Snobrdrkid's WJ Build Thread - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 01-18-2011, 03:14 PM   #136
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by lloyd877 View Post
I need a duh stamped on my forehead.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 01-18-2011, 03:21 PM   #137
snobrdrkid07
Should I look into getting new injectors? Read that could cause rough idle .
-Michael-
Unread 01-18-2011, 04:21 PM   #138
AgitatedPancake
Damn man, one thing at a time. You have to rule things out before you find the cause. Why would you look into replacing the injectors before you'll even attempt to pull 1 or 2 screws out to look at a sensor? Hell I think you could replace it for under $50.
I don't understand what's going through you're head to refuse to diagnose, just throw money at it
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 01-18-2011, 04:24 PM   #139
AgitatedPancake
and when was the last time it got new plugs or you regapped the plugs?
Unread 01-18-2011, 05:22 PM   #140
snobrdrkid07
I got new spark plugs put in last weekend along with a throttle body cleaning.
I am going to pull the IAC and inspect/clean it, this weekend when I have time.
I was just asking if the injectors could cause the idle issue, I am not messing with that until I deal with the IAC as you suggested. Because I really don't have money to throw.
As always I appreciate the information.
-Michael-
Unread 01-18-2011, 08:09 PM   #141
AgitatedPancake
Ahh nice man, good plan! Sorry it kinda felt like you were ignoring the easy things :P. It's nice to check them, just to rule them out in your mind!
Unread 01-18-2011, 08:14 PM   #142
snobrdrkid07
Hahahaha. Thanks. I will definitely take the easy way if at all possible.
Reading this about how to Clean the IAC
I am hoping that cleaning it all off should help the idle. HOPING that will fix it!!!
I am still working on my lose a** steering hehe
-Michael-
Unread 01-18-2011, 11:23 PM   #143
Akrobatiks
I finally got that Jet Accu-speed chip installed...!!!! SOoo Stoked!!!! It works perfectly. My speedo is accurate again and because it adjusts the shift points my ride is sooo much smoother on the highway again. Its also looking like my fuel economy is back. Have to do some more driving to be sure but its looking like Il be back up over 200 miles per tank and with my flashpaq set to economy mode I may even get 250+!!!!(Gone about 100 miles w/ about 2/3 of a tank left) Im super pumped about that because gas has been killing me since I got everything done!!!(was getting about 175 miles per tank @ $55 per fill)
As for your Idle issue,
Did you try running some fuel injector cleaner through your gas?
It may sound dumb but have you tried different gas? You could have a bad batch...?
Akrobatiks is offline   Reply With Quote Quick reply to this message
Unread 01-19-2011, 12:24 AM   #144
SplitNail
Which chip did you get??
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline   Reply With Quote Quick reply to this message
Unread 01-19-2011, 12:45 AM   #145
CostcoPizza
Fresh Baked
CostcoPizza's Avatar
Originally Posted by SplitNail View Post
I can't read
CostcoPizza is offline   Reply With Quote Quick reply to this message
Unread 01-19-2011, 12:49 AM   #146
SplitNail
sorry, its late. I just got back from playing tennis. My B.
Unread 01-19-2011, 12:56 AM   #147
Akrobatiks
I also have a Superchips Flashpaq with the Fuel Economy Tune programmed in ATM...
Unread 01-19-2011, 06:45 AM   #148
snobrdrkid07
Oh that those two chips must be awesome! I would only need the flashpack seeing how everything is still stock. I usually get 240 (13.0) mpg was my average) out of a tank with heavy city only @ 60-65 a tank hahaha
I am going to look into the IAC first, whenever I get the time. I am going to hopefully soon, be able to pull it, and clean it. And if that helps... Great. And then I may or may not to go to the injector cleaner.
If the BP i go to has had bad gas for the last 8 months. haha
-Michael-
Unread 01-19-2011, 09:53 AM   #149
Akrobatiks
When I was driving my mom's 4.0, I was getting between 275-300 miles per fill-up FYI on the highway...
Unread 01-19-2011, 10:59 AM   #150
snobrdrkid07
We have gotten 380 to almost 400 on just highway... we could get 22 mpg on cruise on highway
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
