Snobrdrkid's WJ Build Thread - Page 422 - JeepForum.com
post #6316 of 6785 Old 09-30-2013, 09:18 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
A bad CPS would cause more of a no-start condition. I'd say coil rail is also a likely suspect.
~Richard
billzcat1 is offline
post #6317 of 6785 Old 09-30-2013, 09:33 AM
ChrisHager
Administrator
ChrisHager's Avatar
True. I was thinking more of if the fuel sync when out. I don't know if that can even happen though on a whim like that.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6318 of 6785 Old 09-30-2013, 09:52 AM
billzcat1
2003 WJ
Cars ran great for 100 years without synchronized/sequential fuel injection. Turns out it doesn't really matter, it just affects the top 5% of power and of course EMISSIONS.
~Richard
post #6319 of 6785 Old 09-30-2013, 09:56 AM
ChrisHager
Administrator
ChrisHager's Avatar
I see what you're saying. I think the reason CPS popped into mind was when mine was out of sync (probably 30 off), it would start/run but ran so rich the cats turned red. Once I realized my mistake, I fixed it up and shazam, all was well! I then had it synced afterwards but you're right - it ran fine before having the dealer sync it. That being said, the only way the CPS could have turned causing it to run rich is if the hold down clamp worked loose. Even then, if for some reason that actually happened, both cats would turn red, not 1.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6320 of 6785 Old 10-01-2013, 02:58 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Still no word on the Rubicon...
However I have been putting my WJ in Full Time about once a week to keep things from seizing etc. I've noticed its easier to shift from 4hi back to 2wd. But man do I get a lot of nasty noises when accelerating. Lol
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6321 of 6785 Old 10-01-2013, 03:05 PM
ChrisHager
Administrator
ChrisHager's Avatar
Oh?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6322 of 6785 Old 10-01-2013, 03:20 PM Thread Starter
snobrdrkid07
WJ for Life
Originally Posted by ChrisHager View Post
Oh?
Vibrations, whining, and groaning. Haha. Probably the pinion and d.s. angle at the axle. Really don't know any way of remedying
-Michael-
post #6323 of 6785 Old 10-02-2013, 02:23 PM
GraKee99
Rapist Wit
GraKee99's Avatar
That doesn't make sense why it would make noise when 4 wheel drive is engaged since you front driveshaft is spinning all the time anyways since you don't have manual hubs.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #6324 of 6785 Old 10-02-2013, 02:31 PM Thread Starter
snobrdrkid07
WJ for Life
Don't know man, just telling it how it is. That's why it has me confused as well.
Update on the Rubicon, coil rail failed, plugs fouled as a result. Also the cam position sensor failed. So new coils, new spark plugs, and a new cam position sensor. First ever "breakdown" in the Rubicon.
-Michael-
post #6325 of 6785 Old 10-02-2013, 03:56 PM
gcjeeping
gcjeeping's Avatar
Maybe because the its under a load when in 4wd vs not.
_____________
gcjeeping is offline
post #6326 of 6785 Old 10-02-2013, 03:59 PM Thread Starter
snobrdrkid07
WJ for Life
That is when it is the worst... under load.
-Michael-
post #6327 of 6785 Old 10-03-2013, 07:01 PM Thread Starter
snobrdrkid07
WJ for Life
Checked more on the electric fan. Found another thread where the e-fan on the 04's is controlled only by a hi and low relay in the PDC box. Jumped the fan and it kicked on. Wonder if both relays just blew, as unlikely as that sounds. Going to order some new relays tonight.
Also "fixed" the brakes, did a few very hard stops and heated them up big time and then let them cool. Made a noticeable difference in reducing the vibrations. Almost completely gone.
Here are some new "chirps" haha
-Michael-
post #6328 of 6785 Old 10-04-2013, 07:14 AM
ChrisHager
Administrator
ChrisHager's Avatar
Check your front driveshaft U-joints.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6329 of 6785 Old 10-04-2013, 07:55 AM Thread Starter
snobrdrkid07
WJ for Life
Better not be that, front d.s. has maybe a few thousand miles on it. :/
-Michael-
post #6330 of 6785 Old 10-04-2013, 07:56 AM
ChrisHager
Administrator
ChrisHager's Avatar
Are they grease-able?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
