Snobrdrkid's WJ Build Thread - Page 418 - JeepForum.com
post #6256 of 6785 Old 08-14-2013, 07:34 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Yeah hopefully. If I give up, I'll go aftermarket heated seats and just switch out the heating pads.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6257 of 6785 Old 08-15-2013, 08:48 AM Thread Starter
snobrdrkid07
WJ for Life
I've noticed a rear end clunk over speed bumps at very reasonable and slow speed. I was thinking that there was no way I blew out the new a arm in under 10k mikes, especially being because it is a Mopar a arm.
I know the sway links squeak but don't clunk
Its not the shocks
Maybe its the lower control arms? I know the axle side bushings aren't stellar... could that make it clunk?
-Michael-
post #6258 of 6785 Old 08-15-2013, 08:54 AM
Thomahawk
Its not the shocks
My endlinks clunkled to tell me they where shot,
And check swaybar to axle bushing, my energy/Addco upgraded bushing didnt last long before needed replaced, just saying.
Buildthread
Thomahawk is offline
post #6259 of 6785 Old 08-15-2013, 08:55 AM
JerzeyBoyWJ
2003 WJ
Its not the shocks
Check the output shaft on the t-case ...my t-case needs a rebuild and when ever I hit a bump the output shaft clunks
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #6260 of 6785 Old 08-15-2013, 10:07 AM Thread Starter
snobrdrkid07
WJ for Life
Yeah I've had the "clunk stop" on the Jeep where the slip yoke on the t-case would make noise
Maybe I'll check for up and down play on the slip yoke too.
Thomas, I don't think it is the end links, they're fairly new.
The Jeep is also so obnoxious going from P to R or D to R. So clunky too.
-Michael-
post #6261 of 6785 Old 08-15-2013, 11:25 AM
compcrasher86
Well that's pretty normal between the gears the D35s have a bit of diff slop in them you can't avoid.
Matt
compcrasher86 is offline
post #6262 of 6785 Old 08-15-2013, 02:10 PM
ChrisHager
Administrator
ChrisHager's Avatar
Mine does it too. U-Joints look solid. I've heard it's a normal thing.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now
post #6263 of 6785 Old 08-15-2013, 02:22 PM Thread Starter
snobrdrkid07
WJ for Life
I guess the slop is normal, that is pretty sad.
I'll see if I can get a video of the LCA bushing play in the rear. Otherwise just going to have to deal!
-Michael-
post #6264 of 6785 Old 08-15-2013, 02:33 PM
Thomahawk
The new Girly Jeep have this to coming to a stop, seemed to Get better after TC fluid change from ATF>Magic 247 fluid,
mine have this alitte but not so often, and just when put into D, i might suspect TC case and or yokes Are worn.
For you snobrdkid, it might be yokes or worn transfer case chain thinghy, or just the sloppyniess off the D35
Ok, if nothing Ells shows up bad, i might settle with this as a explanation, but idk about the D35.
Oh, phu thx, good to hear
Buildthread
post #6265 of 6785 Old 08-15-2013, 03:09 PM Thread Starter
snobrdrkid07
WJ for Life
Got this little thing in the mail today.
-Michael-
post #6266 of 6785 Old 08-15-2013, 04:24 PM
Thomahawk
Might That be a heated seat switch harness with plug???
Buildthread
post #6267 of 6785 Old 08-15-2013, 04:29 PM Thread Starter
snobrdrkid07
WJ for Life
That'd be exactly what that is!
-Michael-
post #6268 of 6785 Old 08-15-2013, 04:34 PM
Thomahawk
Very Nice indeed, whats next?
Buildthread
post #6269 of 6785 Old 08-15-2013, 05:08 PM Thread Starter
snobrdrkid07
WJ for Life
Upcoming stuff...
I've got measure my front lowers for a member who got IRO lowers.
I want to check out my rear lower bushings.
Grease my sway links and stuff behind there.
Check my t-case output shaft.
Maybe look into the heated seat thing. Still iffy on running wires.
Thinking about moving my amps to underneath the rear seats.
Oil change eventually.
-Michael-
post #6270 of 6785 Old 08-18-2013, 07:28 PM Thread Starter
snobrdrkid07
WJ for Life
For Merc
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
