Snobrdrkid's WJ Build Thread - Page 423 - JeepForum.com
post #6331 of 6785 Old 10-04-2013, 07:59 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
No, they are not.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6332 of 6785 Old 10-05-2013, 06:25 PM Thread Starter
snobrdrkid07
WJ for Life
Waiting on the Relays still for the fan.
Finally got around to changing the oil in the WJ. Nothing is ever easy, dropped the old filter into the very full oil pan... That made a big ol mess, I was pissed. Used a whole roll of shop towels to get as much as possible off the ground. After that ordeal, put the drain plug back on, filled up the new filter with oil, and topped it off with 5.9 quarts. (Will check level later, I always thing 6 quarts is just a tad much). There was about 4,700 miles on this OCI and the oil was BLACK! Sending off a sample to Blackstone on Monday and I am not looking forward to the results.
Drove around the Rubicon this weekend because the coolness factor is way higher than the WJ. I get a lovely check engine light. P0412, awesome. Seems like something is up with the Cat after the fact it was glowing hot when the jeep wasn't starting and it is currently rattling. Honeycomb structure could have bit the dust.
"P0421 OBD-II Trouble Code
Technical Description - Warm Up Catalyst Efficiency Below Threshold (Bank 1) - Which was the cat that was glowing...
What does that mean? - Basically this means that the oxygen sensor downstream of the catalytic converter on bank 1 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
Symptoms - You will likely not notice any drivability problems, although there may be symptoms. The code may be more likely to occur after the engine has had numerous cold starts in the past 1-2 days.
Causes - A code P0421 may mean that one or more of the following has happened:
*The catalytic converter is no longer functioning properly
*An oxygen sensor is not reading (functioning) properly
*A spark plug is fouled up
Also, the cam position sensor gear snapped off the shaft, that was the official initial problem. It also managed to damage the hole according to the service records. The new Cam sensor is massive, probably as big as the Mopar Oil filter, really different from the one I have on the WJ (and what was originally in there). Turns out the coil rain was not replaced after all but, the spark plugs were. Don't know how in the world the camshaft sensor managed to snap.
-Michael-
post #6333 of 6785 Old 10-07-2013, 11:19 AM Thread Starter
snobrdrkid07
WJ for Life
Put in the new fan relays... andddd nothing. Even with the AC running. Ambient is only 65 and the engine was at operating temp after driving. Who knows.
Anyone have any insight to this?
-Michael-
post #6334 of 6785 Old 10-08-2013, 11:45 AM Thread Starter
snobrdrkid07
WJ for Life
This may be why the e-fan is not kicking on, not even getting hot enough. For whatever reason, this are the coolant numbers for my Jeep.
I was driving up and down the mountain roads and the hottest the coolant got was ~195 as you can see. I've read elsewear that the e-fan won't even kick on till just under ~210
-Michael-
post #6335 of 6785 Old 10-09-2013, 07:25 AM
ChrisHager
Administrator
ChrisHager's Avatar
Sounds like your thermostat is sticking open...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #6336 of 6785 Old 10-09-2013, 09:03 AM Thread Starter
snobrdrkid07
WJ for Life
: Is that also characteristic of taking a while to warm up on cold starts?
-Michael-
post #6337 of 6785 Old 10-09-2013, 09:04 AM
ChrisHager
Administrator
ChrisHager's Avatar
Yep. Your heat won't be quite as warm either.
Edit: Check out this post in my build thread and a few following it (you were the one commenting! ). You may notice other symptoms once they're pointed out to you. http://www.jeepforum.com/forum/f197/...l#post15157175
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6338 of 6785 Old 10-09-2013, 09:08 AM Thread Starter
snobrdrkid07
WJ for Life
For comparison how long does it take your Jeep to reach operating temperature? How hot does your jeep run?
Also how do I fix this?? :/
-Michael-
post #6339 of 6785 Old 10-09-2013, 09:11 AM
ChrisHager
Administrator
ChrisHager's Avatar
I think mine is up to temp in a few-ish minutes and I believe runs around 210F or a little lower.
Per fixing, it's super easy - two bolts on the thermostat housing and shazam! The thermostat and gasket are extremely cheap as well.
Here you can see the thermostat housing removed and the thermostat still installed (top front of the head).
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6340 of 6785 Old 10-09-2013, 09:17 AM Thread Starter
snobrdrkid07
WJ for Life
I've got a ~3 miles commute and on an average day it takes about 10 minutes with lights, traffic, etc. Summer, I really don't pay attention because it's hot and I've got AC blasting. I'm barely getting up to operating temp after maybe 8 minutes of driving on a mild day, 50-60's. On winter days, I'll be in the parking garage by the time it finally gets to 195...
I always thought that they put in a cooler thermostat when it was replaced in January. But, recalling last winter and this information now, it seems like my heat was never as hot and it took seemingly forever to warm up.
-Michael-
post #6341 of 6785 Old 10-15-2013, 03:11 PM Thread Starter
snobrdrkid07
WJ for Life
Thanks again for information Chris. I'll bookmark this post if a future incident arrises. I went back and I believe the put a cooler thermostat in for whatever reason.
On a much more sad note. (Click for full size image to read it)
This blows...
-Michael-
post #6342 of 6785 Old 10-15-2013, 03:24 PM
ChrisHager
Administrator
ChrisHager's Avatar
Hmmm... That's not good and is quite odd as well. Any thoughts on what may be causing that much engine wear?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6343 of 6785 Old 10-15-2013, 03:39 PM Thread Starter
snobrdrkid07
WJ for Life
My best guess, while I regretfully admit this, I used to do a lot of wide open throttles while the engine was still very cold. There would be countless days I'd be late for class during the winter, and as a result the engine seemed to have taken a ton of abuse. Other than the engine not getting the lubrication needed while cold and under heavy load, I do not know what else would cause this.
-Michael-
post #6344 of 6785 Old 10-18-2013, 12:43 AM Thread Starter
snobrdrkid07
WJ for Life
Weighed the WJ. Had an almost full tank of gas, 2 occupants, and a bag of tools in the trunk. Any guesses? Winner gets nothing haha.
-Michael-
post #6345 of 6785 Old 10-18-2013, 08:55 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
4526lbs.
~Richard
billzcat1 is offline
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
