Snobrdrkid's WJ Build Thread - Page 431 - JeepForum.com
post #6451 of 6785 Old 01-27-2014, 08:35 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I'll see if my same friend has one, probably does. It was dark, cold, and were short on time, I just wanted him to look at it quickly. But will see if I can do that this weekend.
How does these stout 4.0's go like this, I'm a bit more disappointed that even well taken care of it is shatting a brick.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6452 of 6785 Old 01-27-2014, 10:17 PM
Cirruslydakota
When i pulled my lifters out they had gone from being convex to concave but not worn through. Can lobes looked pretty good along with everything else. I know the TJ guys have opda problems but our distributor drives seem to hold up well. As far as im aware mines the original one. If you pull it out you'll have to re sync your injectors.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #6453 of 6785 Old 01-27-2014, 10:36 PM Thread Starter
snobrdrkid07
WJ for Life
We had our ODPA fail on the trail in the 05 LJ. Looks like Chrysler replaced it with the same POS part that'll fail again. I've been reading about that whole ODPA thing since you posted about it.
Read through a lot of this http://www.jeepforum.com/forum/f9/20...ilure-1144202/
Now that I've read some more, and watched these videos, my noise seems similar?
What do you all think?
How complicated is it to do that? I thought you needed the DRBIII tool to do it?
-Michael-
post #6454 of 6785 Old 01-28-2014, 06:04 AM
ChrisHager
Administrator
ChrisHager's Avatar
Removal and installation only takes 15 minutes. Syncing it requires the DRBIII tool. If you install it correctly, you'll have no issue driving it to the dealer for the sync.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now
post #6455 of 6785 Old 01-28-2014, 08:25 AM Thread Starter
snobrdrkid07
WJ for Life
Well, at that rate. I might consider just having them deal with it. Removing and replacing.
-Michael-
post #6456 of 6785 Old 01-28-2014, 10:08 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
They aren't as bulletproof as everyone thinks. Time spent on this forum should reinforce that.
~Richard
billzcat1 is offline
post #6457 of 6785 Old 01-28-2014, 10:25 AM
Thomahawk
^^^X2, maintainance is a preventive move, not a security for that nothing will ever brake down.
Both 4.7 and 4.0's have their problems, i realize that now after i have been around for awhile.
Still around
Anyway, worst case scenario,,, an engine swap down the Road aint to much to worry about,
The 4.0 is easy to pull, weekend project
Buildthread
Thomahawk is offline
post #6458 of 6785 Old 01-28-2014, 10:37 AM Thread Starter
snobrdrkid07
WJ for Life
Well you're right on that one. Granted the majority of 4.0 problems were the 99-01 cracked heads. But in its defense, my other Jeep likely has over 330k miles on the 4.0 and its still going, somehow.
Did you take a look at the recent two videos I posted? I swear, it sounds like its squeaking more than tapping.
-Michael-
post #6459 of 6785 Old 01-28-2014, 10:41 AM
ChrisHager
Administrator
ChrisHager's Avatar
Agreed. Remember my lifter incident after 87k? The PO had regular oil changes done by the dealer. Ironically, I later found out the dealer changed a lifter (not plural) for the PO at 66k (and a 242 at 80k??). Most likely, they didn't pull the camshaft and inspect the lobes. My 87k failure was probably due to Jeep's cheap fix (thanks, Jeep ).
That being said, why the failure at 66k? I have heard a time or two about these 4.0s eating lifters which negates 'bulletproof', especially considering the work involved requires removing the head.
I'm not trying to dog these things and I love mine but as said, they aren't indestructible, just as the 4.7 can drop valve seats if overheated. Both are great and neither are perfect!
Anyway, camera wasn't being kind that day but you get the point.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6460 of 6785 Old 01-28-2014, 10:55 AM Thread Starter
snobrdrkid07
WJ for Life
Thomas, I guess all you can do is maintenance and get lucky from there on. I would have never thought my Jeep would eat a lifter (*presumably*) with 120k and strict maintenance. I've been following your thread about your new 4.7 HO having issues too.
