Snobrdrkid's WJ Build Thread - Page 421 - JeepForum.com
post #6301 of 6785 Old 09-12-2013, 08:44 AM
ChrisHager
Administrator
ChrisHager's Avatar
Haha I think you misunderstood. I had drilled rotors. They warped so I had them turned.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #6302 of 6785 Old 09-12-2013, 08:47 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Oh wow how did I completely fail at that. Guess between lecture, JeepForum, and solitaire... to much multi tasking.
But I was under the impression you could not turn drilled rotors.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6303 of 6785 Old 09-12-2013, 08:59 AM
ChrisHager
Administrator
ChrisHager's Avatar
That may be the case. I was a little less informed when I was younger. You gotta' start somewhere though!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6304 of 6785 Old 09-12-2013, 09:40 AM
Thomahawk
Ha ha, i didnt try to say it was a problem, and ofcourse the front ones make more effect.
I know the brake split is about 70/30 for a motorcycle,
I would believe its lower for a car, maybe about 60/40.
Idk about if they can be turned though.
I am just a stupid electrician, lol
Buildthread
Thomahawk is offline
post #6305 of 6785 Old 09-13-2013, 05:43 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah not too sure on the brake split!
Picked up 6 Quarts of Mobil 1 10w-30 Full Syn High Mileage at Wal-Mart for $33, not too bad. I've got my Mopar Filter as well. Oil change... woo-hoo so exciting. Will be sending off another oil sample for testing.
-Michael-
post #6306 of 6785 Old 09-16-2013, 11:57 AM Thread Starter
snobrdrkid07
WJ for Life
Uh ohhh! Bought another Jeep! --> http://www.jeepforum.com/forum/f177/...build-1591745/
-Michael-
post #6307 of 6785 Old 09-16-2013, 12:32 PM
Thomahawk
Originally Posted by snobrdrkid07
Congrats man
Buildthread
post #6308 of 6785 Old 09-18-2013, 04:07 PM Thread Starter
snobrdrkid07
WJ for Life
Thanks Thomas!
Back to the WJ... I noticed that my E-Fan is AGAIN NOT WORKING!!! (had the hood up and jumper cables on and somehow managed to see it not spinning, anyways). So I check the fuse by the battery and it was blown, replace the fuse and still nothing. Even when I put the AC on the E-Fan won't kick on. The Jeep was definitely warm, it has been idling for probably 30 minutes or more.
Although I have no idea how long the E-Fan hasn't been working. The Jeep stayed at 195* all summer and never had an overheat issue, thanks to the Mechanical Fan.
I do not know if the relay for the E-Fan is under the pass headlight in the 04's still or what. I noticed a Hi and Low Relay in the box by the battery so maybe one of those controls the fan?
-Michael-
post #6309 of 6785 Old 09-19-2013, 08:54 AM
compcrasher86
Thanks Thomas! Back to the WJ... I noticed that my E-Fan is AGAIN NOT WORKING!!! (had the hood up and jumper cables on and somehow managed to see it not spinning, anyways). So I check the fuse by the battery and it was blown, replace the fuse and still nothing. Even when I put the AC on the E-Fan won't kick on. The Jeep was definitely warm, it has been idling for probably 30 minutes or more. Although I have no idea how long the E-Fan hasn't been working. The Jeep stayed at 195* all summer and never had an overheat issue, thanks to the Mechanical Fan. I do not know if the relay for the E-Fan is under the pass headlight in the 04's still or what. I noticed a Hi and Low Relay in the box by the battery so maybe one of those controls the fan?
Blew a fuse? The motors probably locked up or worn out to a point where its got more drag than its supposed to and now its drawing more current than its supposed to, if it'll even turn on. Recommend new fan and new relay at the same time if you have the relay under the headlight there.
Matt
compcrasher86 is offline
post #6310 of 6785 Old 09-19-2013, 09:14 AM Thread Starter
snobrdrkid07
WJ for Life
It is a brand new fan assembly, less than a year old, like 8 months. Better not be shot...
-Michael-
post #6311 of 6785 Old 09-19-2013, 09:59 AM
compcrasher86
Mopar?
Matt
post #6312 of 6785 Old 09-19-2013, 10:05 AM Thread Starter
snobrdrkid07
WJ for Life
Mopar?
Maybe. Not sure.
Turns out in the 2004's the fan relay is infect in the PDC and not under the headlight. +1 for the 2004s
Maybe I need to check/test/replace those hi and low relays.
-Michael-
post #6313 of 6785 Old 09-29-2013, 10:05 PM Thread Starter
snobrdrkid07
WJ for Life
Well, finally had an opportunity to take the Rubicon off-roading. Didn't turn out so well at all. Started out on the trail, got about 30 minutes in to wheeling, then shut it off for a broken rig a few ahead of us.
Everything was running perfect before that, nothing was out of the ordinary. We come back to start it after it had been sitting for ~20 minutes, then sh** hit the fan. Started up, kinda, idling at ~300 rpms very very rough, sputtering, and coughing from the intake. Giving it some gas did nothing to help. Upon inspection, nothing was out of ordinary, visually loose, etc. Fluids were all fine. Only thing that was out of the ordinary visually was the pre cat for Cylinders 1-3 was glowing red hot. Then it also smelled like a "cold morning start up".
Long and crappy day short. We strapped it out of trail, thankfully we didn't make it any big obstacles. Then flatbed towed about 2 hours to a local dealership around where I am at. They'll have it until its fixed I guess. No idea what is wrong with it. I've gotten suggestions as far as a clogged cat and a failed coil. Other than that, no idea. Sucks, but what can you do. Will post when I find out more.
-Michael-
post #6314 of 6785 Old 09-30-2013, 06:12 AM
ChrisHager
Administrator
ChrisHager's Avatar
That sucks. My thoughts are clogged cat or bad coil rail as well. I thought perhaps bad CPS but if it were causing it to run too rich, both cats would be glowing red.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6315 of 6785 Old 09-30-2013, 09:06 AM Thread Starter
snobrdrkid07
WJ for Life
Those seems to be a general consensus thus far. Maybe I'll hear something from the dealer today.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
