Snobrdrkid's WJ Build Thread - Page 417 - JeepForum.com
post #6241 of 6786 Old 07-28-2013, 05:37 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Dug deeper and I do not have the harness for the heated seats or the switches.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6242 of 6786 Old 07-28-2013, 07:11 PM
Thomahawk
2006 XK Commander
I have the complete wireing diagram for the seats and heat switches on my computer, i Will find it for you, if you would like to just draw your own wires, it shouldnt be to hard, your skilled electro wise.
Buildthread
Thomahawk is offline
post #6243 of 6786 Old 07-28-2013, 07:29 PM Thread Starter
snobrdrkid07
Yeah I guess I am not seeing the bigger picture here? Don't I need the harness to plug into the switches or else nothing would work? I don't get how "tapping into" the PCI Bus wire is going to make the heated seats work?
-Michael-
post #6244 of 6786 Old 07-29-2013, 02:51 AM
Thomahawk
2006 XK Commander
Ok, i will try to explain, you got 12V+ and ground to the seat, the switches Are not open/closed contacts, they Are resistor switches, open in off position, and have a spesific ohm value in high and low position.
So the seat Get a steady/solid 12V+ and ground.
The switches Get 12V but will only send out 0-5V back to the BCM, regarding if they Are in high or low position.
The BCM sends signal to the seat thrue the pci wire to heat the seat in high or low setting.
This is now only regulated by the termostat in the seat so its not overheating/take fire.
The pci wire will Work as your control wire, not by on off but by voltage 0-5V.
Ex, 3V low heat, 5V high heat.
The BCM sends this switches signals/values to the seat (pci cable), so the seat module reconize the signal and feel the termostat, and know what to do, turn on low/high/off.
Hopes this explain some more.
Buildthread
post #6245 of 6786 Old 07-31-2013, 05:29 PM Thread Starter
snobrdrkid07
I am thinking that this heated seat project may be too far out of my comprehension of wiring. Especially leery about tapping into PCI and BCM stuff, that could get nasty. I do not even have the plug to go into the back of the heated seat switches.
-Michael-
post #6246 of 6786 Old 07-31-2013, 05:48 PM
Thomahawk
2006 XK Commander
Cut the plug for switches from a JY.
The wireing is pretty straight forward,
Tapping into the PCI wire is easy, just soldier and heatshrink, nothing can Go wrong with this as Long as you disconect the battery while working on it.
I did this when i hooked up my skim bypass module for the Viper alarm.
You Will only need to draw a pci wire from Seat module to the PCI wire on the radio, so its conected with the BCM and can "comunicate".
And wireing for the switches.
Buildthread
post #6247 of 6786 Old 08-10-2013, 04:52 PM Thread Starter
snobrdrkid07
What signal does the PCI Wire give the seats? IIRC there are like 7 wires that go into each switch.
-Michael-
post #6248 of 6786 Old 08-10-2013, 05:25 PM
Thomahawk
2006 XK Commander
Its a coded signal, where each module have its own identity, so they reconize each other and can comunicate, with data signals, 0 and 1's.
Google bus signal, to advanced for me to explain, but out of the wireing diagram it should be only one wire as i see it.
Buildthread
post #6249 of 6786 Old 08-10-2013, 05:31 PM
Thomahawk
2006 XK Commander
If you mean the heated seat switches, there should be 5 wires going to each switch, refering to the wireing diagram
Wires at switches:
White/Pink (WH/PI), +12V
Black (BL), ground
Orange (OR), bus wire (BCM>switch)
Orange/Black (OR/BL), bus wire (switch>BCM)
Light Green/Red (LG/RD,) bus wire (driver switch>BCM)
Light green/White (LG/WH), bus wire (passenger switch>BCM)
These Are really not bus signals between the switches and the BCM, they Get 12V in and Are resistor switches, sending about ex, 5 and 7V back to the BCM telling the BCM which position the switch is set at.
(I know i have seen a thread with the messuring parameters for the hi/lo setting)
The bus signal is between the BCM and seat module.
Hope this helps out,,,,?
Buildthread
post #6250 of 6786 Old 08-11-2013, 04:32 PM Thread Starter
snobrdrkid07
Yeah that helps out I think. I am going to keep my eyes out for the harness around the JY and Internet.
Problem 2 is that I don't even have a wiring harness going to my passenger seat... like at all.
-Michael-
post #6251 of 6786 Old 08-11-2013, 04:46 PM
Thomahawk
2006 XK Commander
^^^Good
Like you got no power seat at all?
Buildthread
post #6252 of 6786 Old 08-11-2013, 05:05 PM Thread Starter
snobrdrkid07
I have power seats on my pass side. But by my own power and ground source.
-Michael-
post #6253 of 6786 Old 08-11-2013, 05:11 PM
Thomahawk
2006 XK Commander
Uh, yeah, well well,
shouldnt have anything to say, as Long as,,,
the bus wire is wired from the BCM to the Seat module,
And switches to the BCM.
And both Seat have power and ground,
Then you should have everything you need IMO.
Buildthread
post #6254 of 6786 Old 08-11-2013, 05:39 PM Thread Starter
snobrdrkid07
The driver's seat should not be that bad. Since it already has the full harness. Like I just plugged in the new seat base right too it. so that should be good to go.
Breaking it down some more, the DRIVER's switch needs a +12v, ground, Wire to the BCM and a wire from the PCI?
Might have scored a single pigtail for a few dollars on eBay.
-Michael-
post #6255 of 6786 Old 08-12-2013, 01:30 AM
Thomahawk
2006 XK Commander
Cool, i bet you got That heated seat up'n working before i Fix mine, lol
Buildthread
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
