Snobrdrkid's WJ Build Thread - Page 63 - JeepForum.com
post #931 of 6785 Old 06-03-2011, 04:54 PM
straty1987
Originally Posted by Scibbyz99WJ View Post
did you know that they make torque extensions for impact guns? my buddys dad has a set of them. i guess they flex or something when the bolt is torqued down to its rating
http://forums.pelicanparts.com/uploa...1153449661.gif
they look interesting but cost allot, am sure there worth it. http://www.amazon.com/Genius-Tools-Torque-Extension-2-Inch/dp/B000E9NJ28 if only i had good tool money funds
i have a torque wrench from harbor fright. 1/2" 20 to 150 ft. lbs
been ok so far, but i mainly use it use it on the wheels bolts. i can mange ball park 20-40 FT lbs
20 ft. lbs is snug and a about 1/4 a turn, tip via WJJeeps on 4.7 spark plug install
40 ft. lbs is sung and about 1/2 a turn
straty1987 is offline
post #932 of 6785 Old 06-03-2011, 04:58 PM
Scibbyz99WJ
only problem with that is whos definition of snug? and snug with a 1/4 in drive is still loose when you throw on a 1/2 in drive 2ft breaker bar
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline
post #933 of 6785 Old 06-03-2011, 07:05 PM
straty1987
like i said its ball park.
snug usually means on tight and cant move it with out using some strength.
its in there and not tight or loss.
lol break bar is more leverage, is a 1/4" wrench was 2 ft long am sure bolts heads will start snapping from to much torque.
not going to use that tip on a bolt that needs 80 ft. lbs, more for 1/4" and 3/8 wrenching jobs
post #934 of 6785 Old 06-03-2011, 09:27 PM
MikeeN
2003 WJ
we use those at walmart tire lube center each extension has a certain thickness on it the higher the torque rating the thicker the extension is, when it reaches its max torque something to do with the thickness of the extensions causes it to start rattling and it wont allow you to torque it any further, just makes an annoying rattling noise. Kind of hard to explain sorry haha
MikeeN is offline
post #935 of 6785 Old 06-04-2011, 06:23 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
That is really cool about that torque wrench!
The 3/4 spacers are on the way!
Got a deal on a large power inverter (750 watts) Ideas to hard wire it and mount it somewhere... Going to browse around, i know i remember seeing stuff about this... Wonder if I can hook it up to my amp power wires! haha
edit: I bought this for 18.99 at sams club this
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #936 of 6785 Old 06-04-2011, 08:19 PM
Apollo21
I've got something in my sig.
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #937 of 6785 Old 06-04-2011, 08:39 PM Thread Starter
snobrdrkid07
WJ for Life
Yes, I read and I really liked that! I just dont have the same type of console up front!
I like the relay and switch idea for sure!
Ideas on wire size/fuse size/relay size for a 750 watt 1500 peak watt inverter... I plan on mounting under one of the rear seats and them running the AC line somewhere...
edit: bought this at Sam's Club for 20 bucks
-Michael-
post #938 of 6785 Old 06-04-2011, 09:59 PM
robd2003
You could use a heavy duty realy to switch power on and off. I asked my dad the other day about using a relay as power for continuous use and he said something about a 1975 ford starter relay, then i mentioned something about ordering a HD relay... so idk, i was thinking 8guage wire? might be to much, ha
but thats my .02
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline
post #939 of 6785 Old 06-05-2011, 12:15 PM Thread Starter
snobrdrkid07
WJ for Life
found this on Apollo's writeup on a the WJ power inverter install.
I would like to set mine up like this as well!
-Michael-
post #940 of 6785 Old 06-05-2011, 09:26 PM
straty1987
that is a good way to wire most things.
just before you go into this, i say look into if you really need the 750W power inverter. i picked one up after having my 200W inverter and i don't really need the 750W one. theirs a list on how many amps things use.
750W / 12V = 62.5A
-so you need at least a 63 amp fuse.
- deepening on how long the cable is your power cable is battery to invert or really to inverter its going o be 8 gauge to 4 gauge.
- also going to need a strong really not a basic 30 amp relay
post #941 of 6785 Old 06-05-2011, 09:31 PM Thread Starter
snobrdrkid07
WJ for Life
750W / 12V = 62.5A
I thought so too!
I am pretty sure i do not NEED that much power or will ever use that much... I am looking to power a laptop or an xbox... not a house.
I am not sure where I am going to mount... i.e. determining length/size of wire.
I know I can find an inline fuse that big... idk where I would get a relay that big... and the switch can just be a standard switch
-Michael-
post #942 of 6785 Old 06-06-2011, 05:49 PM
Scibbyz99WJ
I thought so too!
A laptop uses about 150 watts of power. Idk about an xbox. But my step dad ran a ps2 and a 12 inch tv with an ancient 150w
post #943 of 6785 Old 06-06-2011, 05:57 PM Thread Starter
snobrdrkid07
WJ for Life
Looking at the power brick... it said 203 watts... then a TV you probably figure 100-150... maybe
Did anyone look at the inverter I bought?
-Michael-
post #944 of 6785 Old 06-06-2011, 06:41 PM
Apollo21
Mine is 800w peak (it can hold it for just under an hour) and 400w for forever. 400w is enough to run an Xbox and TV comfortably. While charging a phone and iPod.
SOLD
Apollo21 is offline
post #945 of 6785 Old 06-06-2011, 07:19 PM Thread Starter
snobrdrkid07
WJ for Life
Did you mention your final setup/parts list in your write-up? I think that I over read past it...
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
