Snobrdrkid's WJ Build Thread - Page 424 - JeepForum.com
post #6346 of 6785 Old 10-18-2013, 10:03 AM
ChrisHager
Administrator
ChrisHager's Avatar
If this is like the PIR, I'm going to guess 4527. Haha! :-)
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #6347 of 6785 Old 10-18-2013, 10:24 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
~Richard
billzcat1 is offline
post #6348 of 6785 Old 10-18-2013, 10:30 AM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Haha! ^
Hint, still too low.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6349 of 6785 Old 10-18-2013, 10:40 AM
billzcat1
2003 WJ
Last time I weighed mine it was 4560 curb weight - empty but full of all fluids and fuel. So add 2 people and a bag of tools we're at about 5000.
Now theoretically the base curb weight for an I6 Laredo is about 400 lbs lighter than an Overland, hence where I got my estimate from. But maybe those figures for curb weight are wrong...oh plus you have a system in there.
4680.
~Richard
post #6350 of 6785 Old 10-18-2013, 10:47 AM Thread Starter
snobrdrkid07
Definitely on the right track, still a little low. Actually, the numbers in your last guess are correct, just in the wrong order. The scale rounds to the whole 10's place.
-Michael-
post #6351 of 6785 Old 10-18-2013, 11:16 AM
ChrisHager
Administrator
ChrisHager's Avatar
Haha I got a kick out of that, Richard!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6352 of 6785 Old 10-18-2013, 01:07 PM
billzcat1
2003 WJ
4860?!
~Richard
post #6353 of 6785 Old 10-18-2013, 01:10 PM Thread Starter
snobrdrkid07
Originally Posted by billzcat1 View Post
4860?!
Yup, tipped the scales at 4860 pounds haha. That's pretty much my daily driving weight. Loaded down I don't even want to know haha.
-Michael-
post #6354 of 6785 Old 10-18-2013, 04:14 PM
billzcat1
2003 WJ
So that's still more than 4400 curb. Why so heavy? Sounds like a real workout for the 4.0.
~Richard
post #6355 of 6785 Old 10-18-2013, 04:38 PM Thread Starter
snobrdrkid07
This is the first time that I have ever put in on a scale to get a real number. I was expecting it to be heavy but, not quite this much.
Here are my best guesses:
3970 = Base Laredo 4.0, 4wd, curb is weight according to WJJeeps.com.
124 = 19 gallons x 6.5 pounds/gal
350 = Passenger Weight
65 = 15x2 subs + box + 2 amps
50~ pounds of tools, compressor, junk, etc
4559 = Total
Where the added weight comes in, no clue. Sunroof, tow package, upgraded seats? No idea.
Probably a decent factor in poor(er) than most city fuel econ. Lots of weight to lug with a heavy foot.
-Michael-
post #6356 of 6785 Old 10-24-2013, 10:19 AM Thread Starter
snobrdrkid07
P0505 - IAC Motor Code popped up today. Don't know why, everything is running fine. Only difference was, on the usual start up it will rev to 1500 rpms and immediately drop down to normal idle. This time it just jumped to 1000 or so on start up and threw a code. Went to start it a few more times today and was normal. Probably just going to clear the code and not worry about it.
-Michael-
post #6357 of 6785 Old 10-24-2013, 10:50 AM
ChrisHager
Administrator
ChrisHager's Avatar
You could pop it off and clean it up a bit. It may be sticking on some gunk...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6358 of 6785 Old 10-24-2013, 11:46 AM Thread Starter
snobrdrkid07
Possible, although its only like 2 years old. When I broke my original IAC by cleaning it, I replaced it with an AutoZone IAC. That is likely getting ready to hit the fan. I'll get a Mopar Sensor if this one fails.
-Michael-
post #6359 of 6785 Old 10-30-2013, 03:18 PM Thread Starter
snobrdrkid07
Replaced the stock hardware that the Moog Tie Rod clamps came with. Replaced with Grade 8 bolts, washers, and nylock nuts. Wish I would have went a size bigger though. At Least now the washers are keeping the nuts from burrowing into the clamps.
-Michael-
post #6360 of 6785 Old 11-20-2013, 11:31 PM Thread Starter
snobrdrkid07
Picked up some *new* Moog front sway links from a forum member.
Made it home from school today.
290 Miles,
5:14 drive time,
21.9 MPG, peaked at 23.0 at one point.
Got about ~230 miles to half a tank.
Cruised at about 65 avg mph
Jeep did good for the most part, few big bumps threw it for a loop. Santa needs to bring me tires, early!
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
