Snobrdrkid's WJ Build Thread - Page 405 - JeepForum.com
post #6061 of 6785 Old 04-03-2013, 03:53 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I've got some white lithium grease that should do the trick then.
I'll do some shopping for the future!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #6062 of 6785 Old 04-03-2013, 08:05 PM
compcrasher86
Well go figure I've got a tub of marine grease that stuffs nasty if you ever get it on your hands.
Matt
compcrasher86 is offline
post #6063 of 6785 Old 04-04-2013, 08:46 AM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by ChrisHager View Post
Fiberglass. I understand what you mean about smacking it around. That being said, I have a zip tie hanging loose on my roof rack rail. When I go through a car wash, I bend the antenna back under the zip tie. You could always do that and slip it out when you want it. Or, you could get a 4' and take it off just as you do with the 3'. If I think about it, I'll snap a quick pic here in a little while.
A bit off subject but I finally remembered to get these posted in here. This is how the 4' flexible antenna folds back. I think 3' would be too short to do this. I only fold it back for car washes though it would be handy in low parking garages, etc. where you'd whip everything.
Zip Tie. I leave it here. Usually it's fine but it does move around a little when driving down the interstate. It took me forever to figure out what the tapping noise above my head was!
Antenna slipped into Zip Tie:
How flexible it is:
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6064 of 6785 Old 04-04-2013, 10:23 AM Thread Starter
snobrdrkid07
WJ for Life
What brand antenna is that? That's pretty flexible and I like the mounting point you have there as well. Is that through the cowling? I would like to mess around with the Jeep again this weekend. I've got a big volunteer project with Va Tech this weekend so I'm not sure how much ill be able to tool around with the CB and such. Surprisingly the magnet Mount CB antenna has a very low SWR.
Secondly I've been working on a side wiring project to clean up all my mess for the amps and extra wires. I would like to run a 0 or 1 gauge wire from the battery to the back seat to go to a distribution block to connect amp 1, amp 2, and aux power wire that currently powers a few small things. Currently there are two 4ga wires and an 8ga wire coming off the battery and all running to the same place... to the rear seat. So I want to consolidate it all.
Thirdly I hate my tires. It sat overnight and it got cold last night. The tires flat spotted in 24 hours and man did they vibrate at 55-65. They suck. Just like body vibrations and crap not a shimmy. Its got to be the tires too because it doesn't always do this when I make the same drive.
-Michael-
post #6065 of 6785 Old 04-04-2013, 10:58 AM
ChrisHager
Administrator
ChrisHager's Avatar
The antenna I'm using is a Wilson Flex Silver Load 305-4FD. It does indeed go through the cowling. It's a little annoying to work on but once it's set, it's great. I think it looks nice and it's the most central you can get to the vehicle without mounting on the roof.
I thought I linked this before but here it is again: CB Antenna Install
That's a heck of a wire but it would sure clean things up - especially your battery terminals!
You need new tires.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6066 of 6785 Old 04-04-2013, 11:07 AM Thread Starter
snobrdrkid07
WJ for Life
Thank you for posting the link again. Will check that out when I get home and bookmark.
Yeah it is. I'm hoping 1 gauge should suffice. I'm going to a welding supply shop, Arcet. Going to see what they have. I've got some sweet marine terminals and I've got the main jeep wires on the post on the marine terminal and want to put this wire on the bolt holding the terminal on the battery post.
You need new tires.
Pffftttchhh. I'm about to go slash them and speed up that process. Or some burn outs one wheel at a time haha. They are dry rotting on the inside too!
-Michael-
post #6067 of 6785 Old 04-04-2013, 02:03 PM
Thomahawk
I see you got inspired to clean up the wireing, Thumbsup!
About time to Get new TIRES, they have been a big headeach for ya, bet that Will solve your problem.
Buildthread
Thomahawk is offline
post #6068 of 6785 Old 04-04-2013, 02:33 PM Thread Starter
snobrdrkid07
WJ for Life
Well I picked up 2 gauge welding wire rated for 200 amps at 50 feet before losing before loosing efficiency or even starting to get hot. I would think 16 feet fused @125 or 150 should be well under its rating. And its probably never going to see much over 100.
