Snobrdrkid's WJ Build Thread - Page 441 - JeepForum.com
post #6601 of 6785 Old 06-04-2014, 03:24 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Actually did something productive today. Greased the slip joint for the rear drive shaft. All the "stop bump" or whatever it is called is gone. Finally did a simple project and it fixed the problem! Imagine that. Usually doesn't happen.
Really wasn't much grease on it before.
U joints looked okay for the miles, no play.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6602 of 6785 Old 06-10-2014, 10:14 PM
NOVAXJ
Thats funny, I was down in OBX the same time you were. Too bad I didnt see that before!
NOVAXJ is offline
post #6603 of 6785 Old 06-10-2014, 11:40 PM Thread Starter
snobrdrkid07
WJ for Life
Oh dang, I didn't see your Jeep. Where were you at, Corolla?
Ordered some HIR1 Bulbs for the fog lights. They cross reference a 9005 which also can be wiggled into the 9145 for light slot. I've been running 9005's in there and its been great but, want to try something new.
Bought 7 Quarts of Mobil 1 5w-30 and the PL30001 oversized filter. Hoping the 5w-30 will be a little thinner for cold starts.
-Michael-
post #6604 of 6785 Old 06-19-2014, 05:34 PM Thread Starter
snobrdrkid07
WJ for Life
Updates for the past week or so:
- Changed the oil the other day with the thinner stuff. Didn't help at all with the cold starts... Oh well. Sent an oil sample to blackstone, we'll see what that says. Expecting nothing good to come from it.
- The HIR1 Bulbs are nice, a little brighter than the 9005 Sylvanias I had.
- Replaced the Moog SS, it was rusting bad and crappy. Didn't have much resistance to it after 1.5 years, junk. That boot killed it, should have not used it. Both the moog and the new one, are not "long enough" because of where the bracket mounts on the Moog Tie Rod setup... I can hit the steering stops turning left but can feel the SS stopping me from turning hard over right.
- Also took the time to check the TB bolt and wailed on that while I was under there. Greased the tie rod ends too.
- Lastly I keep blowing the damn fuse for the rear wiper and the interior lights. I have no idea why but it has blown about 5 times now in the past couple months.
-Michael-
post #6605 of 6785 Old 06-19-2014, 09:19 PM Thread Starter
snobrdrkid07
WJ for Life
Things I need to do:
1. Install the freaking IRO Adjustable UCA's that I bought 6 months ago.
2. A-arm spacer
3. BJ's and WB's
-Michael-
post #6606 of 6785 Old 06-20-2014, 07:04 AM
ChrisHager
Administrator
ChrisHager's Avatar
Fingers crossed...
You're the first to have something bad to say about the Moog SS! As far as I know, my Rancho SS is still doing its job after ~2.5 years...
That doesn't seem right. Have you considered moving it up like I did? You can mount it 'just right' if you do.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6607 of 6785 Old 06-20-2014, 07:12 AM Thread Starter
snobrdrkid07
WJ for Life
Originally Posted by ChrisHager View Post
Fingers crossed...
The sample is getting there today. I have a very slight hope because the OPDA thing was replaced.
I was almost not going to say anything, upsetting the status quo with the Moog. Even out of the box it had air in it and you could hear the bubbles. I am not the only one to say this either.
I don't know why this is but its been like this since I did the tie rod upgrade. The Moog Tie Rod SS mount point is more outboard than the factory. I don't think the clamp will go over the thicker part of the bar either. When full left there is still an 1.5-2" of silver rod showing.
-Michael-
post #6608 of 6785 Old 06-20-2014, 07:34 AM
ChrisHager
Administrator
ChrisHager's Avatar
Well, I've heard whispers that Moog's quality is diminishing. If this is true, hopefully they get their issues straightened out and start making a part worth buying.
With a hammer, some pliers, and a little fire, anything fits.
Weird. What brand did you replace the Moog SS with? Just curious.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6609 of 6785 Old 06-20-2014, 07:39 AM Thread Starter
snobrdrkid07
WJ for Life
Sadly I have heard the same, don't know what the heck is going on there.
HA! I am sure that would get the job done.
I went with the RC-X 2.2 SS, had it on my floor for months. It is the same extended length as the Moog too. Did a side by side. Its bigger than the Moog and stiffer.
-Michael-
post #6610 of 6785 Old 06-20-2014, 08:24 PM Thread Starter
snobrdrkid07
WJ for Life
-Michael-
post #6611 of 6785 Old 06-21-2014, 06:40 AM
ChrisHager
Administrator
ChrisHager's Avatar
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6612 of 6785 Old 06-21-2014, 07:32 AM Thread Starter
snobrdrkid07
WJ for Life
The "Love-Hate" meter is now leaning a little more towards "love" haha.
Actually made my day when I read that, sometimes its the little things!
-Michael-
post #6613 of 6785 Old 07-08-2014, 11:29 PM Thread Starter
snobrdrkid07
WJ for Life
Been tearing about the rear hatch panel, looking for signs of a bad wire. I keep popping the #8 Fuse for the rear wiper and the interior lights. Couldn't find anything wrong, voltage drop between the batter and the power lead was less than 0.1 volts. Heard some things that the rear wiper motor can appear okay but be going bad internally. Just the petty stuff.
Got a factory Power Steering Cooler coming to me all the way from Norway! Thanks Thomahawk!
-Michael-
post #6614 of 6785 Old 07-09-2014, 10:35 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
If it is the early style (small aluminum cooler with barb fittings) it will be easy to install. If it is the late style (large cooler, hard mounted with metric threaded fittings) it will be a horrendous ***** to install and I honestly wouldn't bother. You don't need one anyway.
~Richard
billzcat1 is offline
post #6615 of 6785 Old 07-09-2014, 10:53 AM Thread Starter
snobrdrkid07
WJ for Life
I believe it looks like this pictured below, I am getting it for free and actually haven't seen a picture of it!
I probably need a new high pressure line as well, starting to get wet and possibly a drip or two.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
