re... but just not as much as there 45re
-Michael-
Unread 08-30-2011, 02:37 PM   #1612
Thomahawk
Thomahawk's Avatar
545RFE Rearwhell Full Electronic
Same as 45RFE just another program in the TCM transmision control modul That adds the 5th gear.
45RFE was delivered from factory in 99 and 00 models, sometime in 01 they started with the 545RFE, but all 99 and 00 models can easily be flashed by dealership so it becomes a 545RFE.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 02:54 PM   #1613
snobrdrkid07
I was looking at the 545re and was wondering if the could flash it to be a six speed... So it would utilize both 2nd gears.
-Michael-
Unread 08-30-2011, 03:09 PM   #1614
Thomahawk
Thomahawk's Avatar
In fact the 45 have 5 gears, the 545 have 6 gears, both have 2 2th gears one for down shift and one for up shift. The difference is the 5th (6th) overdrive gear.
Btw its RFE not RE as in the 42re.
Unread 08-30-2011, 03:36 PM   #1615
snobrdrkid07
Right, Now can the 545rfe be programmed to use all 6 gears consecutively?
-Michael-
Unread 08-30-2011, 04:08 PM   #1616
joze
No, when you drive "normally" it just shifts normal.
The gears in (5)45RFE are like 1st, 2nd, 2ndLong, 3rd, 4th, 5th. So when i take off it just shifts 1st, 2nd, 3rd... but when i romp the pedal to the floor it upshifts to 2ndLong and then 3rd, 4th... i hope i explained it well enough. If not, i'll make a video.
If you can get it to fit, 545rfe is a great tranny. Or just get a V8
[URL="http://www.jeepforum.com/forum/f197/my-non-build-fix-when-gets-broken-thread-1240817/"]My non-build thread[/URL]| [URL="http://www.jeepforum.com/forum/groups/black-jeep-society/"]Black Jeep Society member[/URL]
[QUOTE=Ljohn221;12072741]You can't start a new civilization without jeeps[/QUOTE]
[QUOTE=dukie564;11573618]
[B]Epic boobs saving threads since 1978[/B][/QUOTE]
joze is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 04:10 PM   #1617
1stblack97ZJ
the AW4 isn't a simple swap..
http://www.jeepforum.com/forum/f13/a...dii-zj-382739/
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 04:11 PM   #1618
snobrdrkid07
Yes that does make sense. But what I was wondering is if they can program it to on a normal basis to go: 1,2,2,3,4,5 so it would be turning it into a six speed. Get me? lol. Is there a lock up torque converter with the (5)45rfe?
-Michael-
Unread 08-30-2011, 04:13 PM   #1619
Thomahawk
Thomahawk's Avatar
Its like 1-2-2-3-4-5
The first 2 gear is for up shift the second for down shift.
I have read someplace here at JF That the 545RFE actualy can have up to 8 gears physicly, 2 backwards and 6 forwards but Chrysler never Made Any program for That as far as i know.
I would be like R1-R2-1-2-3-4-5-6
Unread 08-30-2011, 04:15 PM   #1620
snobrdrkid07
OH WOW I guess it can be done. I think it would be easier for my to buy my overland and swap my audio and mods over to the new Jeep!
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
