Snobrdrkid's WJ Build Thread - Page 75 - JeepForum.com
post #1111 of 6785 Old 08-05-2011, 09:42 AM
Scibbyz99WJ
I purchased my kit from rpm machine. It was essentially a 4.0 rebuild kit with a few exceptions. Forged and 0 balanced 12 weight 4.2l crankshaft, 4.2l forged rods, and high compression pistons along with some moly rings. Everything else is identical to a 4.0
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline
post #1112 of 6785 Old 08-05-2011, 10:15 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
So you did not bore anything out?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #1113 of 6785 Old 08-05-2011, 10:21 AM
Scibbyz99WJ
Nope. I left the standard bore. I would've gone .020 over had I known it was as easy as telling the shop to do it when I purchased the kit a month before the block went in for machining.
post #1114 of 6785 Old 08-05-2011, 10:36 AM Thread Starter
snobrdrkid07
WJ for Life
Ah ok thanks for all of the info. So just that kit got you tons of power over stock?
How hard was install and build?
-Michael-
post #1115 of 6785 Old 08-05-2011, 10:52 AM
Scibbyz99WJ
It is no harder than rebuilding an engine any other way. All it requires is that you space the girdle so the longer throw crank doesn't hit it. Then you must shave it to clear the oil pan.
I did other things to increase the power. Bigger throttle body, bored out intake manifold, ported and polished head. The more volume pushed through the cylinders needs somewhere to go.
post #1116 of 6785 Old 08-05-2011, 10:52 AM
zerocool1221
2003 WJ
Love your WJ man....looks good!!
zerocool1221 is offline
post #1117 of 6785 Old 08-05-2011, 10:55 AM Thread Starter
snobrdrkid07
WJ for Life
I figured it still was an entire rebuild. Which is for the time being out of my league. I would need a shop to do it or see if my mechanic would be able to do it. haha
Have you blown your trans yet?
-Michael-
post #1118 of 6785 Old 08-05-2011, 10:56 AM Thread Starter
snobrdrkid07
WJ for Life
Thank you! It had been a really fun process building it up! I hope the same goes for you and your Jeep!
-Michael-
post #1119 of 6785 Old 08-05-2011, 10:57 AM
Scibbyz99WJ
Engine was rebuilt at 147k trans went at 158k
Oh FYI. I spent about $1800 in parts alone
The hot tank, magnaflux, port job, freeze plugs, block sleeve, and cylinder hone cost $425
post #1120 of 6785 Old 08-05-2011, 10:59 AM Thread Starter
snobrdrkid07
WJ for Life
Oh that sounds like fun. What did you do to your trans... did you build that up some?
-Michael-
post #1121 of 6785 Old 08-05-2011, 11:01 AM
Scibbyz99WJ
I didn't have the money at the time so I bought a used trans out of a recently wrecked jeep. It's holding up so far. But I'm saving up for a nv3550 swap when it does go. The 42re can barely handle a 4.0 much less a 4.5
post #1122 of 6785 Old 08-05-2011, 11:05 AM Thread Starter
snobrdrkid07
WJ for Life
haha a manual swap would be so much fun haha. would the six speed manual from the rubicons fit in the WJ's? thatd be cool too!
I wish the 545re would fit up to the 4.0 or the future 4.5+ liter engine!
-Michael-
post #1123 of 6785 Old 08-05-2011, 11:53 AM
Scibbyz99WJ
I hope I'm not wrong but I believe that any 4.0 wrangler trans will adapt to fit a WJ. The 6 spd would be pretty awesome but its $4k new!!! I can find a used nv3550 and rebuild it for a quarter of that
post #1124 of 6785 Old 08-05-2011, 12:06 PM Thread Starter
snobrdrkid07
WJ for Life
Yea that would be good. I do not see why that 6 speed from the Rubicon wouldn't fit. haha. Had no idea that it was that expensive either!? Why is it so much more?!?!
Will the 545re fit the 4.0?
-Michael-
post #1125 of 6785 Old 08-05-2011, 12:51 PM
Scibbyz99WJ
Most say no. And I haven't seen any try to make it fit. If it did that
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
