Snobrdrkid's WJ Build Thread - Page 412 - JeepForum.com
post #6166 of 6785 Old 05-13-2013, 01:42 PM
ChrisHager
Administrator
ChrisHager's Avatar
Sure did. Order is placed!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6167 of 6785 Old 05-16-2013, 10:36 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Made it home from College today. Took it nice and easy on the way home and the Jeep treated me well. Only had one bad string of bumps made it wobble a few times and it settled out by itself and not full on DW. Still get a lot of minor shimmies and stuff. As to be expected, nothing has really changed haha.
I did average 23 miles per gallon on the way home! That was a by hand calculation too! Loaded down, hills and crap, I'm impressed. Glad the upkeep of the Jeep shows.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6168 of 6785 Old 05-17-2013, 07:09 AM
ChrisHager
Administrator
ChrisHager's Avatar
Wow! When I drive to Columbia, I only get around 15...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6169 of 6785 Old 05-17-2013, 07:15 AM
compcrasher86
I got 25 hand calc this last time around. I was shocked to get home and have 1/4 tank left. I was doing 49-55 the whole way home and it took a good 9 hours between stopping to fool with my Jeeps allignment.
Matt
compcrasher86 is offline
post #6170 of 6785 Old 05-17-2013, 07:29 AM
ChrisHager
Administrator
ChrisHager's Avatar
Do you two fill up with magic or do you add a quart of liquified fairy dust and ground up unicorn to the tank while filling?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6171 of 6785 Old 05-17-2013, 07:32 AM Thread Starter
snobrdrkid07
WJ for Life
I averaged about 60 mph for the trip. And I sprinkle magic on my Jeep
-Michael-
post #6172 of 6785 Old 05-17-2013, 07:34 AM
compcrasher86
Stock street tires, very conservative driving. Okay fine maybe a little unicorn.
Matt
post #6173 of 6785 Old 05-17-2013, 07:39 AM
ChrisHager
Administrator
ChrisHager's Avatar
I knew it!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6174 of 6785 Old 05-17-2013, 08:25 AM Thread Starter
snobrdrkid07
WJ for Life
When I get bigger tires... that'll go right out the window.
-Michael-
post #6175 of 6785 Old 05-17-2013, 11:43 AM
Thomahawk
^^^Sure will, after going to 31's my V8 got thiiiirsty, mostly city driving These days, i really dont want to know how bad of a mpg i Get now.
Buildthread
Thomahawk is offline
post #6176 of 6785 Old 05-17-2013, 12:01 PM Thread Starter
snobrdrkid07
WJ for Life
I get 12 around town, heavy foot!
-Michael-
post #6177 of 6785 Old 05-18-2013, 11:37 AM Thread Starter
snobrdrkid07
WJ for Life
The roads sure suck around here back home! The springs really show how stiff they are around the city. Has anyone ever thought that these springs are just *too* stiff for the WJ and the suspension to handle? Like I was wondering if the springs can cause issues being too stiff and not absorbing the bumps? Crossed my mind but, probably not an issue.
The Jeep sure likes to have little shimmies around here, no where near the realm of full DW mind you... I'm not sure if that is just how it is going over all these bumps or what. (40-50 mph). Nothing that is bad, just the steering wheel will go back and forth a time or two and settle out, small but present. Not to mention that I have to constantly correct where I am going... *bump* oh I am going this way now... That is the obnoxious part.
I really hope that you all are right and this is all my tires. I hope to swap them over tomorrow! Also going to check out the Moog SS... It just seems weak and letting the steering *bounce* around.
\mini-rant. LOL
-Michael-
post #6178 of 6785 Old 05-18-2013, 12:53 PM
Thomahawk
I bet my BDS Are a notch stiffer, and our roads a little worse, but i still like the setup, the 70's profile sucks up the worst of it, anyway you want a tire with quite stiff sidewall to maintain the handling in curves.
Buildthread
post #6179 of 6785 Old 05-18-2013, 04:14 PM Thread Starter
snobrdrkid07
WJ for Life
How does your Jeep drive with the stiff springs?
Haha my tire sidewalls are extremely soft... so that results in the poor handling...
-Michael-
post #6180 of 6785 Old 05-18-2013, 05:09 PM
Thomahawk
With the BDS and Addco F+R it rides firm but not harsh, bodyroll zero to nothing, very stiff and confident thrue curves, i love the handling, its Way better than stock.
Alitte harsher vs stock w/Billys at 60's profile,
But not harsher than stock at 20's with 50's profile.
Perfect at 70's profile which i got now
Will try to air mine up a notch now as temp raise from 10-25 degree Celcius, deff can feel them getting softer.
Good luck with the tires,
Buildthread
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
