Snobrdrkid's WJ Build Thread - Page 438 - JeepForum.com
post #6556 of 6785 Old 03-24-2014, 11:37 AM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Black Ground wire and Orange/White wire broke in the driver's boot... I am angry, it's been fixed once already.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6557 of 6785 Old 03-24-2014, 11:39 AM
ChrisHager
Administrator
ChrisHager's Avatar
Fix it again! Haha. That happens. It's a thick wire and bending thick wires isn't good... Sucks though.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #6558 of 6785 Old 03-24-2014, 11:43 AM Thread Starter
snobrdrkid07
I'm running out of wire to work with. I am doing a crimp in the door and running new wire all the way inside to another crimp connector. Hopefully this wire I am splicing will last longer...
-Michael-
post #6559 of 6785 Old 03-24-2014, 11:58 AM
ChrisHager
Administrator
ChrisHager's Avatar
Try soldering? It's a pain but that's what I did and so far, so good...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6560 of 6785 Old 03-25-2014, 08:39 AM Thread Starter
snobrdrkid07
Don't have my soldering gun here at school. I made a connection in the boot and then ran new wire all the way into the body where I made the second connection. Hopefully that will help.
-Michael-
post #6561 of 6785 Old 03-25-2014, 08:59 AM
ChrisHager
Administrator
ChrisHager's Avatar
That might do it for ya!
Does the Torque app actually tell you when the fan kicks on or do you literally just stand aside and wait until it turns on? I was going to check it for you this morning but I couldn't find a widget dealy in the app that would notify me when the fan kicked on.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6562 of 6785 Old 03-25-2014, 09:00 AM Thread Starter
snobrdrkid07
The wire was so brittle and sun damaged too!
Oh, going to have to just wait for it to kick on and then look at the temp reading.
-Michael-
post #6563 of 6785 Old 03-25-2014, 09:13 AM
ChrisHager
Administrator
ChrisHager's Avatar
Roger that!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6564 of 6785 Old 03-25-2014, 05:36 PM Thread Starter
snobrdrkid07
Thanks man!
You jinxed me with the Power Steering, Chris. I am leaking a bit of fluid around the high pressure line fitting.
-Michael-
post #6565 of 6785 Old 03-25-2014, 09:35 PM
ChrisHager
Administrator
ChrisHager's Avatar
Oh no!!! I looked mine over and I think it may be a leaky line too...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6566 of 6785 Old 04-11-2014, 05:04 PM
Thomahawk
How is things going with you and your Jeep Michael? Long time, no update,,,?
Buildthread
Thomahawk is offline
post #6567 of 6785 Old 04-12-2014, 03:10 AM Thread Starter
snobrdrkid07
It's been running good recently, I still have some slight lifter tick on the cold morning until it warms up and pumps up. I just figured I am going to let that go, warmer weather has helped stifle that issue. I've had IRO UCA's sitting on my floor since December and a RC-X steering stabilizer on the floor too. My Moog SS bushing kinda blew out and are soft. I've just been driving it and putting gas in it, kinda nice to just enjoy it recently. Took that road trip in the end of February and that was fun.
Now that warmer weather is happening, I'll be more likely to tool around.
-Michael-
post #6568 of 6785 Old 04-16-2014, 10:55 AM Thread Starter
snobrdrkid07
Eating my words with everything being good, although i knew this was going to eventually happen. I'm getting a clunk feeling through the floorboard on the drivers side where the left foot rest pad is. I've checked the jam nuts on the LCA's. I've never ever done anything with the front uppers... I'm wondering if the upper frame side bushings took its last beating. I notice it on bumpy roads where I'd assume it'd be doing the most work, also sometimes when on the brakes hard I'll feel it. Ohhhh fun.
-Michael-
post #6569 of 6785 Old 04-16-2014, 07:16 PM Thread Starter
snobrdrkid07
Finally got a wrench out for the WJ. Checked all the LCA bolts, the Driver's side, frame side bolt, was "loose". Well I had my wrench set at 140 lb-ft and I was able to turn before it clicked a few times. For comparison, none of the other 3 bolts were able to turn before clicking. Didn't test drive after that but will post back later.
Went on a cruise
-Michael-
post #6570 of 6785 Old 04-17-2014, 08:39 PM
ZJPunk98
Anything wrong with your bushings? I see you torqued the loose bolt, good.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
