Snobrdrkid's WJ Build Thread - Page 442 - JeepForum.com
post #6616 of 6785 Old 07-09-2014, 11:02 AM
Thomahawk
^^^Thats the one, from my old green WJ, 2000 model, it should mount up easy, you should have it in about a week i believe.
Buildthread
Thomahawk is offline
post #6617 of 6785 Old 07-09-2014, 11:32 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Nice man! There are so many radiator setups over the 5 years and 6 and 8 Cylinder engines. It'll be nice to toss it in there!
This is all that I think is right.
I6's:
99-03: Had a Radiator and Trans Cooler in one and then a the AC condenser. E-Fan only unless it has the tow package which included the mechanical fan.
2004: Has a "Coolant Only" main radiator and the AC condenser is split between the Trans fluid and the Refrigerant. E-Fan only unless it has the tow package which included the mechanical fan.
V8's:
99-01: Radiator with Trans cooler in one, AC condenser up front. Mechanical Fan, E-Fan, or Both?? Tow packaged added the small power steering cooler on the driver's side.
02-04: Radiator with Trans cooler in one, AC condenser up front. Hydraulic Fan with the large power steering cooler on the passenger side with metal lines. Tow package added??
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6618 of 6785 Old 07-17-2014, 10:53 PM Thread Starter
snobrdrkid07
WJ for Life
Got the power steering cooler from Thomahawk today, it is in great shape.
I've got some OEM Chrome tow hooks coming soon too. Once I get everything here, I'll pull the front bumper and fascia and do all that at once. I'd like to try and reroute the ATF cooler lines if I can find space.
-Michael-
post #6619 of 6785 Old 07-27-2014, 11:04 AM
Cirruslydakota
Following in my footsteps I see Although there are differences since I'm a 99 and you're an 04.
Made my own "4.0 Class V towing package" by adding the 99 V8 power steering cooler and adapting the 2000 V8 power steering/hydraulic fan cooler as a aux transmission cooler. Its a tight space to work in but all the lines run through the same area. Works well and keeps temps cool during heavy towing or mountain climbing.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #6620 of 6785 Old 07-27-2014, 11:44 AM Thread Starter
snobrdrkid07
WJ for Life
Ha, I sure am following down that way! Only difference is my transmission fluid runs through the AC condenser and the radiator is 100% coolant. Do you have any insight or pictures on how you hooked up the power steering cooler?
-Michael-
post #6621 of 6785 Old 07-27-2014, 11:59 AM
Cirruslydakota
Its been a few years since I did it but these pictures from the FSM should help for now. Ill take some pictures for you when I go out later.
Those are from my 99 service manual so itll probably be different depending on how the transmission lines for your cooler run on yours. Remember, mine has the cooler in the radiator so the lines are tucked close to the radiator out of the way.
Bear - 99 WJ Laredo
post #6622 of 6785 Old 07-27-2014, 12:22 PM Thread Starter
snobrdrkid07
WJ for Life
Thanks for that, I also found this picture. Which I am going to try and follow. I bought a new piece of line with a fitting on it and about 12" of hose. Thinking of running the new hose to the cooler and using old hose from the cooler back to the reservoir.
-Michael-
post #6623 of 6785 Old 07-27-2014, 02:14 PM
Cirruslydakota
These should help since they show the original hose routing when it was an option on the 4.0.
Bear - 99 WJ Laredo
post #6624 of 6785 Old 07-28-2014, 10:13 AM Thread Starter
snobrdrkid07
WJ for Life
I bought this to go from the steering box to the cooler. However I am thinking of taking the line of the reservoir and putting that on the cooler and getting more PS line and running it from the cooler to the reservoir.
-Michael-
post #6625 of 6785 Old 07-30-2014, 05:10 PM Thread Starter
snobrdrkid07
WJ for Life
Finally topped off the coolant reservoir with some Zerex G-05 HOAT, only been a little low for a year. Added about a half gallon to bring it up to the "Full".
