Snobrdrkid's WJ Build Thread - Page 44 - JeepForum.com
post #646 of 6785 Old 04-30-2011, 01:33 PM
straty1987
Originally Posted by snobrdrkid07 View Post
The jeep isn't really sagging more then I just have a lot of stuff in there and it seems to sit a bit lower then it should.
Parents just don't want me spending money. I guess that's the main problem there.
I really am tempted to just order a BB but I really want springs. Uhh
i understand i like the springs too but they cost almost double then spacers and spring cost allot to ship.
if you look can get a deal i picked up 2" BB and MX6 shocks for a bit over $300 shipped. but still looking at 2" springs since you can add 3/4 spacers for a taller lift. would like a 3" lift but dose not work for me since its 90% DD.
going to see ho 2" lift dose verses stock at the park and re think after that in July
straty1987 is offline
post #647 of 6785 Old 04-30-2011, 04:24 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Ahhhh wow that is not a bad deal at all!
I just feel like if I order spacers, I am somehow going to screw up something and get some crappy DW or something like that.
So have we talked about your stroker at all? Even if we did I still want to talk about it. hahahaha. I could totally do that without mom noticing
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #648 of 6785 Old 04-30-2011, 11:53 PM
straty1987
yea hard to pass it up. shocks only had over 1K miles on them too. guy was selling his WJ lift for his TJ axle since it broke
spacers are not hard. just jack up the jeep and disconnect whats need to remove the spring. take out spring, take out coil isoltor, spacer on top then isolator then spring again.
if you can get upcountry coils can get about an extra inch
i really need to start a build tread and get the time to install things but i don't have a garage so i do the work on my street and first have to get the spot inform of my house
post #649 of 6785 Old 05-01-2011, 07:28 AM Thread Starter
snobrdrkid07
WJ for Life
Spacers require an alignment?
I do a lot of work at home to. Stuff that can be done at home. Oil, tire rotate. Simple things.
-Michael-
post #650 of 6785 Old 05-01-2011, 08:37 AM Thread Starter
snobrdrkid07
WJ for Life
Ok I have some initiative going. Here is what is up. Mom said I can look into a 2" lift. I told her it just gives it a bit more aggressive look and doesn't mess anything up (hopefully)
Here is where I need opinions:
1. I am 99% sure I will NEVER (in the next few years at least) go over 2 inches. ---> Springs or Spacers?
2. Shocks? Skip the "no-name" shocks, wait till my current skyjackers blow and get some bilsteins? ---> yes or no?
3. Track-Bar? ---> chart says it is not needed, but what do you all think. Gonna be enough to mess anything up?
4. Control Arms ---> Need new CA??
5. Isolators ---> I do not think my iso's are that bad... I am loosing a bit of ride height b/c of my subs and crap in trunk being like 200 pounds and the stock springs are soft.
6. WHERE TO ORDER ---> I have a 10% off coupon right now on eBay. (that expires by the end of may 1st) Fat bob's, or ... ?
Thank you!
-Michael-
post #651 of 6785 Old 05-01-2011, 08:44 AM Thread Starter
snobrdrkid07
WJ for Life
Fat bob's Coils only shipped ---> 253.20 (with FB military coupon ---> 232.20, I have family in military, idk if that counts)
Ebay fatbob's only coils shipped (w/ my 10% coupon) ---> 255.52
-Michael-
post #652 of 6785 Old 05-01-2011, 02:56 PM
straty1987
some people do it others don't. better to be safe and just do it from the get go.
might want to look into the lifetime alignments for places like Firestone. its like $80 and as long as you own the jeep they will do it at no charge
i was planing on install my shocks with the jeep on the ground one day and then doing the spacers another day since i might not be able to get it done in one shot on the street.
it can be done http://www.jeepsunlimited.com/forums...d.php?t=512721 just might take a bit longer
post #653 of 6785 Old 05-01-2011, 02:59 PM
straty1987
Thank you!
if your springs are go just get spacers to save money and get good shock
if you shock are at stock hight they will blow at some point but might be a year down the road. just skip the cheap ones and get a good set. if you can buy them now might be able to sell teh current ones you have.
for the isolators just jack up the jeep and take off the wheel to look at them. 200lbs is not allot to have sag
FB has the better prices and your getting it form the direct company. join there mail list since they send out 10% off coupons now and then
post #654 of 6785 Old 05-01-2011, 05:43 PM Thread Starter
snobrdrkid07
WJ for Life
I think we did it with a jack and a jack stand with the skyjacker shocks
if you shock are at stock height they will blow at some point but might be a year down the road. just skip the cheap ones and get a good set. if you can buy them now might be able to sell the current ones you have.
The springs are okay, I just dont like how soft they are...
-Michael-
post #655 of 6785 Old 05-01-2011, 07:35 PM
Bama_WJ
Bama_WJ's Avatar
If you can wait, I'll have my BB and NIB JKS track bar for sale after my Claytons go on.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #656 of 6785 Old 05-01-2011, 07:53 PM Thread Starter
snobrdrkid07
WJ for Life
Springs or spacers?
Interested... YES. haha
-Michael-
post #657 of 6785 Old 05-01-2011, 07:56 PM
SnowLeopard
If you just want a couple inches of lift, I'd go with OME HD coils and MX-6 shocks. That's what I'm wanting to do on my ZJ, only the ZJ variety, of course.
SnowLeopard is offline
post #658 of 6785 Old 05-01-2011, 07:57 PM Thread Starter
snobrdrkid07
WJ for Life
LOL... Keep dreaming... I am trying to work with about 200-250 dollars..
-Michael-
post #659 of 6785 Old 05-01-2011, 08:00 PM
SnowLeopard
I've been working toward this goal for years myself, and my philosophy is do it right, or don't do it at all. But I'm not sure of the quality of BDS coils, and a lot of people run them. They might be pretty good. I just know OME are the best. I hope you can come to a decision. I'd say at this point you already know what you want to do though...
However, you really shouldn't go against your mom considering you're so young and still live with her.
post #660 of 6785 Old 05-01-2011, 08:01 PM Thread Starter
snobrdrkid07
WJ for Life
Painted the tow hooks today, I got bored
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
