Snobrdrkid's WJ Build Thread - Page 432 - JeepForum.com
post #6466 of 6786 Old 01-28-2014, 02:02 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Let's add this into the mix. Leaving school, I noticed the squeak/tap was intermittent a few seconds after start up and then become steady. Started driving home, came to a stoplight and the Jeep started to bog down at idle, around 250 rpms if I had to guess and was running rough and "chugging" and then died. Fortunately I was able to start it back up and make it a few more miles back home.
Read all the codes and this is what it came up with:
I think that sounds has to be that camshaft position sensor, it fits what is going on, IMO.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6467 of 6786 Old 01-28-2014, 02:18 PM
ChrisHager
Administrator
ChrisHager's Avatar
If I had to guess, I'd agree with your hypothesis. If I hadn't just taught class last night and therefore was not still in 'instructor mode', I'd have said something along the lines of 'Yup, slap a new one of those spinny timing dealies on there and see if she fires up!'.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6468 of 6786 Old 01-28-2014, 02:52 PM Thread Starter
snobrdrkid07
WJ for Life
Lets hope I am right this time around.
Booked an appointed the Dealership for Monday, oh joy.
-Michael-
post #6469 of 6786 Old 01-28-2014, 05:18 PM
Cirruslydakota
T6 only comes in 5w-40 flavor (full synthetic). T5 is a semi synthetic and comes in 10w-30/10w-40 flavors. Its up to you what to run (personally I run T5 10w-30 but with you being up north I'd run T6 especially in this weather).
The problem I have with the OPDA is Chrysler already had the system we use in the Grand Cherokee but didn't use it in the wrangler. Why?
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #6470 of 6786 Old 01-28-2014, 05:59 PM Thread Starter
snobrdrkid07
WJ for Life
Why is T6 only in 5w-40? I like synthetic though, don't know why. Is that too thin? (Need to refresh my self on the oil weight nomenclature)
I wonder why they switched either, doesn't make sense.
-Michael-
post #6471 of 6786 Old 01-28-2014, 06:09 PM
Cirruslydakota
Because these oils (Rotella) are primarily diesel engine oils. T3 is their regular 15w-40 and T6 is their synthetic line.
First number is the cold weight 5 and the second number, 40 is the hot weight. The WJ 4.0 calls for a 10 weight cold oil down to 0 if I'm remembering correctly and below 0 it calls for a 5 weight. Running either a 10 or 5 won't hurt anything (5 will pump faster) and the 30/40 won't hurt either although a 40 weight may cause your gas mileage to suffer a bit due to pumping losses with the heavier oil. If you have valvetrain noise and want those lifters quieter drop in a 40 weight oil.
Also, no Rotella is marked with the "energy conserving" label. I can't remember if Mobil 1 is or not so you may notice slightly worse gas mileage.
Bear - 99 WJ Laredo
post #6472 of 6786 Old 01-28-2014, 09:37 PM Thread Starter
snobrdrkid07
WJ for Life
Thank you for the information, I'll consider pouring in some T6 for the next oil change.
-Michael-
post #6473 of 6786 Old 01-29-2014, 08:56 AM
Cirruslydakota
My 4.0 seems to like it. Every engine is different though.
Bear - 99 WJ Laredo
post #6474 of 6786 Old 01-29-2014, 09:18 AM Thread Starter
snobrdrkid07
WJ for Life
Rust Prevention Step 1: Cover Jeep in Salt. Lol
http://s1220.photobucket.com/user/sn...4_960.jpg.html
Died on me again today, probably shouldn't be driving it.
-Michael-
post #6475 of 6786 Old 01-29-2014, 09:26 AM
ChrisHager
Administrator
ChrisHager's Avatar
Probably not...
Mine is covered almost up to the windows. It's a sad sight...
Click Free:
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6476 of 6786 Old 01-29-2014, 09:28 AM Thread Starter
snobrdrkid07
WJ for Life
Oops, copied the wrong link. Thanks!
I'll bum a ride to class the next few days. Lol
-Michael-
post #6477 of 6786 Old 01-31-2014, 11:11 AM Thread Starter
snobrdrkid07
WJ for Life
Drove to class this morning, started fine. Went to leave and it would crank but not catch. It's done.
Called for a tow truck and they got it out of the parking spot, in the parking garage. Front tires of the ground and real wheels still on the ground. Well I forgot to put the transfer case in neutral. Tow truck driver, while pretty nice, didn't seem to think that was an issue and I didn't think much of it. Well too little to late, reading around, turns out that wasn't the best.
So the Jeep will get looked at Monday and they'll do a diagnostic thing and go from there. Already $200 in for the tow in the diagnostics. Hopefully they won't have to add a transmission into that repair list.
Couldn't get a loaner car because I'm not 21, nice and pissed there. I asked if I could buy a new Grand Cherokee for a week.
-Michael-
post #6478 of 6786 Old 01-31-2014, 04:14 PM
Thomahawk
Drove to class this morning, started fine. Went to leave and it would crank but not catch. It's done. Called for a tow truck and they got it out of the parking spot, in the parking garage. Front tires of the ground and real wheels still on the ground. Well I forgot to put the transfer case in neutral. Tow truck driver, while pretty nice, didn't seem to think that was an issue and I didn't think much of it. Well too little to late, reading around, turns out that wasn't the best. So the Jeep will get looked at Monday and they'll do a diagnostic thing and go from there. Already $200 in for the tow in the diagnostics. Hopefully they won't have to add a transmission into that repair list. Couldn't get a loaner car because I'm not 21, nice and pissed there. I asked if I could buy a new Grand Cherokee for a week.
Good luck man, hope its an easy fix and not to expensive
Buildthread
Thomahawk is offline
post #6479 of 6786 Old 02-03-2014, 03:18 PM Thread Starter
snobrdrkid07
WJ for Life
Got a call back from the dealership, fortunately, I was right. Bad cam sensor, causing the knocking/squeaking sound, and the no-start conditions. Along with the rest of the codes. Damage was only $250 all said in done. (Plus $85 for towing, but the insurance covered that.)
Fingers crossed this does it, and the transmission isn't messed up from towing.
-Michael-
post #6480 of 6786 Old 02-03-2014, 03:38 PM
Thomahawk
Glad to hear that, Thumbsup
Buildthread
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
