Snobrdrkid's WJ Build Thread - Page 427 - JeepForum.com
post #6391 of 6785 Old 12-02-2013, 09:10 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
10-4. I didn't see the need for the wider tires and extra 0.5" of height. I should be okay then for the 99% streeting then. Just the only thing will be the front lowers, no tight turns!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #6392 of 6785 Old 12-02-2013, 12:36 PM
Thomahawk
Originally Posted by billzcat1
I would go with the 245/70-17 myself. There's no need to go wider unless you have a very specific need for floatation - and wider tires tend to have drawbacks like tracking in ruts as well as a greater impact on fuel mileage + acceleration (due to increased weight and wind resistance). Plus it fits in the spare tire well nicely. As for the rubbing - mine will rub the rear shocks when wheeling although it seems to be a non-issue now with the Moabs - which have 1/4 less backspace than stock WJ 17s. If you are having rubbing issues, a set of 1" wheel spacers might be a good idea - and will fill out the wheel wells nicely. I've wanted a set for years now but haven't been able to justify it when there are other more pressing issues, both WJ- and life- related.
Good point, i didnt think about he is on stock wheels, Wider rims, and/or different BS is indeed needed to Go Wider, spacers Are a great idea to solve rubbing with factory rims.
Buildthread
Thomahawk is offline
post #6393 of 6785 Old 12-08-2013, 11:29 PM Thread Starter
snobrdrkid07
WJ for Life
Gonna go with the less expensive size and save myself the money from wheel spacers
-Michael-
post #6394 of 6785 Old 12-09-2013, 07:38 AM
Thomahawk
Good idea, Good tires and safty Are more important than looks, Go Get new tires, you will love it.
Buildthread
post #6395 of 6785 Old 12-09-2013, 11:45 AM Thread Starter
snobrdrkid07
WJ for Life
Ordering at the end of the month.
Picked up some of these on black Friday sale.
-Michael-
post #6396 of 6785 Old 12-19-2013, 07:10 PM Thread Starter
snobrdrkid07
WJ for Life
I finally made it home for Winter Break! Going to really enjoy this month off.
Took the same route home as I did for Thanksgiving break and did even better on fuel economy, somehow. I had the Jeep packed full, more so than when I was going home in November. But, this time I managed the EVIC to read out 23.2 MPG for the whole trip, about 2 MPG better than last time. Took the same route, had more in the Jeep this time, and probably drove harder. The difference? SuperChips. I did significantly better on fuel economy without the SuperChips tune, (It was tuned for 87 performance). So that was a surprising result but, makes sense because the Superchips is probably trying to stuff more fuel in there. I know the EVIC is a "rough" number but mine reads about 1.3-1.5 mpg high. Nonetheless, without a tune fuel economy improved. Shoot, the EVIC even said I was going to get a 500 mile range.
Secondly, I have been trying to track down a clunk from the passenger side front area for the past month or two. I went over everything that I could think of and check it all out. Could not find anything loose or making a noise when visually inspecting, had tire off the ground and shaking it, etc. Mind you that I have "checked" the Jam nuts on my control arms before. But when I pulled in the driveway tonight, something made me go check the passanger side again. Sure enough, after 300+ mile highway trip it was hand loose and I could spin it freely. I have a feeling that is the culprit for the clunk. I hope I didn't ruin the threads or anything in that nature but there is still 95% engagement, the arms are almost as short as they can go. Time to bring out the big 'ol wrench tomorrow, (and maybe some thread locker?)
-Michael-
post #6397 of 6785 Old 12-19-2013, 08:07 PM
ChrisHager
Administrator
ChrisHager's Avatar
I used a big wrench and some thread locker on my track bar jam nut. That seemed to do the trick.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #6398 of 6785 Old 12-19-2013, 10:44 PM Thread Starter
snobrdrkid07
WJ for Life
I guess it is time to find a big wrench! What type of loctite would be best for this? Figuring something that can be broken loose if need be.
-Michael-
post #6399 of 6785 Old 12-20-2013, 01:32 AM
Thomahawk
Blue loctite for getting it loose again, red if not.
Have a Nice holyday Michael
Buildthread
post #6400 of 6785 Old 12-20-2013, 09:55 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Ugh, no Loctite on service items. You think pulling off a 24mm x 1.5mm jam nut is going to be fun with Loctite on there? No way. I'd go the opposite route - anti-seize and then torque the F out of that guy. There's no reason for it to come loose other than mis-torquing in the first place. For me, the 24" crescent wrench (aka: Knucklebuster 3000) is the one for this job.
~Richard
billzcat1 is offline
post #6401 of 6785 Old 12-20-2013, 10:28 AM
ChrisHager
Administrator
ChrisHager's Avatar
This is a good point. The first time mine came loose, I imagine it was from not being tight enough in the first place. I know it isn't going anywhere but I'll have issues in the future busting it loose.
Knucklebuster 3000 - nice! Haha! :-)
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6402 of 6785 Old 12-20-2013, 12:37 PM
billzcat1
2003 WJ
Mine also came loose twice on both the JKS track bar and the JKS tie rod. Once was my fault, the other was Firestone's fault.
~Richard
post #6403 of 6785 Old 12-22-2013, 11:33 AM Thread Starter
snobrdrkid07
WJ for Life
I got myself a big pipe wrench and just took as much force as I could to it. It wouldn't go any further regardless if I put any more pressure on it. It sure fixed the clunking, pretty happy it was simple. Just took me awhile to figure it *what* was clunking.
-Michael-
post #6404 of 6785 Old 12-23-2013, 10:43 AM Thread Starter
snobrdrkid07
WJ for Life
Tires are finally ordered! Got the Silent Armors in 245/70-17's!
-Michael-
post #6405 of 6785 Old 12-23-2013, 11:26 AM
Thomahawk
^^^Thumbsup M!!! You will like them
Buildthread
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