Chris, I didn't know that a lifter had been previously replaced before you had to do the tear down. Well, I don't even have words to say for that one. Shoot, how the heck did the blow the transfer case, I don't know if someone was abusing it or the dealership was ripping said person off.
The motors are great, but nothing is perfect. Actually my check engine light went away for the IAC and the Cam Position Sensor/Crank Position Sensor. Is the camshaft or lifter iron? Wonder if that was the source of the high metal?
I've got a few options, in order of likelihood:
1. Drive it, try to determine lifter or Cam Pos Sensor, then ignore it
2. Drive it and replace the Cam Position Sensor Assembly
3. Rebuild the motor, along with the trans
4. New motor, stroked
-Michael-
post #6461 of 6785 Old 01-28-2014, 11:15 AM
ChrisHager
Administrator
ChrisHager's Avatar
With that squeak and the code, I'd guess CPS over lifter but that's all speculation without actually diving in. I wouldn't ignore it though as that second video showing the noise in sync with the engine rpm sounds crappy...
Edit: The only thing I can think of with my transfer case is the PO possibly thought Part Time was for on road and Full Time was for off road. Ultimately, the vehicle was in great shape when I bought it - nice enough that I guessed it was soccer mom driven and garaged parked.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6462 of 6785 Old 01-28-2014, 11:21 AM Thread Starter
snobrdrkid07
WJ for Life
Yeah, I am going to call the dealership today or tomorrow. Gonna have them put in a new Cam Sensor Assembly.
-Michael-
post #6463 of 6785 Old 01-28-2014, 11:25 AM
Cirruslydakota
Due to oil being changed so much in the last 10-15 years id say anyone with a flat tappet motor needs to pay close attention to the oil they use. In the case of our 4.0's running a HDEO is the best thing to do (Nothing special either like synthetic). The 4.7 guys dont have to worry with the same issue so any 5-30/10-30 works for them. As far as the OPDA issue goes I havent seen or heard many problems with our type of drive causing issues like what the TJ guys haveto deal with. Not saying its not possible but pulling it out and checking it wouldnt be a bad idea by any means. Only downside is seting the sync perfect but if you punch mark the drive base and the block then you should be able to get it back in almost exact. I recently aquired a Snap-on solus ultra and it does fuel sync but its $2,600 so its not pratical unless youre a mechanic (I am.)
Bear - 99 WJ Laredo
post #6464 of 6785 Old 01-28-2014, 11:32 AM
ChrisHager
Administrator
ChrisHager's Avatar
Rotella T-5 10W-30
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6465 of 6785 Old 01-28-2014, 11:36 AM Thread Starter
snobrdrkid07
WJ for Life
I've been running the high(er) dollar Mobil 1 10w-30 Full Synthetic High-Mileage for the added ZDDP content in it. However, it has been brought to light that they have changed their formula for the oil. Sadly, lessening the ZDDP content which is no good for us with the 4.0's. I've heard of people running Rotella T6 10w-30, which I think is synthetic. Does the T6 have a lot of ZDDP and a HDEO? Maybe I will make the switch over to that. My last oil analysis had 900 whereas a year ago it was over 1000. Think I should look into switching to Rotella?
Edit 2: Mobil 1 says that the High Mileage, Synth, 10w-30 should still have 1100 ZDDP PPM whereas my last oil sheet said 900. pdf sheet link
The 05/06 TJ/LJ OPDA was an insane problem, never really knew about it. Untils the OPDA on the 05 LJ busted with 42,000 miles on the odometer. (This happened a few months ago in October). Because of the tools needed to do it properly, scanners, etc. I'll just have the big Jeep dealer up by school deal with it.
Edit: 10 Best Engines of the Last 20 Years. Looks what came in 8th place! haha
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
