Snobrdrkid's WJ Build Thread - Page 48 - JeepForum.com
post #706 of 6785 Old 05-04-2011, 06:41 AM
sherker55
well the shocks should be fine, but it depends on when everything was installed. the trackbar bushings may have to be replaced, just for good measure...contact the MFG...SS's aren't that expensive, and that can go really quick since it's just a band aid for the DW. I would just replace that any way when you replace the TRE's (and replace all of them, no questions). DW is a strange animal. I did my lift with like 90k on the clock. No wobbles afterwards....old parts, probably never replaced.
sherker55 is offline
post #707 of 6785 Old 05-04-2011, 06:48 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
You think the trac bar bushings are gone only with vibrations?
Let me make clear that the DW stopped after the tires and trackbar and alignment. We have been left with just vibes... not DW
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #708 of 6785 Old 05-04-2011, 07:05 AM
sherker55
IRO sells the bushing for like $15...you might be able to get them from the MFG for free. it wouldn't hurt. the vibes are probably "mini" DW's...replace the TRE's and I think you'll be G2G....
my line of thought is to replace things that get worn or can be impacted by the dw vibes/vibes...I don't think shocks are effected as much because of their up/down travel compared to the lateral movement of the steering parts. sooooo
TRE's
SS
TB Bushings
should be about $150 max, assuming you do the labor yourself, and bought a lifetime alignment from firestone....don't forget to get it aligned this time please!
post #709 of 6785 Old 05-04-2011, 07:12 AM Thread Starter
snobrdrkid07
WJ for Life
TRE's
SS
TB Bushings
Emailed dad and he said he just had the car inspected and b/c of that, they said steering is fine (which I doubt the inspectors). He said he is just done with it.... idk. =(
-Michael-
post #710 of 6785 Old 05-04-2011, 12:13 PM
sherker55
well it is what it is...
no offense, but if he isn't going to do what is necessary to make it right, then half-asssing it is the way it'll have to be. I take it, he doesn't get his hands dirty much?
post #711 of 6785 Old 05-04-2011, 12:20 PM Thread Starter
snobrdrkid07
WJ for Life
He is making me mad. It will get fixed eventually. He is in the middle of buying a company and doing the regular taxes. (He's a CPA) so I think he is rreally really busy right now. He doesnt like stuff wrong. He is usually not like this at all. =\
Edit: I will take your advice as I completely agree with you. Makes sense. Dad is just, as stated, really really busy and has been in not the greatest mood lately... the Rubi is by no means a Daily D, its in the 3rd garage chilling with a cover on it.
-Michael-
post #712 of 6785 Old 05-04-2011, 07:14 PM Thread Starter
snobrdrkid07
WJ for Life
I received my OBD II Bluetooth adapter today to go with my Torque app for my android. Works well, read alot of info. I have my home screen setup to read: Intake Air Temp, Coolant Temp, MPH, MPG (instant), Engine Load, RPM's. It is pretty cool to have that display.
Received my Auto-Dim Mirror and its the wrong one, for a ZJ... emailed seller, last time I order from him.
-Michael-
post #713 of 6785 Old 05-04-2011, 07:23 PM
JerzeyBoyWJ
2003 WJ
how does you app display all of that? what did you have to order?
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #714 of 6785 Old 05-04-2011, 07:25 PM Thread Starter
snobrdrkid07
WJ for Life
Ordered this
Using
app. Pretty cool stuff.
-Michael-
post #715 of 6785 Old 05-04-2011, 07:55 PM
JerzeyBoyWJ
2003 WJ
Ordered this
Using Video... More Out there too app. Pretty cool stuff.
thats awesome... 0o how i hate finding new thing i wanna add to my list of things to buy... good thing i don't have a smart phone
post #716 of 6785 Old 05-04-2011, 08:01 PM
Akrobatiks
That's pretty sweet! Il have to look into that!
2001 WJ Limited 4.7L Black on Black --- Interior Modifications... Alpine INA-w900 navigation unit, 2 9-inch headrest LCD's, Alpine PDX-F4 125w x 4 Multi-channel Digital amplifier, Alpine Type - X Component Interior Speakers, Alpine PDX-M12 1200w x 1 Digital Mono Sub Amplifier, 2 MTX - 9510's, Custom built subwoofer enclosure, Sirrius Satellite Radio, Backup Camera, Viper 5901 Remote start/alarm, Passport Escort 9500ci Radar Detector/Laser Shifter, Optima Yellow Top Battery, Cobra 29 LTD BT CB Radio --- Exterior Modifications... 6" Clayton Long arms, Bilstein 5100's, Addco Front and Rear Sway bars, IRO extended rear sway bar links, JKS Trackbar, JKS quicker front disconnects, IRO front upper and lower coil retainers, Rough Country Dual Steering Stabilizers, 17" Fuel Hostage Wheels, 285/70 Goodyear Wrangler Duratracs, Westin Safari bar, PIAA 525 dual beam off road lights, CCFL Halo Projector Headlights w/ Super Vision 6000k HID bulb kit, 100w PIAA 4000k halogen high beams, LED 360 Amber LED signal bulbs, LED Tail Lights, Jet Accu-Speed Computer chip, Flashpaq jeep power programmer, AVS rain gaurds, Yakima 4 Snowboard rack, Curt tow strap receiver mount, Hornblasters Shocker 240 Train Horn Kit, Rigid E-Series 40" LED light bar, Mean Green H.O. Alternator, JCR Stage 3 Sliders, Blue Torch d30/d44a diff covers, KOR Steath rear tire carrier/bumper. LSR winch mount front bumper, Warn xd9000, KOR under Belly skid...
Akrobatiks is offline
post #717 of 6785 Old 05-04-2011, 08:06 PM
straty1987
that devices look cool i might have to order one to play with and its cheap.
did you get the app for free?
i like the seller but his listing are so messed up. have to know what your looking ta really.
he says he has a a rough country 3" kit for WJ sale. rough country dose not make a 3" lift said is just going by the shocks name. coils look after marketer but cant get the high off them and all the other parts look stock its at $81 with 75 shipping.
someone is going to be mad when they really see what they get.
straty1987 is offline
post #718 of 6785 Old 05-04-2011, 08:16 PM Thread Starter
snobrdrkid07
WJ for Life
Thanks man. Haha. Its pretty nifty lol.
Yea! It is pretty cool to have some info like that. Can also read codes etc an clear them!
Got a cheapy adapter. Its not bad. App has a free and paid version.
Yea I saw that lift too. I LOL'd. And true on the seller.
-Michael-
post #719 of 6785 Old 05-04-2011, 08:43 PM
JerzeyBoyWJ
2003 WJ
those are RC coils ... unless they are just painted silver stockers
post #720 of 6785 Old 05-04-2011, 09:05 PM
straty1987
anything possible he just going by the shocks name.
but RC only have 4" springs and 2" pucks
i would bid but not worth the chances
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
