Snobrdrkid's WJ Build Thread - Page 435 - JeepForum.com
post #6511 of 6785 Old 02-16-2014, 01:40 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I wish I had the Quadra-Drive system with a 242 in place of the 247
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6512 of 6785 Old 02-16-2014, 01:56 PM
Thomahawk
^^^Yeah, That would be the ultimate upgrade combo.
I actually have a 242 from a ZJ just laying around, idk if that would Work though.
Got to love the LSD diff in snow, best there is
Buildthread
Thomahawk is offline
post #6513 of 6785 Old 02-16-2014, 02:01 PM Thread Starter
snobrdrkid07
WJ for Life
Even the open/open combo in my WJ did great in the snow while the TJ and LJ were getting stuck! Only thing that was concerning was that when the front dug and tried to grab it'd sometimes "hop" and create a hell of a banging/rattling. Only when the front tire(s) were hopping. This was when I was in 4 Part-Time or 4 Full Time, in the snow. What was happening was the front was trying to grab so it was loading the tire, then it'd break the snow pack and drop down and then bind/load up again. Then doing that on repeat. I was able to grab the front output yoke on the t-case and shake that thing around... up and down movement. I *don't* think it is supposed to have that kind of slop in it.
-Michael-
post #6514 of 6785 Old 02-16-2014, 02:16 PM
Thomahawk
Nah, That slop should be there, any highway vibs?
Buildthread
post #6515 of 6785 Old 02-16-2014, 02:17 PM Thread Starter
snobrdrkid07
WJ for Life
Above ~70-75 mph i'll get slight vibes...
-Michael-
post #6516 of 6785 Old 02-16-2014, 02:36 PM
Thomahawk
^^^Time for a 247 upgrade, or if lucky only yoke or smaller parts, didnt you Get a new rebuildt front DS when you did the lift?
Buildthread
post #6517 of 6785 Old 02-16-2014, 09:00 PM
SnowLeopard
I agree with Thomahawk regarding the 247 being superior to the 242. Even if he is perhaps having fun with you here. Though I like being able to lock in 4wd-high, the LSD function is superior to the open diff of the 242. Running a torsen diff in the 4Runner I'm currently driving I've come to appreciate not having an open diff in the middle. It's as much night and day better than having an open diff in an axle. Still, the 242 is a great option. I'd just not prefer one over the 247 knowing what I know now.
The downside is waiting for it to respond to slippage where as the 242 is always splitting torque when engaged in full-time. That and the 247 requires a lot more upkeep. Of course, your 242 is not without its associated issues, as you are seeing.
SnowLeopard is offline
post #6518 of 6785 Old 02-17-2014, 02:13 PM Thread Starter
snobrdrkid07
WJ for Life
I've been getting better with it the past couple days too. Learning how to finesse it in and out of 2wd/4wd with improvement. I do like having the Full Time option so I can not worry about binding on the road while the conditions aren't "bad" enough to warrant Part Time. Also part time doesn't like to steer, being it locked in the center.
-Michael-
post #6519 of 6785 Old 02-17-2014, 03:06 PM
Thomahawk
Thats the Nice thing with the QD center, it doesnt look up and goes straight forward when throttled in curves, the locked ones keeps to "push" the front wheels straight forward.
When the QD seems to push out the rear so the front wheels goes into the curve not out. My old S10 Blazer was like locked, the QD behavious in a whole different matter, like you Are able to stear the rear end with the Throttle, like drifting cars.
Buildthread
post #6520 of 6785 Old 02-17-2014, 05:12 PM
SnowLeopard
Without binding as in full lock a lsd center diff will allow your vehicle to actually pull you through a turn, steering, yet allowing differential movement so you don't understeer as you would with full lock. I'm not sure if this is how QD works, but I know torsen diffs do this. Getting used to the idea of pushing through a turn instead of laying off the gas takes a little getting used to.
post #6521 of 6785 Old 02-17-2014, 05:38 PM
Thomahawk
^^^Yes that would be how the QD works, kinda like a torsion diff, right.
It pulls you in rather than push you out, hard for me to explain in my poor english.
Buildthread
post #6522 of 6785 Old 02-21-2014, 01:35 PM Thread Starter
snobrdrkid07
WJ for Life
Slathered some grease all over the double cardon joint. Hopefully that shuts it up.
Update, killed the sound for now. Splattered everywhere. Hah.
Update 2. Changed the oil again to start fresh. Going to see if that OPDA was the source of the metal.
-Michael-
post #6523 of 6785 Old 02-25-2014, 04:11 PM Thread Starter
snobrdrkid07
WJ for Life
Passenger side ground wire broke inside the boot as they all do. Spliced in some new wire and called it a day, easy fix.
Changing the oil has seemed to make the WJ unhappy. Since changing, 3 cold (20-40*) start ups have resulted in, assuming valvetrain, noise. Takes a minute or two now for it to stop. Was suggested that oil filter could have a bad back flow valve? Who knows. 1 step forward two steps back.
Secondly, I've mentioned this before but, my oil gets pitch black very quickly. The oil I took out had less than 900 miles and looked like it was 9000 miles old. Suggested to inspect the PCV system for leaks/clogs.
-Michael-
post #6524 of 6785 Old 02-25-2014, 04:18 PM
Thomahawk
Seafoam the shhh out of it!!!
Buildthread
post #6525 of 6785 Old 02-25-2014, 08:45 PM
ChrisHager
Administrator
ChrisHager's Avatar
What filter are you using?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
