Snobrdrkid's WJ Build Thread - Page 430 - JeepForum.com
post #6436 of 6785 Old 01-07-2014, 06:39 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by Thomahawk View Post
Shhh, sounds almost like my engine tick, mine is just not That bad, but sounds the same just yours louder i believe.
Sounds terrible but at least it goes away. My first guess is the exhaust leak, then second would be some sort of valve train noise.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6437 of 6785 Old 01-09-2014, 07:29 PM
Thomahawk
Something like this?
Buildthread
Thomahawk is offline
post #6438 of 6785 Old 01-09-2014, 07:34 PM Thread Starter
snobrdrkid07
The 4.7's have an exhaust manifold that breaks of some sort. That can cause the noises that you are hearing. Check that bolt in the back and do some more research on that. BUT, that just doesn't sound like an exhaust leak, I'd pull the cover man, sounds like something internal is going on. Is yours constantly doing that? Does it go away?
Mine has not made any nasty noises since I posted that video, it is really hit and miss!
-Michael-
post #6439 of 6785 Old 01-09-2014, 09:23 PM
compcrasher86
You guys sure thats coming from the engine? Sounds a lot like the Evap purge solenoid to me, exact same frequency. Worth checking at least, get a mechanic's stethoscope and poke around. Or if it changes when you give it a little bit of gas then its not the solenoid like I thought.
Matt
compcrasher86 is offline
post #6440 of 6785 Old 01-10-2014, 02:16 AM
Thomahawk
Min is Deff not purge solenoid, That is ruled out, 2 guys with stetoscop have listened, coming from valve cover.
Buildthread
post #6441 of 6785 Old 01-10-2014, 10:03 PM Thread Starter
snobrdrkid07
Time to pull the valve cover then. Keep us posted.
-Michael-
post #6442 of 6785 Old 01-16-2014, 05:19 PM Thread Starter
snobrdrkid07
Oil
I give up.... geshhh!
-Michael-
post #6443 of 6785 Old 01-21-2014, 01:11 PM Thread Starter
snobrdrkid07
Got some snow around VT.
New tires are great!
-Michael-
post #6444 of 6785 Old 01-26-2014, 02:31 PM Thread Starter
snobrdrkid07
This sounds like fun....
https://www.youtube.com/watch?v=WU-xNf9ilC8
-Michael-
post #6445 of 6785 Old 01-26-2014, 02:48 PM
Thomahawk
And familiar, havent got any parts yet to try to cure my tick
Sound like valve tick, have you got around to locate it with a stetoscop?
Is it consistent or only at cold start ups?
Buildthread
post #6446 of 6785 Old 01-26-2014, 03:27 PM Thread Starter
snobrdrkid07
Sometimes I'll have an exhaust leak sound on cold starts, that *will* go away when it warms up. I drove around and this sound, that is different, didn't go away when it warmed up. Upon further investigation, it sounds like the CPS is making this noise. I was able to put my finger on it while running, I could feel a scrape/vibration as it spun, which coincided with the squeaking/tapping sound it was making in the video.
Anyone know what is making the whistling sound in the video? Can't figure that out.
-Michael-
post #6447 of 6785 Old 01-27-2014, 08:10 AM Thread Starter
snobrdrkid07
Okay, so my theory of the CPS making the tapping/squeaking sound, may not be that far off. I got a code this morning for P1391. (Also have a P0505, which has popped up and gone away a few times now)
P1391 (M)
Intermittent Loss of CMP or CKP
Loss of the Cam Position Sensor or Crank Position sensor has occurred.
Maybe the CPS is having a bad time? Oh, I am not sure if I am confusing the terminology but I am referring to what I am feeling/hearing making noise is the sensor thing about the Oil filter, which I think is the Cam Position Sensor. Thoughts?
-Michael-
post #6448 of 6785 Old 01-27-2014, 07:00 PM Thread Starter
snobrdrkid07
Here is another video:
Had a good friend listen to it, in person, and he suggested the same. Could be the Cam/valve train of possibly the Cam Position Sensor once he was able to physically touch it. But, also said that the lifter could be transmitting vibration up through the Cam Pos Sensor as well. So I am going to look into replacing the Cam Sensor first and then go from there. Really isn't a great time to have to tear down a motor.
-Michael-
post #6449 of 6785 Old 01-27-2014, 07:04 PM
Thomahawk
Replace cam sensor first,,,
This along with the CPS , sets the ingnition timing, if this aint correct you might Get valve noises,,,,,
Buildthread
post #6450 of 6785 Old 01-27-2014, 07:32 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Get a mechanic's stethoscope. They are about $10 and will help you track down the noise much much better. Invaluable tool IMO.
TBH though it sounds like a lifter/cam lobe got chomped up, 4.0 style.
~Richard
billzcat1 is offline
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
