Snobrdrkid's WJ Build Thread - Page 416 - JeepForum.com
post #6226 of 6786 Old 07-22-2013, 09:20 AM
Merc1973
Thanks, that would be great, I replied to your PM prior to reading this post. Dang, I wish i could find a shop that does UNLIMITED alignments, shame they don't adjust it for you...
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6227 of 6786 Old 07-22-2013, 03:02 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Honestly I would rather wrench on the Jeep myself when I can, it will be done right if I am doing it. There have been countless times, with various places where I had to go back and fix what they "fixed".
I have them make sure the toe is set properly with their fancy machine and I can do the rest. That is the only measurement that is the "most difficult" but, still can be done at more. There is no camber adjustment, caster can be adjusted at home, along with the drag link to center the steering wheel.
There are off road shops in my area that'll do control arms but its like $110 for each time you go. I paid $75 for unlimited alignments at a place around the corner from me.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6228 of 6786 Old 07-22-2013, 03:03 PM Thread Starter
snobrdrkid07
WJ for Life
ReCharged the AC system today with the can and gauge. It was "low" according to the gauge, added some and noticed a drop in temperature. Works for me.
Anyone know what makes JKS Control arms so dang expensive over say IRO?
-Michael-
post #6229 of 6786 Old 07-23-2013, 11:22 PM Thread Starter
snobrdrkid07
WJ for Life
Thomas, here are the numbers. Depending if you have memory or not.
-Michael-
post #6230 of 6786 Old 07-24-2013, 06:33 AM
Thomahawk
Thanks man
I am just about to Go pick up the "new" WJ.
Will have to do this Fix on both, very Nice write up Michael.
Edit, here it is>>>
Buildthread
Thomahawk is offline
post #6231 of 6786 Old 07-24-2013, 07:18 PM
wyattwj123
Hey man what headlights do you have and did they come with the bulbs and ballast and everything I like yours alot just need some new ones thanks man?!
wyattwj123 is offline
post #6232 of 6786 Old 07-24-2013, 09:33 PM Thread Starter
snobrdrkid07
WJ for Life
Originally Posted by Thomahawk View Post
Thanks man
Edit, here it is>>>
No problem!
Jeep looks good man. Take some more pictures.
-Michael-
post #6233 of 6786 Old 07-24-2013, 09:34 PM Thread Starter
snobrdrkid07
WJ for Life
Ordered the Housings off Ebay.
I got HID Bulbs and Ballasts from DDM Tuning. www.ddmtuning.com
-Michael-
post #6234 of 6786 Old 07-25-2013, 12:31 AM
Thomahawk
No problem!
Ok, here is some more pics.
Buildthread
post #6235 of 6786 Old 07-27-2013, 11:32 PM Thread Starter
snobrdrkid07
WJ for Life
Great pictures! Looks like you got another great project coming. I do have a power motor with memory that is working if you need it.
-Michael-
post #6236 of 6786 Old 07-28-2013, 03:53 AM
Thomahawk
Yeah thx,
I would very much apriciated if you want to Get rid of That motor,
New Jeep is hers, but i will help with the work and moding
Her wish/Work list is:
Tinted Windows
Wheels tires 255/65/17
3" Kolak exhaust
My old billy's
Rear Addco swaybar
Undercarriage rustprotection
Plastidip or 3M vinyl wood interior
Fix seat motor
Then it will be sweet'n Badass like her, lol
Buildthread
post #6237 of 6786 Old 07-28-2013, 10:41 AM Thread Starter
snobrdrkid07
WJ for Life
I sent you a PM about the motor Thomas.
Well I tried to see if WJ Jeeps were correct in saying that there was a harness pre-wired for the heated seats... well not on my WJ. So that sucks, I do not know what I am going to do now to hook up the factory heated seats. Will have to do more research.
-Michael-
post #6238 of 6786 Old 07-28-2013, 11:06 AM
compcrasher86
What... Check deeper, every WJ I've seen has them just they're tucked into the harness
Matt
compcrasher86 is offline
post #6239 of 6786 Old 07-28-2013, 11:18 AM Thread Starter
snobrdrkid07
WJ for Life
I could not find it. Maybe I wasn't looking in the right spot?
-Michael-
post #6240 of 6786 Old 07-28-2013, 11:30 AM
Thomahawk
I think they should be there too
But you might wire up the pci bus cable,,,
From wjjeeps>>>
Upgrading to power or power/heated seats (Laredo models)
Power or power/heated seats can be added to most WJ's that came with standard seats. The entire seat assemblies will have to be exchanged. All seats use the same bolt pattern so the installation fit will always be exact. For power seat wiring, all that is required is a constant +12V wire and a Ground wire. Vehicles that came without power seats are not pre-wired. For the Ground wire it is probably best to run it over to the center console area where it can be attached to a metal bracket. Do not drill a hole in the floor below the seat. For the power lead, run a wire with an in-line fuse up to the fuse panel area where you can find a + wire to tap into.
Power / heated seats (leather only)
For 1999-2004 Grand Cherokees that came without heated seats the wiring is a little more involved as the heat function is controlled via the PCI Bus and you will be hooking up two seats. Two heated seat switches will have to be purchased and installed in the center bezel. Some center bezels have the holes pre-cut with blank plates installed while others may have to be trimmed out with a dremel type tool. Some owners elect to just purchase a new center console bezel assembly as there are several choices available (with and without ashtray for example). See Interior Trim for a list of part numbers for center bezels.
NOTE: A factory pre-wired harness for the heated seat switches is located behind the center lower bezel in most if not all models that did not have this feature. All you have to do is plug the two harness plugs into the two heated seat switches.
Power / heated seat wiring at the seat location
For the driver's seat, Pin 4 (red) is the 12V lead and Pin 5 (black) is the Ground.
On the Passenger seat Pin 3 (Red/LB) is the 12V lead and Pin 2 (black) is the Ground.
The Ground wires for the two seats should be run together to one Ground location. The power wires for both seats can be hooked together and a single wire with an in-line fuse run to the front fuse box area.
The PCI Bus wire is run from the drivers seat to a location under the dash where you can tap into any PCI wire. Most owners have just tapped into the Bus at the radio harness. On 1999-2001 WJ's, a single separate PCI wire plugs into the back of the radio. For 2002-2004 models tap in to Pin 14 of the 22-pin radio harness. Radio wiring diagrams can be found Here .
In addition to the PCI Bus, Power and Ground, four wires must be run between the drivers seat and the passenger seat, as shown in the table below:
Buildthread
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
