Snobrdrkid's WJ Build Thread - Page 415 - JeepForum.com
post #6211 of 6785 Old 06-25-2013, 09:51 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
So its Jeep being Jeep. Figures. Thanks guys.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #6212 of 6785 Old 06-25-2013, 09:57 AM Thread Starter
snobrdrkid07
WJ for Life
Finally fixed the driver's side power seat with a new motor off eBay and some pins from TSC haha
Yeah I cleaned all that up too ^^^ haha
-Michael-
post #6213 of 6785 Old 06-25-2013, 10:01 AM
ChrisHager
Administrator
ChrisHager's Avatar
You should see the inside of the WJ and the TJ, especially after hitting that 'mud puddle'.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #6214 of 6785 Old 06-25-2013, 10:03 AM Thread Starter
snobrdrkid07
WJ for Life
Yeah I would rather not!
-Michael-
post #6215 of 6785 Old 06-30-2013, 08:31 AM Thread Starter
snobrdrkid07
WJ for Life
Even thought I just fixed my power seat up front. I just got a full set of leather seats!
Taupe, 10 way power, heated, memory all for $100. In great condition too.
-Michael-
post #6216 of 6785 Old 06-30-2013, 08:42 AM
compcrasher86
$100 WOW what a steal michael
Matt
compcrasher86 is offline
post #6217 of 6785 Old 06-30-2013, 10:30 AM
04Overland47
04Overland47's Avatar
Sweet deal! Go home Michael you're
2004 WJ Overland 4.7HO Graphite 127k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / SOLD!
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
2002 WJ Overland 4.7HO
04Overland47 is offline
post #6218 of 6785 Old 06-30-2013, 06:20 PM Thread Starter
snobrdrkid07
WJ for Life
Here we go! Won't be able to get the memory to work. But would like to get the heated seat option going somehow!
They look great and are really comfy!
-Michael-
post #6219 of 6785 Old 06-30-2013, 09:58 PM
SnowLeopard
They look good. Really. If I recall, the heated seat module is under the driver's seat, and this goes under the carpet to the passenger seat. There's an in-dash button/switch that turns it on. It looks to be some form of transformer under the driver seat. I'm not sure how it all works. I never could figure it out, so when I transplanted leather WJ seats into my ZJ, I just lived without the heating function. I hope you're able to find a way to make them work. It might be easier as you're putting them into another Dub.
SnowLeopard is offline
post #6220 of 6785 Old 06-30-2013, 10:03 PM Thread Starter
snobrdrkid07
WJ for Life
WJJeeps is my hero lol. I'll keep an eye on eBay. Should have snagged that whole WJ. He wanted a Grand and it was mine. There was much money to be made.
For 1999-2004 Grand Cherokees that came without heated seats the wiring is a little more involved as the heat function is controlled via the PCI Bus and you will be hooking up two seats. Two heated seat switches will have to be purchased and installed in the center bezel. Some center bezels have the holes pre-cut with blank plates installed while others may have to be trimmed out with a dremel type tool. Some owners elect to just purchase a new center console bezel assembly as there are several choices available (with and without ashtray for example). See Interior Trim for a list of part numbers for center bezels.
NOTE: A factory pre-wired harness for the heated seat switches is located behind the center lower bezel in most if not all models that did not have this feature. All you have to do is plug the two harness plugs into the two heated seat switches.
-Michael-
post #6221 of 6785 Old 07-01-2013, 01:42 PM Thread Starter
snobrdrkid07
WJ for Life
Well I saw something I didn't really like yesterday from the Jeep. Saw a puff of blue smoke from the exhaust on start up. Just a little bit and stopped. (my friend was moving the Jeep and I saw it). So I was told that this was the valve seals leaking a little oil into the exhaust. I guess it is something to keep an eye on and check the oil levels more frequently. I'm going to be curious with the next oil analysis if they find any excessive iron or metal.
-Michael-
post #6222 of 6785 Old 07-19-2013, 10:27 PM Thread Starter
snobrdrkid07
WJ for Life
I put in the other heated mirror for the passenger side today. While I had the door panel I remembered that the Keyless Entry antenna was in the passenger door panel. I read around a while ago on here that people had luck extending the range by adding some more wire to the antenna wire. So, I added about 3 feet of similar gauge wire to it and taped it to the door panel. Put it back together and BAM I now have about 20-30 foot range compared to 2-3 feet of range! Simple and easy!
-Michael-
post #6223 of 6785 Old 07-20-2013, 02:26 AM
compcrasher86
Bam!
Matt
post #6224 of 6785 Old 07-20-2013, 11:52 AM
Merc1973
Awesome thread and WJ!
I'm still on page 388 and need to catch up.
I was wondering if you could possibly measure your IRO LCA's length so I can get my caster close to yours.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6225 of 6785 Old 07-21-2013, 01:27 PM Thread Starter
snobrdrkid07
WJ for Life
BAM BAM... BAM!
Hey Thanks man, Sure has been a project. Haha.
Every Jeep is a little different but, to get a rough count I have about 4-5 threads showing on my LCA's. Barely extended over factory length from what I can tell, I really does not take much. Where I am at, caster wise, is a little too much. I am round 6.7 of caster at the moment and I am getting some driveline MINOR driveline vibes at 70-75+ mph.
I would recommend a bit of trial and error with the control arms and shoot for a caster number around 5-5.5, that seems to be a general number to shoot for in the WJ community with a lift. I got myself an unlimited alignment plan with a local tire shop so they can measure my caster angle for me. (They won't adjust it, the print out just tells me what I needed to do).
If you would like, I can take some pictures for you for a visual reference.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
