Snobrdrkid's WJ Build Thread - Page 67 - JeepForum.com
post #991 of 6785 Old 06-26-2011, 12:13 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by WJHype View Post
Thank you
No problem! Post some pictures when you are done!
Also, I only tapped into the driver side under dash light, the passenger side was a PIA with all the AC stuff over there, I just ran wires around to the other side!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #992 of 6785 Old 06-26-2011, 03:01 PM
JulietheJeep
Hey looks like we're in the same boat, I'm a 17 year old snowboarder with a 2002 Grand Cherokee haha Yours looks pretty nice I'm hoping to save up enough for a lift soon
Steel Blue WJ named Julie.- R.I.P. Julie the Jeep
Another Steel Blue WJ named Jenn.
3" IRO Lift, Bilstein 5100s, 32s, Roof basket
JulietheJeep is offline
post #993 of 6785 Old 06-26-2011, 03:10 PM Thread Starter
snobrdrkid07
WJ for Life
Haha. It's an addiction that's for sure! The jeep is quite the money sucker! I've saved for a lift but the parents shot that one down. I put some 3/4 inch Spacers in the back and that was fun. Haha.
Good luck and keep us updated! Have fun out there!
-Michael-
post #994 of 6785 Old 06-26-2011, 03:30 PM
JulietheJeep
Man thats a bummer. When I first got my Jeep my dad didn't want me going on anything that's not asphalt, then I found some trails around me and took him one day and now we're both working on getting tow hooks and a lift kit. A friend of mine told me to use hockey pucks as spacers for the springs I was thinking about getting a bb and throwing a hockey puck or two in there for some extra lift.
post #995 of 6785 Old 06-26-2011, 03:41 PM Thread Starter
snobrdrkid07
WJ for Life
Haha. Well that's good that its gonna work out with a lift! How the heck do hockey pucks give you lift? Like where the heck do they go?
-Michael-
post #996 of 6785 Old 06-26-2011, 03:44 PM
JulietheJeep
He said it's like the same as a spacer, they go in between the springs and the strut tower, I think he said you have to drill holes through the puck but it seems easy enough. If I get bigger shocks with little spacer kit a puck could give me an extra inch
post #997 of 6785 Old 06-26-2011, 04:46 PM Thread Starter
snobrdrkid07
WJ for Life
The spacers that I installed for the rear were significantly bigger then a hockey puck. So I'm not sure how that would work
-Michael-
post #998 of 6785 Old 06-26-2011, 06:28 PM
WJHype
Here's the lights installed.
Not the best picture because it's still a little sunny outside. By the way, the passenger bulb socket was actually easier to me, so I just wired it the same way I did the driver's side.
WJHype is offline
post #999 of 6785 Old 06-26-2011, 06:58 PM Thread Starter
snobrdrkid07
WJ for Life
Looks good! Really? I had a crap time on the passanger side. Maybe I have a different AC system. I have a manual.... not sure.
-Michael-
post #1000 of 6785 Old 06-26-2011, 09:11 PM
WJHype
That's possible mine is an 01 with dual control so it may be a bit different but the bulb socket was right in front of the AC system and the wire was easier to reach and splice in with the LED strip. The drivers side wire was further up so I had to reach up a bit higher to wire it in. Whatever works though haha.
WJHype is offline
post #1001 of 6785 Old 06-26-2011, 09:36 PM Thread Starter
snobrdrkid07
WJ for Life
yea different system... who knows. exactly, whatever works! haha! did you do rears too?
-Michael-
post #1002 of 6785 Old 06-26-2011, 09:39 PM Thread Starter
snobrdrkid07
WJ for Life
Getting an Alpine 4-channel amp installed tomorrow for the door speakers! Should finish off the system nicely!
-Michael-
post #1003 of 6785 Old 06-26-2011, 10:16 PM
WJHype
No I haven't done the rears yet. I might though soon. How did you wire those?
WJHype is offline
post #1004 of 6785 Old 06-27-2011, 06:55 AM Thread Starter
snobrdrkid07
WJ for Life
I ran positive and negative wire under the door sill thing on the floor and just tapped it in with the front leds. Both my front led and rear led wires are both tapped into the under dash light. The wire is so small I just shoved it under stuff. Haha.
-Michael-
post #1005 of 6785 Old 06-27-2011, 11:53 AM
JerzeyBoyWJ
2003 WJ
how much did that run you?... i really need an amp to fully power my type Rs
the headunits 15w rms isnt cutting it
i was thinking of getting alpines powerpack but another amp is so much cooler
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