Got some sweet factory chrome tow hooks from a good friend, 04Overland47. Going to replace the junk hooks that are on there, harbor freight special.
Hopefully I can get the power steering cooler in this weekend too.
-Michael-
post #6626 of 6785 Old 08-03-2014, 12:11 PM Thread Starter
snobrdrkid07
WJ for Life
Things accomplished Saturday
1. The new oem tow hooks on, old ones were bad and rusted nor were they factory.
2. New Mopar serpentine belt. The dealer was the closest. Easy to do, it was the original belt with 124k on it
3. Air box is actually fasten down now. Lost a nut prior and it had be squeaking.
4. Added more rubber wrap around the trans cooler lines. Peace of mind there
5. Power steering cooler. Hmmm, with the way my factory transmission lines run to the air con condenser I don't think the metal hard lines will fit. So no power steering cooler as of now.
6. Dad scratched the grille by dragging it across the garage floor on accident. Ughhhh
7. Glued some of the header panel back together that had been cracked, minor.
8. Cleaned air filter with air compressor. Been using the wix paper air filter and it's been good.
9. Tried moving the SS bracket closer in. Couldn't bend it enough for the larger diameter of the tie rod and the bolt was hitting the rod. Will have to source another clamp.
Productive weekend.
-Michael-
post #6627 of 6785 Old 08-03-2014, 01:11 PM
ChrisHager
Administrator
ChrisHager's Avatar
Sounds like a busy weekend!
I wouldn't sweat it. I have to watch scratching the J-10 with my belt buckle and clipped on pocket knife. The worst is my cowboy boots clipping the rocker panel when I get in. It is chipped up quite a bit. Oh, country lifestyle...
Heat is worth its weight in gold...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6628 of 6785 Old 08-03-2014, 01:19 PM Thread Starter
snobrdrkid07
WJ for Life
It was, but it was good.
I'm going to try some rubbing compounds or something to try and buff it out. Not the end of the world just wasn't ideal.
Clarifying, I was able to bend it enough to remove it from the tie rod. The issue was the holes weren't low enough for the bolt to pass through. The bolt was bottoming on the tie rod bar. Tried drilling the clamp holes but wasn't enough without taking off a lot of material. I can draw a crude picture later. And I'll post pictures this evening as well.
-Michael-
post #6629 of 6785 Old 08-03-2014, 02:26 PM Thread Starter
snobrdrkid07
WJ for Life
No, I don't know how the radiator support got bent! Lol
-Michael-
post #6630 of 6785 Old 08-27-2014, 06:55 PM Thread Starter
snobrdrkid07
WJ for Life
Rubicon Lift, WJ UCA's
Few things to update with the WJ. 300 miles in about 5 hours, between 55 and 70 mph cruising, loaded, averaged about 18.4 hand calculated. No issues to really report just had one bridge that really upset it and made the Jeep shimmy for a couple seconds. Tires are riding smooth, quiet, and show little wear. I need to rotate them, its been 6700 miles.
Waiting on the last hardware to come in from Fastenal for the UCA's. Ordered Class 10.9 Flange bolts and nuts in the appropriate size for the UCA axle mount. The torx bolt head is stripping, (my bad when I tried to do it by myself once). I don't know if it is a locking nut that I ordered. I developed a consistent thud/clunk going over dips, bumps, manhole covers, from the front driver's side. Have to check Jam nuts on the lowers, and hopefully the UCA's will take care of it. Plan on inspecting WB's and BJ's again with the tires off.
In other news I have been ordering a lot of parts for the Rubicon.
- OME HD's, we've got bumpers front and rear with a the winch
- Bilstein 5100's
- OME Rear TB Bracket
- Moog STB SS
- Undercover Fab "Extra Clearence" skid 1/4" steel with Air Pump bracket
- Lo Pro Trans mount so we can use the Extra Clearence skid with no body lift.
Next up hopefully will be some Control arms, JKS Disco's, and 33" Kevlar MT/R's
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
