Snobrdrkid's WJ Build Thread - Page 433 - JeepForum.com
post #6481 of 6785 Old 02-04-2014, 10:16 AM
Cirruslydakota
Too bad you couldnt ask for the old one back. Id love to take it apart and see what caused the failure considering the OPDA seems to fail in a similar fashion.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #6482 of 6785 Old 02-04-2014, 10:29 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I got another call from the dealer today. They told me the OPDA is hitting the cam sensor itself. So they're replacing the OPDA for about $450, which is the part cost and the new sensor. I swear if they put that horrid assembly on it like the 05/06 TJ's have I'm going to flip out. The 04 and prior OPDA haven't really had these issues.
I'll ask them to keep the old part. If I can get a hold of it, I'll send it your way.
Edit: Called them and requested the keep the old OPDA.
Edit 2: Also called them to make sure they replace the part with the original sensor (Top) and not the craptastic stuff that the 05/06 TJ's have. (Bottom)
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6483 of 6785 Old 02-04-2014, 04:40 PM
Cirruslydakota
If it was hitting the sensor then thats bearing failure. Hmm, I haven't heard of our opda's failing like the wrangler ones especially at the relatively low mileage you have (compared to mine anyway).
Bear - 99 WJ Laredo
post #6484 of 6785 Old 02-04-2014, 05:13 PM Thread Starter
snobrdrkid07
WJ for Life
That is what the dealer said, the OPDA had a bearing failure. This one went at 119k and the Rubicon we have, failed at 42k. Again I requested to keep the old assembly, we'll see if they follow through.
-Michael-
post #6485 of 6785 Old 02-04-2014, 07:00 PM
Cirruslydakota
They should since theres no core charge on it. This is the first failure of our type of opda that Ive heard of.
Bear - 99 WJ Laredo
post #6486 of 6785 Old 02-04-2014, 07:02 PM Thread Starter
snobrdrkid07
WJ for Life
Just my luck! First I've heard of it in the WJ.
I wonder if this bearing failure in the drive was causing excess metal wear to show up in my oil??
-Michael-
post #6487 of 6785 Old 02-05-2014, 03:13 PM Thread Starter
snobrdrkid07
WJ for Life
Got the Jeep back just now, so nice to have a car again, missed it a lot!
Parts:
OPDA, which was different from the 04 WJ parts list PDF that I have. 53010615AB
Thankfully they replaced with the original one and not the crap from the 05/06 TJ's.
**I asked about the old OPDA, they "lost it" : Sorry man.
-Michael-
post #6488 of 6785 Old 02-05-2014, 04:51 PM
Cirruslydakota
No problem, not a big deal.
They lost it...haha, suuuuure...
Also that p/n is correct. The old one was superceded. Probably a design change (due to bearing failures perhaps?).
Bear - 99 WJ Laredo
post #6489 of 6785 Old 02-05-2014, 04:53 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah, no kidding, disappeared into thin air.
Thankfully, no more awful sounds coming from the engine.
-Michael-
post #6490 of 6785 Old 02-05-2014, 04:56 PM
Cirruslydakota
Sometimes we lose stuff in my shop but with everything big and yellow its hard to misplace things.
Bear - 99 WJ Laredo
post #6491 of 6785 Old 02-05-2014, 04:58 PM Thread Starter
snobrdrkid07
WJ for Life
True, who knows. Guess I am ground zero for the WJ OPDA to fail. I still haven't found anyone else yet, albeit didn't search that hard.
-Michael-
post #6492 of 6785 Old 02-05-2014, 06:06 PM
Cirruslydakota
You're the first ive heard of it. Usually its the cmp sensor going bad.
Bear - 99 WJ Laredo
post #6493 of 6785 Old 02-09-2014, 07:33 PM Thread Starter
snobrdrkid07
WJ for Life
Haha, I feel special.
My double cardon joint is squeaking, can I squirt some grease on, in or around the centering ball?
-Michael-
post #6494 of 6785 Old 02-09-2014, 08:17 PM
ChrisHager
Administrator
ChrisHager's Avatar
I dont know why you couldn't...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6495 of 6785 Old 02-10-2014, 07:33 AM Thread Starter
snobrdrkid07
WJ for Life
That's what I figured, I'll see if I can get some grease up in there.
Going to change the oil again, with only ~700 miles on it. Why? Well, I want to know if the OPDA was throwing metal into the oil while the bearing where going out. So, with a new OPDA, I want to get fresh oil and then check the metal wear again. Who knows, maybe that was where some, hopefully most, of the metal was coming from.
Also *really* considering a 2-inch a-arm spacer, based on what I've been reading around the forum.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
