Snobrdrkid's WJ Build Thread - Page 413 - JeepForum.com
post #6181 of 6786 Old 05-18-2013, 10:52 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Yeah I almost think it rides harsh sometimes. Need long arms I guess! Haha.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6182 of 6786 Old 05-23-2013, 11:51 AM Thread Starter
snobrdrkid07
WJ for Life
Found a trans pan that has a drain hole and can get it machined with a temp sensor hole.
http://www.yourcovers.com/transpan_9862.php
-Michael-
post #6183 of 6786 Old 05-24-2013, 08:56 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Deep well pans are a mixed blessing.
Loss of ground clearance on the most vulnerable part of your vehicle.
Cast aluminum will crack where the stock steel pan would dent.
You'd be better off buying a new stock pan and having the bungs welded into it. It's not like you would benefit from the deep-well pan anyway given that you have already added a large aux trans cooler.
~Richard
billzcat1 is offline
post #6184 of 6786 Old 05-27-2013, 11:09 AM Thread Starter
snobrdrkid07
WJ for Life
I didn't even really read that much about it, I knew it was a deep well but didn't think much about aluminum. Cracking versus steel denting. I'll check prices on a stock pan, not a huge priority. When it comes time to change the fluid and filter this will be revisited.
Another thing that has come up was about the Moog SS (and even my Rough Country SS), the bushing have so much play in them. I took it off and inspected and there was notable for play. I'm not sure how much that has on the steering. When a friend put on his stock stabilizer that had the bolt already connected didn't have the play that the Moog did, he had said that the stock stabilizer did a better job than the Moog?!
Lastly, there is some body rust going on the driver side passenger fender in the door well. Calling body shops tomorrow to get quotes to just grind off the paint and re do that area. Its not bad and its rotting through yet. No metal should need to be replaced. But I want to take care of it now before it gets any worse. I've got no idea why its bubbling either. There is no damage on either side, doesn't make any sense.
-Michael-
post #6185 of 6786 Old 05-31-2013, 02:54 PM Thread Starter
snobrdrkid07
WJ for Life
Cleaned up the Piece today. I do not know if you all remember the one time I had full on DW over a bridge on I-64, the only time. I went back over the bridge and it was alright this time around. I guess loose lug nuts really can cause you to have a bad day.
-Michael-
post #6186 of 6786 Old 05-31-2013, 02:58 PM
Thomahawk
Wow man, thats super clean, Thumbsup!!!
Mine is just full of pollen, driving the beater bike These summer days
Buildthread
Thomahawk is offline
post #6187 of 6786 Old 05-31-2013, 03:01 PM Thread Starter
snobrdrkid07
WJ for Life
Thank you, it had been about a month since the last "bath" haha. She was dirty!
I've been more busy with work then I have been with school lately, not what I was expecting! I was hoping to have finished painted and the other two 17" rims and have them on by now too!
-Michael-
post #6188 of 6786 Old 05-31-2013, 08:07 PM Thread Starter
snobrdrkid07
WJ for Life
Hey this might be something you all could help me with... my oil has been getting black very fast, after about 3000 miles its black. Not even dark brown, black. I've got no clue why. There are no leaks in the PCV system or vacuum system, (I'm not sure of the exact term). Air Filter is clean and such. There was not any fuel in there from the oil analysis.
-Michael-
post #6189 of 6786 Old 05-31-2013, 09:41 PM
compcrasher86
Are you running stock tune? Perhaps your 02 sensor might be on its way out? Just thinking of things that would blacken up your oil quicker, ie more fuel in oil generally can cause black stinky oil.
Matt
compcrasher86 is offline
post #6190 of 6786 Old 05-31-2013, 09:46 PM Thread Starter
snobrdrkid07
WJ for Life
I've been running the 87 SuperChips Tune for like 2 years. Don't know. But wouldn't I get really crappy mpg in the Jeep if I an O2 was going out?
-Michael-
post #6191 of 6786 Old 06-01-2013, 02:18 AM
Thomahawk
Faulty O2 sensors should mess up your mpg,
Oil going black after 3000 miles sounds normal to me, only thing you could do is to use some engine flush at every oil change to Get shhh out of the engine, i use Omega engine flush, might Work with seafoam to, never tried That stuff.
Buildthread
post #6192 of 6786 Old 06-01-2013, 11:23 AM Thread Starter
snobrdrkid07
WJ for Life
Maybe I should try some of that engine cleaner, does it get any sludge/crap out? Can you post a link? Can't hurt to try it.
-Michael-
post #6193 of 6786 Old 06-01-2013, 04:07 PM
compcrasher86
Actually it can hurt. If you have any seals being held together by "engine gunk" or are weak and on their way out, the cleaning agents may cause new leaks to show up. Arguably that means you probably should have known about and replaced the problem already but some people are not always prepared for an engine teardown or to have stuff replaced right away. I already have a list and I'd rather not add to mine.
Matt
post #6194 of 6786 Old 06-01-2013, 04:13 PM Thread Starter
snobrdrkid07
WJ for Life
I've got new oil pan gasket, rear main seal, and crank case deal. About 30k on them so I would not expect them to be weak. Are there any other seals that I'm missing?
-Michael-
post #6195 of 6786 Old 06-01-2013, 04:26 PM
compcrasher86
When did you get a new oil pan gasket?? I know there's also valve cover deal (but that's mad easy to do, and head gasket (shouldn't be held together with sludge anyways) but I'm sure there's other seals internal to the engine I'm not familiar with (perhaps oil pump seal?)
Matt
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
