Snobrdrkid's WJ Build Thread - Page 410 - JeepForum.com
post #6136 of 6785 Old 04-19-2013, 03:31 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Yeah I am pretty sure that they are the Wrangler SRA's. I am not buying them, my friend is purchasing them. It is a great deal and he wants them but, will not be able to run them immediately. So, in the meantime he said I could run them on the WJ for sizing purposes and see how the Jeep drives in lieu of the crap Yokohama's.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6137 of 6785 Old 04-20-2013, 12:35 AM
compcrasher86
This isn't your buddy with the TJ right? TJ wheels won't bolt up to WJs.
Matt
compcrasher86 is offline
post #6138 of 6785 Old 04-20-2013, 01:09 AM Thread Starter
snobrdrkid07
WJ for Life
Nah it is another one, there are like a dozen people that are regular in the club. They are JK take off's.
-Michael-
post #6139 of 6785 Old 04-21-2013, 12:27 PM Thread Starter
snobrdrkid07
WJ for Life
FINALLY was able to put the front control arms in the right place. Switched the bolts that were in the wrong spot and lastly we switched the frame side washers to the correct spot. So all good to go there. Then torqued to 125 foot pounds.
Got the uppers out too, axle bushings are soft. The bushings in the arms themselves are pretty solid, would replace them though. (IRO uppers)
Had a cool extension to torque the upper frame side.
-Michael-
post #6140 of 6785 Old 04-22-2013, 04:52 PM Thread Starter
snobrdrkid07
WJ for Life
Picked up some 2" front bump stop extensions for <$20 today. Sweet.
-Michael-
post #6141 of 6785 Old 04-26-2013, 05:20 PM Thread Starter
snobrdrkid07
WJ for Life
Bump stops are a bust, about an inch too long. With the spacer and just the rubber "jounce" it only gave me about 3/4" before hitting the axle. No dice.
-Michael-
post #6142 of 6785 Old 04-26-2013, 05:40 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
I put 2" extensions in mine and they appeared to be "too much" but they haven't been a limitation at all.
That is fully stuffed on the bump stops. There's more travel in the shock but as I said, it hasn't been any limitation for what I've been doing with the Jeep.
~Richard
billzcat1 is offline
post #6143 of 6785 Old 04-26-2013, 05:56 PM Thread Starter
snobrdrkid07
WJ for Life
I may need to actually measure, they could be longer than 2". I wonder if it wouldn't be enough up travel though. I couldn't even fit the bump stop into the holder with the extension in.
-Michael-
post #6144 of 6785 Old 04-26-2013, 05:57 PM
billzcat1
2003 WJ
I should add that this is where I was with no extensions...
~Richard
post #6145 of 6785 Old 04-26-2013, 10:10 PM Thread Starter
snobrdrkid07
WJ for Life
Hmm, it really does not look like it affected it *too* much. Did you have any problem stuffing the bump stop back in the holder or did you have to raise the Jeep to get it in there? Lastly, do you estimate for distance between the axle and bottom of the bump stop, for comparison.
-Michael-
post #6146 of 6785 Old 04-28-2013, 10:25 PM Thread Starter
snobrdrkid07
WJ for Life
Car show this weekend at Tech was awesome, got to be a part of it! Jeep still cleans up pretty well!
-Michael-
post #6147 of 6785 Old 04-30-2013, 12:02 PM Thread Starter
snobrdrkid07
WJ for Life
Been lazy and have not ordered Grease yet for the Poly TB... I guess this is what I get for that.
-Michael-
post #6148 of 6785 Old 04-30-2013, 05:46 PM Thread Starter
snobrdrkid07
WJ for Life
I have been searching around the interwebs for a substitute poly grease. This is what I came up with as a *safe* substitute for the KOR grease at a much lower cost. http://www.energysuspensionparts.com...p?prod=9.11110
-Michael-
post #6149 of 6785 Old 04-30-2013, 06:42 PM
04Overland47
04Overland47's Avatar
Hmm energy suspension does have some good stuff, so I would trust them. Maybe I'll buy some for the Addco bushings, rather than use brake grease. I'd like to hear other's input as well!
2004 WJ Overland 4.7HO Graphite 127k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / SOLD!
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
2002 WJ Overland 4.7HO
04Overland47 is offline
post #6150 of 6785 Old 04-30-2013, 06:55 PM Thread Starter
snobrdrkid07
WJ for Life
I guess the grease finally dried up. I need some thick and sticky grease. Which it seems like that is what the energy suspension grease is like.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