Oh these tires. *shakes head* they are just running their course for the next 2 months.
-Michael-
post #6069 of 6785 Old 04-04-2013, 05:55 PM Thread Starter
snobrdrkid07
WJ for Life
What started out as some random snow showers...
Turned out to be a big mess of almost 6 inches of snow in 2-3 hours!
I got stuck in the parking garage because of the mass exodus from campus and resulting gridlock. Took about 1.5 hours to get out of the garage.
Seriously good thing I got gas before I parked because we sat and sat! I had just filled up and reset the average MPG prior to getting to campus this afternoon. As a result of all the sitting and idling!
Jeep poser shot of course!
Saw a sweet Land Rover Defender 90 after fianlly getting to Wendy's after taking 2 hours to move about 3 miles!
-Michael-
post #6070 of 6785 Old 04-04-2013, 06:00 PM Thread Starter
snobrdrkid07
WJ for Life
So I bought that 2 gauge welding wire of 100% oxygen free pure copper wire. None of that copper clad aluminum garbage. I should use about 16-18 feet of it from the battery to the rear seat. I plan on running a 125 or so amp inline fuse on the welding wire. When that ends under the rear seat at the distribution block here, I am going to use my existing inline fused wire's to run to their respective devices. So in all the main wire will be fused and then the smaller wires coming off the block will be fused appropriately as well.
Here is a shot of the wire. (I picked up an 2 gauge 3/8 lug as well)
Here is a chart that I found with the wire gauges and rated amps per length. I do not see any reason why 2 gauge should not be enough to run what I need. The amps are fused at 60 and 40 respectively. On top of that, I will be powering the cargo trunk outlet and the passenger power seat. I do not forsee and issue with "welding wire" vs. the "amplifier wire" difference. Only thing that *might* be an issue is that the jacket seems thin? However, when I look at some power wire on my desk it seems to be the same.
-Michael-
post #6071 of 6785 Old 04-04-2013, 10:14 PM Thread Starter
snobrdrkid07
WJ for Life
Any advice on parking brake adjustment. Jeep felt really sluggish just now when I was out, needing more skinny pedal. I came back and walked around to check if I could smell the brakes. Well the rear (both sides) smell like they were burning. Jeep won't even "free roll" down a slight incline like normal, something is dragging in the rear. Maybe there is a bunch of snow jammed up in there, not sure but definitely dragging.
-Michael-
post #6072 of 6785 Old 04-05-2013, 04:55 AM
Thomahawk
Nice downfall of snow
Looks like you have done your homework pretty good on the wireing, Thumbsup!
As for the emergency brake, you Will need to back them off so you can freely rotate the wheel by hand (when off the ground), i had my right rear draging Long time ago, at highway speed the whole rim got heated up, and thats NO good.
Buildthread
post #6073 of 6785 Old 04-05-2013, 12:05 PM Thread Starter
snobrdrkid07
WJ for Life
It is going to be 65 degrees here today!?!?! The weather is nuts!
I think I will be good to go for the wires. I need to find a good distribution block. Ideas?
About the parking brake, they seemed to have fixed themselves. Maybe there was a ton of snow piled up on them last night. There is still a ton of snow jammed up in the transfer case area that is currently melting away. I jacked up the Jeep and spun each tire and it seemed relatively free. here it a quick video.
-Michael-
post #6074 of 6785 Old 04-05-2013, 02:01 PM
Thomahawk
What about this one?
http://www.sonicelectronix.com/item_...DAGU3234P.html
2gauge in, 4 out's, fused???
If not they have 154 other, you should find one That suits your needs.
Buildthread
post #6075 of 6785 Old 04-06-2013, 07:12 PM Thread Starter
snobrdrkid07
WJ for Life
Rolled a Jeep over too. https://www.youtube.com/watch?v=ml_XpwDi0Ng&
That was me driving.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
