Snobrdrkid's WJ Build Thread - Page 411 - JeepForum.com
post #6151 of 6785 Old 05-02-2013, 06:26 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I guess this is why the 2" bump stops were a little too long...
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6152 of 6785 Old 05-02-2013, 09:40 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Put em in sideways!
~Richard
billzcat1 is offline
post #6153 of 6785 Old 05-02-2013, 09:43 PM Thread Starter
snobrdrkid07
WJ for Life
That could work if I drill holes in it. Wonder how the track bar bolt would fair with this there...
I guess if I ever get the other bolt in there I could have the nut facing the rear instead of the front.
-Michael-
post #6154 of 6785 Old 05-03-2013, 03:47 PM Thread Starter
snobrdrkid07
WJ for Life
Greased the outer face of the bushings... didn't help. Still makes the same crunch, pop, squeak, lame. Maybe I need to grease the outside of the sleeve. :/ What rotates if the sleeve is stationary? The bushings supposed to rotate on the sleeve?
-Michael-
post #6155 of 6785 Old 05-07-2013, 11:54 PM Thread Starter
snobrdrkid07
WJ for Life
Track bar is still acting up bad after a few minutes of driving. Weird that is is fine for a little bit but, I guess as it warms up, it starts to squeak. My guess is the bushing is trying to rotate on the sleeve and just failing miserably. I would think the sleeve would be stationary...
Thinking of finding an "easy" way of adding a temp gauge to the transmission... Yeah the word easy... hah.
-Michael-
post #6156 of 6785 Old 05-08-2013, 07:07 AM
compcrasher86
To get a rough idea you can put a sender inline at the cooler input hose upfront but that may not be all that accurate the best way is to have a pan-mounted sender.
Matt
compcrasher86 is offline
post #6157 of 6785 Old 05-10-2013, 11:07 PM Thread Starter
snobrdrkid07
WJ for Life
Left the sunroof flipped up during a heavy storm. Awesome, soaked the headliner, seats, and carpet. Stained the seats too, going to have to find a way to clean them. While I was inside towelling stuff off, I had the AC on full blast and on recirculate and it helped dehumidify the cabin and dry it out. What a mess.
-Michael-
post #6158 of 6785 Old 05-10-2013, 11:08 PM Thread Starter
snobrdrkid07
WJ for Life
I was wondering if there was any way I could add a sensor to the pan. I guess when I did the fluid/filter drain/replace.
-Michael-
post #6159 of 6785 Old 05-11-2013, 01:49 AM
Thomahawk
Auch thats shhh, hope you got it sorted out.
Buildthread
Thomahawk is offline
post #6160 of 6785 Old 05-11-2013, 04:50 PM Thread Starter
snobrdrkid07
WJ for Life
It seems like the headliner will be okay. I was going to leave the windows open to vent it out, but it has been raining off and on. So it has been hot and the Jeep was a sauna inside haha.
Did get a chance to work on the seats but I should be able to stain remove them.
Took a 40 mile cruise to nowhere today with the AC running and on Recirculate, It got cold in there! But, it helped dry it out more.
I'll tell you guys, I love how the Jeep rides on the highway and around town. Those damn bumps though!? Haha, the DAY I get home I am swapping the Overland rims and tires on and going to go from there. Everyone says I need to do ball joints but there is just no play in them... I do need to do axle side uppers, thats on the list. Would really hate to un-lift the damn thing.
-Michael-
post #6161 of 6785 Old 05-13-2013, 10:47 AM
ChrisHager
Administrator
ChrisHager's Avatar
Now that you've had your Transmission Cooler for a while, how has it been treating you? How was the fitment, etc.? I'm going to place an order for one today and wondered: If you could do it again, would you go with the same one (Derale D13503) or would you get something different?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6162 of 6785 Old 05-13-2013, 12:43 PM Thread Starter
snobrdrkid07
WJ for Life
I have been very happy with it thus far. Fitment was a little tight as it is a "Class III" Cooler and rather large. But, got it in there nonetheless. I did not mount it on the AC condesnor as shown in the thread/pictures here It kinda sits on the two bars that hold the hood latch and I have not had an issue with it there. I've had to tighten a hose clamp once on the Jeep side metal to rubber hose connection but nothing major. I went to the auto store and purchases like 6-8 feet of large ID TRANSMISSION fluid rated hose and just used that to keep it symmetrical. They provide you with some hose but, for my install it was not enough.
I oriented it sideways with the flow coming from the transmission to the bottom and from the top back to the transmission. (I need to double check this however, I do recall something like this so it would not all drain back and have to be pumped up every time.)
As you may know, I went from the trans, through the factory cooler, and then to the aux cooler and back to the transmission. I've had no negative effects that I can say with this setup in the way of "overcooling". I've been able to go out start up the Jeep in 0 degree weather and after a minute down the street it will lock up the torque converter. Basically I've never in the life of the Jeep had the torque converter *not* lock up because it was too cold. I've been meaning to get a temperature sensor in there sometime. I wish Jeep has a real trans temp monitor and real oil pressure gauge (in the 02-04's)
*Update* From a Derale Rep on the orientation... (Went *way* back in the emails...(3/9/12))
Me - "Hello, I have just bought a Series 8000 Oil Cooler, stock number 13503 and I was wondering what way you should orient the cooler. As in, where the barbs should be pointing to connect the rubber hoses? Downwards or on the side? Thank you."
Derale Rep - "In the best case you would want the fittings to be pointing towards the sky. Second you would want them to either side. Last is facing down."
Me -"... Now, does it matter how the fluid flows through the cooler? From the looks of it, I did not see any indications that said one barb over the other. But, I was thinking to route the lines for the fluid to flow "up" through the radiator for the way of backflow prevention... "
Derale Rep - "Yes, for the most effective routing you will want the flow of the fluid to move up through the cooler."
I hope that clears up the orientation and fluid flow. Reason I did not point them upwards is there was not enough room or I did not have enough hose, I can not remember. But, it has been fine on its side.
Summary: Yes, I would do it again over and over. Best investment towards the 42re to keep it happy. I was able to do it my College's parking lot with basic tools, relatively easy. What was a huge pain was finding out all that information prior to! I would get the same one, I do not think it is too big or too small.
-Michael-
post #6163 of 6785 Old 05-13-2013, 12:54 PM
ChrisHager
Administrator
ChrisHager's Avatar
Excellent! I'll order it this afternoon. Thanks!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6164 of 6785 Old 05-13-2013, 01:25 PM
ChrisHager
Administrator
ChrisHager's Avatar
Are you sure you purchased D13503? 503 is Class III. 504 is Class IV.
Edit: I see on the picture I re-posted of yours, you did get D13503.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6165 of 6785 Old 05-13-2013, 01:30 PM Thread Starter
snobrdrkid07
WJ for Life
Oops, my mistake! I fixed that, it is a Class III! Hope all that helped.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
